查看: 17085|回复: 1
双ADC规则触发问题以及ADC外部触发问题
发表于 2016-11-14 22:04:20 | 显示全部楼层 |阅读模式
  视频里面双ADC规则同步模式,配置ADC2初始化结构体的时候把外部触发选的ADC_ExternalTrigConv_None,然后在后面调用ADC_ExternalTrigConvCmd(ADCx_2, ENABLE);这个函数开启ADC2的外部触发,我想问可不可在初始化结构体里面这个外部触发设置好呢?如果可以要选择哪个参数
  1. #define ADC_ExternalTrigConv_T1_CC1                ((uint32_t)0x00000000) /*!< For ADC1 and ADC2 */
  2. #define ADC_ExternalTrigConv_T1_CC2                ((uint32_t)0x00020000) /*!< For ADC1 and ADC2 */
  3. #define ADC_ExternalTrigConv_T2_CC2                ((uint32_t)0x00060000) /*!< For ADC1 and ADC2 */
  4. #define ADC_ExternalTrigConv_T3_TRGO               ((uint32_t)0x00080000) /*!< For ADC1 and ADC2 */
  5. #define ADC_ExternalTrigConv_T4_CC4                ((uint32_t)0x000A0000) /*!< For ADC1 and ADC2 */
  6. #define ADC_ExternalTrigConv_Ext_IT11_TIM8_TRGO    ((uint32_t)0x000C0000) /*!< For ADC1 and ADC2 */
  7. #define ADC_ExternalTrigConv_T1_CC3                ((uint32_t)0x00040000) /*!< For ADC1, ADC2 and ADC3 */
  8. #define ADC_ExternalTrigConv_None                  ((uint32_t)0x000E0000) /*!< For ADC1, ADC2 and ADC3 */
  9. #define ADC_ExternalTrigConv_T3_CC1                ((uint32_t)0x00000000) /*!< For ADC3 only */
  10. #define ADC_ExternalTrigConv_T2_CC3                ((uint32_t)0x00020000) /*!< For ADC3 only */
  11. #define ADC_ExternalTrigConv_T8_CC1                ((uint32_t)0x00060000) /*!< For ADC3 only */
  12. #define ADC_ExternalTrigConv_T8_TRGO               ((uint32_t)0x00080000) /*!< For ADC3 only */
  13. #define ADC_ExternalTrigConv_T5_CC1                ((uint32_t)0x000A0000) /*!< For ADC3 only */
  14. #define ADC_ExternalTrigConv_T5_CC3                ((uint32_t)0x000C0000) /*!< For ADC3 only */
上面这几个具体代表什么?什么情况下用?
谢谢。
发表于 2016-11-15 08:32:22 | 显示全部楼层
具体的看 参考手册 ADC 章节 的 规则触发模式 部分
GMT+8, 2025-12-14 11:49 , Processed in 0.037415 second(s), 24 queries , Gzip On.
