查看: 14168|回复: 3
向各位高手请教一个问题 !!!
发表于 2016-12-9 13:50:09 | 显示全部楼层 |阅读模式
请问 最后 为什么    bitstatus = GPIO_PIN_SET ,  一个 变量 可以赋值给  一个具有两个成员的枚举变量呢?
typedef enum
  GPIO_PIN_RESET = 0,
  GPIO_PIN_SET
}GPIO_PinState;
  ##### IO operation functions #####
@endverbatim
  * @brief  Read the specified input port pin.
  * @param  GPIOx: where x can be (A..H) to select the GPIO peripheral for STM32L4 family
  * @param  GPIO_Pin: specifies the port bit to read.
  *         This parameter can be GPIO_PIN_x where x can be (0..15).
  * @retval The input port pin value.
GPIO_PinState HAL_GPIO_ReadPin(GPIO_TypeDef* GPIOx, uint16_t GPIO_Pin)
  GPIO_PinState bitstatus;
  /* Check the parameters */
  assert_param(IS_GPIO_PIN(GPIO_Pin));
  if((GPIOx->IDR & GPIO_Pin) != (uint32_t)GPIO_PIN_RESET)
    bitstatus = GPIO_PIN_SET;
    bitstatus = GPIO_PIN_RESET;
  return bitstatus;
发表于 2016-12-9 14:18:53 | 显示全部楼层
枚举变量的值就是0或1,一个变量赋值为0或1,完全没问题
 楼主| 发表于 2017-1-16 09:32:10 | 显示全部楼层
多谢指教!
发表于 2017-1-21 10:49:01 | 显示全部楼层
GMT+8, 2024-11-27 20:23 , Processed in 0.026939 second(s), 23 queries , Gzip On.
