查看: 10970|回复: 7
fire_easylink_app例程下载后,调试助手显示信息与要求不符,不知问题出在何处?
发表于 2017-2-15 20:58:39 | 显示全部楼层 |阅读模式
我使用的是新版野火F429开发板,按要求(前面7项已经检查过,在下载OV5640时,一切正常)下载fire_easylink_app例程后,串口调试助手显示信息如下: [IA_[6DX`GIYK3V8WM{QGMV.png
串口调试助手显示信息如下:
  1. [4][Platform: mico_platform_common.c: 104] Platform initialised, build by RVMDK
  2. [619][SYSTEM: system_misc.c: 235] Free memory 121436 bytes
  3. [626][SYSTEM: system_misc.c: 241] Kernel version: 31620002.042
  4. [633][SYSTEM: system_misc.c: 244] MiCO version: 2.4.0
  5. [639][SYSTEM: system_misc.c: 246] Wi-Fi driver version wl0: Nov  7 2014 16:03:45 version 5.90.230.12 FWI, mac C8:93:46:80:B9:33
前一部分信息基本正确,但到了后一部分却出现了
  1. [652][SYSTEM: mico_system_init.c: 134] Available configuration. Starting Wi-Fi connection...
  2. [662][SYSTEM: system_misc.c: 222] Connect to TP-LINK.....
  3. [1324][APP: MICOAppEntrance.c: 155] MICO CloudService: FogCloud.
  4. [1331][FOGCLOUD_IF: fogCloud.c: 129] FogCloud library version: 1.0.5
  5. [1339][FOG_UP_DATA: fogcloud_up_thread.c: 113] ------------upstream_thread start------------
  6. [1349][uart_demo: uart_recv_thread.c:  52] ------------uart data recv thread start------------
  7. [1869][FOG_UP_DATA: fogcloud_up_thread.c: 123] Module is not connected to the fogcloud!!!
  8. [2378][FOG_UP_DATA: fogcloud_up_thread.c: 123] Module is not connected to the fogcloud!!!
  9. [2837][SYSTEM: system_misc.c:  59] Wlan Connection Err -30
  10. [2843][APP: MICOAppEntrance.c:  39] Wlan Connection Err -30
  11. [2887][FOG_UP_DATA: fogcloud_up_thread.c: 123] Module is not connected to the fogcloud!!!
  12. [3396][FOG_UP_DATA: fogcloud_up_thread.c: 123] Module is not connected to the fogcloud!!!
  13. [3905][FOG_UP_DATA: fogcloud_up_thread.c: 123] Module is not connected to the fogcloud!!!
  14. [4414][FOG_UP_DATA: fogcloud_up_thread.c: 123] Module is not connected to the fogcloud!!!
按要求,如果正常,串口应该显示:
  2. [634][SYSTEM: system_misc.c: 235] Free memory 121436 bytes
  3. [641][SYSTEM: system_misc.c: 241] Kernel version: 31620002.042
  4. [647][SYSTEM: system_misc.c: 244] MiCO version: 2.4.0
  5. [653][SYSTEM: system_misc.c: 246] Wi-Fi driver version wl0: Nov  7 2014 16:03:45 version 5.90.230.12 FWI, mac C8:93:46:80:AE:56
  6. [667][SYSTEM: mico_system_init.c: 112] Empty configuration. Starting configuration mode...
  7. [679][CONFIG SERVER: config_server.c: 165] Config Server established at port: 8000, fd: 1
  8. [878][SYSTEM: system_easylink.c: 251] Start easylink combo mode
所下载的两个程序编译情况如下:
编译过程基本顺利,有警告但没有错误,不知道问题出在何处,为什么串口调试助手显示信息错误,希望火哥或者做过该实验的朋友能够帮我找出问题。
发表于 2017-2-16 09:05:18 | 显示全部楼层
是不是没有下载bootloader版本的程序
 楼主| 发表于 2017-2-16 11:03:44 | 显示全部楼层
不是,为保险,我又重做了几遍,还是一样,火哥应该也看到了,所需下载的两个程序的编译情况,我都发上去了,程序是从压缩包里解压出来的,没有修改,直接编译后先下载bootloader,后下载demo,当然BOOT1接3V3,WIFI接3v3等前期准备工作也是做了的,现在就是不知道错在哪,因为WIFI程序较为复杂,串口输出的提示:
  1. [668][SYSTEM: system_misc.c: 222] Connect to TP-LINK.....
  2. [1328][APP: MICOAppEntrance.c: 155] MICO CloudService: FogCloud.
  3. [1335][FOGCLOUD_IF: fogCloud.c: 129] FogCloud library version: 1.0.5
  4. [1343][FOG_UP_DATA: fogcloud_up_thread.c: 113] ------------upstream_thread start------------
  5. [1353][uart_demo: uart_recv_thread.c:  52] ------------uart data recv thread start------------
  6. [1873][FOG_UP_DATA: fogcloud_up_thread.c: 123] Module is not connected to the fogcloud!!!
  7. [2382][FOG_UP_DATA: fogcloud_up_thread.c: 123] Module is not connected to the fogcloud!!!
  8. [2841][SYSTEM: system_misc.c:  59] Wlan Connection Err -30
如:Module is not connected to the fogcloud!!!和Wlan Connection Err -30,是在什么情况下输出的,不是很清楚,网上也找不到原因和理由来解释,这个只有拜托火哥和懂该程序的朋友们了,自己真心不知道是什么原因,有什么提议或者需要提供任何资料,请告诉我,我会上传,请多指教,火哥,谢谢你的回复,麻烦继续哟。
 楼主| 发表于 2017-2-18 16:17:11 | 显示全部楼层
有谁碰到过类似问题吗,希望得到帮助。
发表于 2017-5-5 13:31:35 | 显示全部楼层
今天,使用F429挑战者开发板测试板载wifi功能,先下载BootLoader,然后下载demo,(复位)运行后,在USB串口上能显示(如下图),在手机上安装了WIFI-手机APP测试版,无法注册。其他所购模块(GSM,GPS)运行配套例程,均测试完好。请问火哥,下一步该怎办?
发表于 2017-5-5 13:53:47 | 显示全部楼层
zhoushanfei 发表于 2017-5-5 13:31
今天,使用F429挑战者开发板测试板载wifi功能,先下载BootLoader,然后下载demo,(复位)运行后,在USB串 ...
你是没有吧boot 跟3v3接在一起,boot就接口被屏幕挡住了。我今天也是APP无法注册。
发表于 2017-5-8 10:10:38 | 显示全部楼层
谢谢WSY,把boot1接上3.3V后,串口调试显示已经正常启动了,核心板蓝色LED也能正常闪烁了。但在andriod手机运行fire APP仍然不能注册,输入“”手机号码“”后,点“”发送“”显示提示信息{"code":605,"message:“”签名无效 ,应用至少需要一个默认签名,或签名未通过审核。“”}。
发表于 2017-9-11 15:03:45 | 显示全部楼层
zhoushanfei 发表于 2017-5-8 10:10
谢谢WSY,把boot1接上3.3V后,串口调试显示已经正常启动了,核心板蓝色LED也能正常闪烁了。但在andriod手 ...
你好,哥们。我玩这块东西和你遇到的是一样的问题,请问你现在解决了吗
GMT+8, 2025-1-15 20:51 , Processed in 0.056354 second(s), 27 queries , Gzip On.
