查看: 14188|回复: 6
STM32F103ZET6与DAC7512程序
发表于 2017-2-28 16:56:50 | 显示全部楼层 |阅读模式
STM32F103ZET6与DAC7512芯片程序如下:[index]
#include "DAC7512.h"
static void SPI_GPIO_Config(void)
  GPIO_InitTypeDef  GPIO_InitStructure;
        DAC7512_SPI_GPIO_APBxClock_FUN ( DAC7512_SPI_GPIO_CLK, ENABLE );
        DAC7512_SPI_APBxClock_FUN ( DAC7512_SPI_CLK, ENABLE );
  GPIO_InitStructure.GPIO_Pin   = DAC7512_SPI_SCK_PIN;
  GPIO_InitStructure.GPIO_Mode  = GPIO_Mode_AF_PP;
  GPIO_Init(DAC7512_SPI_SCK_PORT, &GPIO_InitStructure);
  GPIO_InitStructure.GPIO_Pin   = DAC7512_SPI_MOSI_PIN;
  GPIO_Init(DAC7512_SPI_MOSI_PORT, &GPIO_InitStructure);
  GPIO_InitStructure.GPIO_Pin   = DAC7512_SPI_CS_PIN;
  GPIO_InitStructure.GPIO_Mode  = GPIO_Mode_Out_PP;
  GPIO_Init(DAC7512_SPI_CS_PORT, &GPIO_InitStructure);
//        DAC7512_SPI_CS_HIGH;
static void SPI_Mode_Config(void)
SPI_InitTypeDef  SPI_InitStructure;
        SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_2 ;
        SPI_InitStructure.SPI_CPHA = SPI_CPHA_2Edge ;
        SPI_InitStructure.SPI_CPOL = SPI_CPOL_Low ;
        SPI_InitStructure.SPI_CRCPolynomial = 0;
        SPI_InitStructure.SPI_DataSize = SPI_DataSize_16b;
        SPI_InitStructure.SPI_Direction = SPI_Direction_1Line_Tx;
        SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB;
        SPI_InitStructure.SPI_Mode = SPI_Mode_Master;
        SPI_InitStructure.SPI_NSS = SPI_NSS_Soft;
        SPI_Init(DAC7512_SPIx,&SPI_InitStructure);
        SPI_Cmd(DAC7512_SPIx,ENABLE);
void SPI_DAC7512_Init(void)
        SPI_GPIO_Config();
        SPI_Mode_Config();
static void SPI_DAC7512_Send_Byte(uint16_t data)
        while(SPI_I2S_GetFlagStatus(DAC7512_SPIx,SPI_I2S_FLAG_TXE) == RESET)
        SPI_I2S_SendData (DAC7512_SPIx,data);
void SPI_Write_Enable(uint16_t data)
                //片选使能
        DAC7512_SPI_CS_LOW;
        SPI_DAC7512_Send_Byte(data);
//        DAC7512_SPI_CS_HIGH        ;
大家看看这个程序有什么问题啊?SPI片选信号必须高电平,不然输出电压立马归零了
发表于 2017-2-28 18:55:59 | 显示全部楼层
没有用过这芯片,帮顶
 楼主| 发表于 2017-3-1 09:35:19 | 显示全部楼层
谁能帮忙看看这个芯片的datasheet,这程序写了,有输出,但是只输出一会就没了
发表于 2017-3-7 14:05:28 | 显示全部楼层
DA芯片时序不对
 楼主| 发表于 2017-3-8 08:43:40 | 显示全部楼层
嗯,这是最早的程序,后来我改了一下,但是时序时序是对的,但是芯片还是没有输出!#include "DAC7512.h"
        DAC7512_SPI_GPIO_APBxClock_FUN (DAC7512_SPI_GPIO_CLK,ENABLE);
        GPIO_Init(DAC7512_SPI_CS_PORT,&GPIO_InitStructure);
        GPIO_Init(DAC7512_SPI_SCK_PORT,&GPIO_InitStructure);
        GPIO_Init(DAC7512_SPI_MOSI_PORT,&GPIO_InitStructure);
        DAC7512_SPI_APBxClock_FUN(DAC7512_SPI_CLK,ENABLE);
        SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_16;
        SPI_InitStructure.SPI_CPOL = SPI_CPOL_High ;
        SPI_GPIO_Config();
        SPI_Mode_Config();
        while(SPI_I2S_GetFlagStatus(DAC7512_SPIx,SPI_I2S_FLAG_TXE) == RESET);
        SPI_I2S_SendData(DAC7512_SPIx,data);
void Delay(uint8_t s)
        uint8_t i = 0;
        for(i=0;i<s;i++)
                __NOP();
#include "stm32f10x.h"
uint16_t data1 = 0x00ff;
        SPI_DAC7512_Init();
                DAC7512_SPI_CS_LOW;
                SPI_DAC7512_Send_Byte(data1);
                Delay(60);
可以再帮我看看嘛?这个程序的时序是对的,但是芯片就是没有输出
发表于 2017-3-8 13:39:43 | 显示全部楼层
算命先生 发表于 2017-3-8 08:43
嗯,这是最早的程序,后来我改了一下,但是时序时序是对的,但是芯片还是没有输出!#include "DAC7512.h" ...
你六个联系方式 方便交流 这样实时性太差了
 楼主| 发表于 2017-3-8 14:20:53 | 显示全部楼层
193174872,这是QQ
GMT+8, 2025-1-15 12:46 , Processed in 0.030841 second(s), 23 queries , Gzip On.
