查看: 11397|回复: 2
ov7725带FIFO从STM32移植到K60读不出引脚的数据
发表于 2017-3-6 17:31:15 | 显示全部楼层 |阅读模式
ov7725带FIFO从STM32移植到K60读不出引脚的数据。。。我测试了,我的读数据的函数是没问题的,,上拉下拉也都试了,,有没有大神可以帮帮忙了,弄了好几天了
这个是我调试时的数据,,,第一次读的时候有数据,然后就一直是这个了
就第一次读的时候有数据,,,然后一直是这个,,,
  1. for(i = 0; i < width; i++)
  2.         {
  3.                 for(j = 0; j < height; j++)
  4.                 {
  5.                         READ_FIFO_PIXEL(Camera_Data);                /* 从FIFO读出一个RGB565像素到Camera_Data变量 */
  6.                     ili9320_write_pixel( i,  j,Camera_Data );
  7.                 }
  8.         }
  1. #define READ_FIFO_PIXEL(RGB565)            do{\
  2.                                           RGB565=0;\
  3.                                           FIFO_RCLK_L();\
  4.                                           RGB565 = ((GPIO_InstanceTable[OV7725_DATA_GPIO_PORT]->PDIR)) & 0xff00;\
  5.                                           FIFO_RCLK_H();\
  6.                                       FIFO_RCLK_L();\
  7.                                           RGB565 |=((GPIO_InstanceTable[OV7725_DATA_GPIO_PORT]->PDIR)>>8) & 0x00ff;\
  8.                                           FIFO_RCLK_H();\
  9.                                     }while(0)
  1. #define FIFO_OE_H()     GPIO_WriteBit(OV7725_OE_GPIO_PORT, OV7725_OE_GPIO_PIN,1)
  2. #define FIFO_OE_L()     GPIO_WriteBit(OV7725_OE_GPIO_PORT, OV7725_OE_GPIO_PIN,0)
  3. #define FIFO_WRST_H()   GPIO_WriteBit(OV7725_WRST_GPIO_PORT, OV7725_WRST_GPIO_PIN,1)
  4. #define FIFO_WRST_L()   GPIO_WriteBit(OV7725_WRST_GPIO_PORT, OV7725_WRST_GPIO_PIN,0)
  5. #define FIFO_RRST_H()   GPIO_WriteBit(OV7725_RRST_GPIO_PORT, OV7725_RRST_GPIO_PIN,1)
  6. #define FIFO_RRST_L()   GPIO_WriteBit(OV7725_RRST_GPIO_PORT, OV7725_RRST_GPIO_PIN,0)
  7. #define FIFO_RCLK_H()   GPIO_WriteBit(OV7725_RCLK_GPIO_PORT, OV7725_RCLK_GPIO_PIN,1)
  8. #define FIFO_RCLK_L()   GPIO_WriteBit(OV7725_RCLK_GPIO_PORT, OV7725_RCLK_GPIO_PIN,0)
  9. #define FIFO_WE_H()     GPIO_WriteBit(OV7725_WE_GPIO_PORT, OV7725_WE_GPIO_PIN,1)
  10. #define FIFO_WE_L()     GPIO_WriteBit(OV7725_WE_GPIO_PORT, OV7725_WE_GPIO_PIN,0)
发表于 2017-3-6 18:09:14 | 显示全部楼层
就是直接读IO口的
 楼主| 发表于 2017-3-6 18:13:58 | 显示全部楼层
随风 发表于 2017-3-6 18:09
就是直接读IO口的
什么意思,,,没懂
GMT+8, 2025-4-9 16:58 , Processed in 0.124153 second(s), 28 queries , Gzip On.
