查看: 13232|回复: 3
USART读取传感器数据
发表于 2017-3-8 21:20:48 | 显示全部楼层 |阅读模式
项目需要使用USART读取CO2传感器的数据传到上位机,我先写了USART3与电脑的通信程序,没有用printf函数,接收和发送字符串都很正常,但是将主程序改成和传感器连接,程序就无法进入中断了,希望大家帮忙看一下程序有没有问题?(注:传感器本身是正常的)
附上代码:
void DEBUG_USART_IRQHandler(void)//中断处理函数
ReceiveBit3=1;
if(USART_GetITStatus(DEBUG_USART,USART_IT_RXNE)!=RESET)
  ReceiveBit3=1;
  USART_ITConfig(DEBUG_USART, USART_IT_RXNE, DISABLE);
  temp_str[RecCount]=(char)USART_ReceiveData(DEBUG_USART);//接收到的字符存入一个全局变量
  RecCount++;
  //if(RecCount==6)
   //ReceiveBit3=1;
  USART_ITConfig(DEBUG_USART, USART_IT_RXNE, ENABLE);
#include "./usart/bsp_debug_usart.h"
uint8_t ReceiveBit3;
char temp_ch;
char temp_str[7];
uint8_t RecCount;
static void NVIC_Configuration(void)
  NVIC_InitStructure.NVIC_IRQChannel = DEBUG_USART_IRQ;
void Debug_USART_Config(void)
  RCC_AHB1PeriphClockCmd(DEBUG_USART_RX_GPIO_CLK|DEBUG_USART_TX_GPIO_CLK,ENABLE);
  RCC_APB1PeriphClockCmd(DEBUG_USART_CLK, ENABLE);
  GPIO_InitStructure.GPIO_Pin = DEBUG_USART_TX_PIN  ;
  GPIO_Init(DEBUG_USART_TX_GPIO_PORT, &GPIO_InitStructure);
  GPIO_InitStructure.GPIO_Pin = DEBUG_USART_RX_PIN;
  GPIO_Init(DEBUG_USART_RX_GPIO_PORT, &GPIO_InitStructure);
  GPIO_PinAFConfig(DEBUG_USART_RX_GPIO_PORT,DEBUG_USART_RX_SOURCE,DEBUG_USART_RX_AF);
  GPIO_PinAFConfig(DEBUG_USART_TX_GPIO_PORT,DEBUG_USART_TX_SOURCE,DEBUG_USART_TX_AF);
  USART_InitStructure.USART_BaudRate = DEBUG_USART_BAUDRATE;
  USART_Init(DEBUG_USART, &USART_InitStructure);
NVIC_Configuration();
  USART_Cmd(DEBUG_USART, ENABLE);
void Usart_SendByte( USART_TypeDef * pUSARTx, uint8_t ch)
USART_SendData(pUSARTx,ch);
while (USART_GetFlagStatus(pUSARTx, USART_FLAG_TXE) == RESET);
#ifndef __DEBUG_USART_H
#define __DEBUG_USART_H
#include "stm32f4xx.h"
#include <stdio.h>
#define DEBUG_USART                             USART3
#define DEBUG_USART_CLK                         RCC_APB1Periph_USART3
#define DEBUG_USART_BAUDRATE                    9600  //&acute;&reg;&iquest;&Uacute;&sup2;¨&Igrave;&Oslash;&Acirc;&Ecirc;
#define DEBUG_USART_RX_GPIO_PORT                GPIOB
#define DEBUG_USART_RX_GPIO_CLK                 RCC_AHB1Periph_GPIOB
#define DEBUG_USART_RX_PIN                      GPIO_Pin_11
#define DEBUG_USART_RX_AF                       GPIO_AF_USART3
#define DEBUG_USART_RX_SOURCE                   GPIO_PinSource11
#define DEBUG_USART_TX_GPIO_PORT                GPIOB
#define DEBUG_USART_TX_GPIO_CLK                 RCC_AHB1Periph_GPIOB
#define DEBUG_USART_TX_PIN                      GPIO_Pin_10
#define DEBUG_USART_TX_AF                       GPIO_AF_USART2
#define DEBUG_USART_TX_SOURCE                   GPIO_PinSource10
#define DEBUG_USART_IRQHandler                  USART3_IRQHandler
#define DEBUG_USART_IRQ                     USART3_IRQn
extern uint8_t ReceiveBit3;
extern uint8_t RecCount;
extern char temp_ch;
extern char temp_str[7];
//extern  uint8_t SendBit3;
void Debug_USART_Config(void);
void Usart_SendByte( USART_TypeDef * pUSARTx, uint8_t ch);
void Usart_SendString( USART_TypeDef * pUSARTx, char *str);
void Usart_SendHalfWord( USART_TypeDef * pUSARTx, uint16_t ch);
#endif
#include "led.h"
char Humid[3]={0x48,0x0d,0x0a};
void Delay(__IO uint32_t count)
for( ;count!=0;count--)
  Debug_USART_Config();
LED_GPIO_Config();
RecCount=0;
ReceiveBit3=0;//计数位清零
Usart_SendByte(DEBUG_USART,Humid[0]);
Usart_SendByte(DEBUG_USART,Humid[1]);
Usart_SendByte(DEBUG_USART,Humid[2]);//向传感器发送指令,指令没有错误
LED3_TOGGLE;//为了检查LED灯是否可以正常亮起
Delay(0xffff);
  if(temp_str[0]==0x48)//如果受到正确数据,第一个字节是‘H’
   //ReceiveBit3=0;
   //RecCount=0;
   LED1_TOGGLE;
  if(ReceiveBit3==1)//这里设了一个标志位,只要进入中断就会更改,但是LED并没有换颜色,说明没有进中断
   LED2_TOGGLE;
   ReceiveBit3=0;
 楼主| 发表于 2017-3-8 21:21:16 | 显示全部楼层
自顶。。。
 楼主| 发表于 2017-3-8 21:22:39 | 显示全部楼层
还有人说可能是有芯片把串口电平拉低了,不知道挑战者有没有这个问题?求教!
发表于 2017-3-9 09:38:52 | 显示全部楼层
确认下传感器有没有正常运行输出数据
GMT+8, 2025-1-15 12:51 , Processed in 0.029698 second(s), 23 queries , Gzip On.
