查看: 13950|回复: 2
请帮忙教我,谢谢1
发表于 2017-4-2 10:03:10 | 显示全部楼层 |阅读模式
火哥,请问有没有关于void LCD_WriteBMP(uint32_t BmpAddress)这个函数调用的视频或者例程?能够给个信息地址呢使用前是否需要先将图片数组拷贝到内部FLASH中,然后再去调用地址?只有F429核心板的情况下能不能完成调用呢?
请帮忙教我,谢谢
* @brief  Displays a bitmap picture loaded in the internal Flash.
  * @param  BmpAddress: Bmp picture address in the internal Flash.
  * @retval None
  uint32_t index = 0, size = 0, width = 0, height = 0, bit_pixel = 0;
  uint32_t Address;
  uint32_t currentline = 0, linenumber = 0;
  Address = CurrentFrameBuffer;
  /* Read bitmap size */
  size = *(__IO uint16_t *) (BmpAddress + 2);
  size |= (*(__IO uint16_t *) (BmpAddress + 4)) << 16;
  /* Get bitmap data address offset */
  index = *(__IO uint16_t *) (BmpAddress + 10);
  index |= (*(__IO uint16_t *) (BmpAddress + 12)) << 16;
  /* Read bitmap width */
  width = *(uint16_t *) (BmpAddress + 18);
  width |= (*(uint16_t *) (BmpAddress + 20)) << 16;
  /* Read bitmap height */
  height = *(uint16_t *) (BmpAddress + 22);
  height |= (*(uint16_t *) (BmpAddress + 24)) << 16;
  /* Read bit/pixel */
  bit_pixel = *(uint16_t *) (BmpAddress + 28);
  if (CurrentLayer == LCD_BACKGROUND_LAYER)
    /* reconfigure layer size in accordance with the picture */
    LTDC_LayerSize(LTDC_Layer1, width, height);
    LTDC_ReloadConfig(LTDC_VBReload);
    /* Reconfigure the Layer pixel format in accordance with the picture */
    if ((bit_pixel/8) == 4)
      LTDC_LayerPixelFormat(LTDC_Layer1, LTDC_Pixelformat_ARGB8888);
    else if ((bit_pixel/8) == 2)
      LTDC_LayerPixelFormat(LTDC_Layer1, LTDC_Pixelformat_RGB565);
      LTDC_LayerPixelFormat(LTDC_Layer1, LTDC_Pixelformat_RGB888);
    LTDC_LayerSize(LTDC_Layer2, width, height);
      LTDC_LayerPixelFormat(LTDC_Layer2, LTDC_Pixelformat_ARGB8888);
      LTDC_LayerPixelFormat(LTDC_Layer2, LTDC_Pixelformat_RGB565);
      LTDC_LayerPixelFormat(LTDC_Layer2, LTDC_Pixelformat_RGB888);
  /* compute the real size of the picture (without the header)) */
  size = (size - index);
  /* bypass the bitmap header */
  BmpAddress += index;
  /* start copie image from the bottom */
  Address += width*(height-1)*(bit_pixel/8);
  for(index = 0; index < size; index++)
    *(__IO uint8_t*) (Address) = *(__IO uint8_t *)BmpAddress;
    /*jump on next byte */
    BmpAddress++;
    Address++;
    currentline++;
    if((currentline/(bit_pixel/8)) == width)
      if(linenumber < height)
        linenumber++;
        Address -=(2*width*(bit_pixel/8));
        currentline = 0;
主题推荐
发表于 2017-4-5 08:59:38 | 显示全部楼层
可以,总体思想就是读取显存的内容写入到spi flash
 楼主| 发表于 2017-4-7 12:04:35 | 显示全部楼层
火哥,这个函数是否能调用外部FLASH中的数组?
我的思路
我将一个800*480的24bit图片转为数组后 存到。C文件中,大约5M,刷到外部FLASH中。
通过地址0x68000000+1536*4096 调用数组,void LCD_WriteBMP(uint32_t BmpAddress)实现图片显示
是否可以实现呢?
新手,还请不吝赐教
GMT+8, 2025-1-15 21:59 , Processed in 0.029705 second(s), 23 queries , Gzip On.
