查看: 18314|回复: 3
触摸校准。
发表于 2017-4-6 17:31:09 | 显示全部楼层 |阅读模式
我想在自己画的板子上想实现触摸屏功能,SPI模拟时序和LCD驱动都跟着视频写好了,实验时按触摸屏的现象也有了(LED亮了)。
但是我画的板子没有外置FLASH,我删除了SPI_FLASH的外设驱动,中文字模都改成了英文字符串。但是发现那个触摸校准标志貌似也存在FLASH内,不知道该怎么继续修改了。
发表于 2017-4-6 18:28:44 | 显示全部楼层
可以直接存储在内存里,每次上电都校准
 楼主| 发表于 2017-4-8 22:00:21 | 显示全部楼层
flyleaf 发表于 2017-4-6 18:28
可以直接存储在内存里,每次上电都校准
/******************************* XPT2046 触摸屏中断引脚定义 ***************************/
#define             macXPT2046_EXTI_GPIO_CLK                        RCC_APB2Periph_GPIOB
#define             macXPT2046_EXTI_GPIO_PORT                       GPIOB
#define             macXPT2046_EXTI_GPIO_PIN                        GPIO_Pin_6
#define             macXPT2046_EXTI_SOURCE_PORT                     GPIO_PortSourceGPIOB
#define             macXPT2046_EXTI_SOURCE_PIN                      GPIO_PinSource6
#define             macXPT2046_EXTI_LINE                            EXTI_Line6
#define             macXPT2046_EXTI_IRQ                             EXTI9_5_IRQn
#define             macXPT2046_EXTI_INT_FUNCTION                    EXTI9_5_IRQHandler
#define             macXPT2046_EXTI_ActiveLevel                     0
#define             macXPT2046_EXTI_Read()                          GPIO_ReadInputDataBit ( macXPT2046_EXTI_GPIO_PORT, macXPT2046_EXTI_GPIO_PIN )
/******************************* XPT2046 触摸屏模拟SPI引脚定义 ***************************/
#define             macXPT2046_SPI_GPIO_CLK                         RCC_APB2Periph_GPIOD| RCC_APB2Periph_GPIOB
#define             macXPT2046_SPI_CS_PIN                                        GPIO_Pin_7
#define             macXPT2046_SPI_CS_PORT                                      GPIOB
#define                    macXPT2046_SPI_CLK_PIN                                GPIO_Pin_2
#define             macXPT2046_SPI_CLK_PORT                                GPIOD
#define                    macXPT2046_SPI_MOSI_PIN                                GPIO_Pin_3
#define                    macXPT2046_SPI_MOSI_PORT                              GPIOD
#define                    macXPT2046_SPI_MISO_PIN                                GPIO_Pin_6
#define                    macXPT2046_SPI_MISO_PORT                              GPIOD
#define             macXPT2046_CS_ENABLE()                          GPIO_SetBits ( macXPT2046_SPI_CS_PORT, macXPT2046_SPI_CS_PIN )
#define             macXPT2046_CS_DISABLE()                         GPIO_ResetBits ( macXPT2046_SPI_CS_PORT, macXPT2046_SPI_CS_PIN )
#define             macXPT2046_CLK_HIGH()                           GPIO_SetBits ( macXPT2046_SPI_CLK_PORT, macXPT2046_SPI_CLK_PIN )
#define             macXPT2046_CLK_LOW()                            GPIO_ResetBits ( macXPT2046_SPI_CLK_PORT, macXPT2046_SPI_CLK_PIN )
#define             macXPT2046_MOSI_1()                             GPIO_SetBits ( macXPT2046_SPI_MOSI_PORT, macXPT2046_SPI_MOSI_PIN )
#define             macXPT2046_MOSI_0()                             GPIO_ResetBits ( macXPT2046_SPI_MOSI_PORT, macXPT2046_SPI_MOSI_PIN )
#define             macXPT2046_MISO()                               GPIO_ReadInputDataBit ( macXPT2046_SPI_MISO_PORT, macXPT2046_SPI_MISO_PIN )
/***********************stm32f10x_it.c********************************/
// EXTI Line --> PF9 ->PB6
void macXPT2046_EXTI_INT_FUNCTION ( void )
  if ( EXTI_GetITStatus ( macXPT2046_EXTI_LINE ) != RESET )
    ucXPT2046_TouchFlag = 1;
    EXTI_ClearITPendingBit ( macXPT2046_EXTI_LINE );
请问下 我把MINI的程序中断源从 PF9改成了 我自己画的板子上的PB6  怎么不能触发中断触摸了呢?
之前用PB6低电平检测时触摸成功过,但是校准不了。
我换了这个有中断的程序,怎么不能触发中断了呢?
发表于 2017-4-10 09:02:49 | 显示全部楼层
看看源代码里是不是有些地方我们的代码没有设置成宏来改,例如AFIO
GMT+8, 2025-12-15 00:29 , Processed in 0.041217 second(s), 24 queries , Gzip On.
