查看: 12286|回复: 3
跟教程一样.但定义了结构体,不能用->
发表于 2017-4-8 23:04:25 | 显示全部楼层 |阅读模式
*新建工程模板--寄存器版本去
#include "stm32f4xx.h"
/*peripheral 外设*/
#define PERIPH_BASE       ((unsigned int)0x40000000)
#define AHB1PERIPH_BASE         (PERIPH_BASE+0x00020000)
#define GPIOH_BASE                                 (AHB1PERIPH_BASE+0x00001c00)
#define GPIOA_BASE                                (AHB1PERIPH_BASE+0x00000000)
#define GPIOH_MODE                  *(unsigned int *)(GPIOH_BASE+0x00)
#define GPIOH_OTYPER          *(unsigned int *)(GPIOH_BASE+0x04)
#define GPIOH_OSPEEDR         *(unsigned int *)(GPIOH_BASE+0x08)
#define GPIOH_PUPDR           *(unsigned int *)(GPIOH_BASE+0x0c)
#define GPIOH_IDR                          *(unsigned int *)(GPIOH_BASE+0x10)
#define GPIOH_ODR                                                 *(unsigned int *)(GPIOH_BASE+0x14)
#define GPIOH_BSRR                  *(unsigned int *)(GPIOH_BASE+0x18)
#define GPIOH_LCKR            *(unsigned int *)(GPIOH_BASE+0x1c)
#define GPIOH_AFRL                         *(unsigned int *)(GPIOH_BASE+0x20)
#define GPIOH_AFRH                         *(unsigned int *)(GPIOH_BASE+0x24)
typedef unsigned int   u32;
typedef unsigned short u16;
typedef struct
                u32 MODE;
                u32 OTYPER;
          u32 OSPEEDR;
                u32 PUPDR;
                u32 IDR;
                u32 ODR;
                u16 BSRRL;
                u16 BSRRH;
                u32 LCKR;
                u32 AFR[2];
}GPIO_TypeDef;
#define GPIOH                                                        ((GPIO_TypeDef *)GPIOH_BASE)  //把GPIO强制转换成指针
#define GPIOA                                                        ((GPIO_TypeDef *)GPIOA_BASE)  //把GPIO强制转换成指针
#define RCC_BASE          (AHB1PERIPH_BASE+0x3800)
#define RCC_AHB1RSTR                        *(unsigned int *)(RCC_BASE+0x30)
#if 1
/*使用寄存器结构体指针的方式来操作GPIO*/
                /*打开时钟*/
                RCC_AHB1RSTR |=(1<<7);
          /*PH10先清零,再设置输出*/
          GPIOH->MODE &=~(3<<(2*10));
                GPIOH->MODE |= (1<<(2*10));
                /*设置PH10为推挽输出*/
                GPIOH->OTYPER &=~(1<<10);
                /*设置PH10输出速度*/
                GPIOH->OSPEEDR &=~(3<<(2*10));
                GPIOH->OSPEEDR |= (2<<(2*10));
          /*PH10输出低电平*/
                GPIOH->ODR &=~(1<<10);
                while(1);
#else
int main()
                /*打开时钟*/
                RCC_AHB1RSTR |=1<<7;
          /*PH10先清零,再设置输出*/
          GPIOH_MODE &=~(3<<(2*10));
                GPIOH_MODE |= (1<<(2*10));
                /*设置PH10为推挽输出*/
                GPIOH_OTYPER &=~(1<<10);
                /*设置PH10输出速度*/
                GPIOH_OSPEEDR &=~(3<<(2*10));
                GPIOH_OSPEEDR |= (2<<(2*10));
          /*PH10输出低电平*/
                GPIOH_ODR &=~(1<<10);
                while(1);
#endif
/*函数为空,目的是为了骗过编译器不报错*/
void SystemInit(void)
*** Using Compiler 'V5.05 update 2 (build 169)', folder: 'F:\keil5\ARM\ARMCC\Bin'
Build target 'Target 1'
compiling main.c...
main.c(56): error:  #7: unrecognized token
main.c(56): error:  #29: expected an expression
main.c(57): error:  #7: unrecognized token
main.c(57): error:  #29: expected an expression
main.c(60): error:  #7: unrecognized token
main.c(60): error:  #29: expected an expression
main.c(63): error:  #7: unrecognized token
main.c(63): error:  #29: expected an expression
main.c(64): error:  #7: unrecognized token
main.c(64): error:  #29: expected an expression
main.c(67): error:  #7: unrecognized token
main.c(67): error:  #29: expected an expression
main.c: 0 warnings, 12 errors
".\Output\LED-REG.axf" - 12 Error(s), 0 Warning(s).
Target not created.
Build Time Elapsed:  00:00:00
 楼主| 发表于 2017-4-8 23:55:09 | 显示全部楼层
好吧!问题解决了。#define  GPIOH                ((GPIO_TypeDef *)GPIOH_BASE) 宏定义的时候有一个括号打成中文格式了     它为什么不报错格式问题啊
发表于 2017-4-10 11:12:35 | 显示全部楼层
GT123 发表于 2017-4-8 23:55
好吧!问题解决了。#define  GPIOH                ((GPIO_TypeDef *)GPIOH_BASE) 宏定义的时候有一个括号打成中文格式了  ...
编译器的这句就是提示:main.c(67): error:  #29: expected an expression
 楼主| 发表于 2017-4-15 20:45:29 | 显示全部楼层
GMT+8, 2024-11-24 13:25 , Processed in 0.027733 second(s), 23 queries , Gzip On.
