大学生
最后登录1970-1-1
在线时间 小时
注册时间2016-3-24
#include "./adc/bsp_adc.h"
__IO uint16_t ADC_ConvertedValue;
static void Rheostat_ADC_GPIO_Config(void)
RCC_AHB1PeriphClockCmd(RHEOSTAT_ADC_GPIO_CLK, ENABLE);
GPIO_InitStructure.GPIO_Pin = RHEOSTAT_ADC_GPIO_PIN;
GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL ;
GPIO_Init(RHEOSTAT_ADC_GPIO_PORT, &GPIO_InitStructure);
static void Rheostat_ADC_Mode_Config(void)
ADC_CommonInitTypeDef ADC_CommonInitStructure;
RCC_APB2PeriphClockCmd(RHEOSTAT_ADC_CLK , ENABLE);
RCC_AHB1PeriphClockCmd(RHEOSTAT_ADC_DMA_CLK, ENABLE);
DMA_InitStructure.DMA_PeripheralBaseAddr = RHEOSTAT_ADC_DR_ADDR;
DMA_InitStructure.DMA_Memory0BaseAddr = (u32)&ADC_ConvertedValue;
DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralToMemory;
DMA_InitStructure.DMA_BufferSize = 1;
DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Disable;
DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;
DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;
DMA_InitStructure.DMA_FIFOMode = DMA_FIFOMode_Disable;
DMA_InitStructure.DMA_FIFOThreshold = DMA_FIFOThreshold_HalfFull;
DMA_InitStructure.DMA_MemoryBurst = DMA_MemoryBurst_Single;
DMA_InitStructure.DMA_Channel = RHEOSTAT_ADC_DMA_CHANNEL;
DMA_Init(RHEOSTAT_ADC_DMA_STREAM, &DMA_InitStructure);
DMA_Cmd(RHEOSTAT_ADC_DMA_STREAM, ENABLE);
ADC_CommonInitStructure.ADC_Mode = ADC_Mode_Independent;
ADC_CommonInitStructure.ADC_Prescaler = ADC_Prescaler_Div2;
ADC_CommonInitStructure.ADC_DMAAccessMode = ADC_DMAAccessMode_Disabled;
ADC_CommonInitStructure.ADC_TwoSamplingDelay = ADC_TwoSamplingDelay_5Cycles;
ADC_CommonInit(&ADC_CommonInitStructure);
ADC_InitStructure.ADC_Resolution = ADC_Resolution_12b;
ADC_InitStructure.ADC_ScanConvMode = DISABLE;
ADC_InitStructure.ADC_ContinuousConvMode = DISABLE;
ADC_InitStructure.ADC_ExternalTrigConvEdge = ADC_ExternalTrigConvEdge_Rising;
ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_T2_CC2;
ADC_InitStructure.ADC_NbrOfConversion = 1;
ADC_Init(RHEOSTAT_ADC, &ADC_InitStructure);
ADC_RegularChannelConfig(RHEOSTAT_ADC, RHEOSTAT_ADC_CHANNEL, 1, ADC_SampleTime_3Cycles);
ADC_DMARequestAfterLastTransferCmd(RHEOSTAT_ADC, ENABLE);
ADC_DMACmd(RHEOSTAT_ADC, ENABLE);
ADC_Cmd(RHEOSTAT_ADC, ENABLE);
void TIM2_CH2_Config(void)
TIM_TimeBaseInitTypeDef TIM_TimeBaseInitStructure;
TIM_OCInitTypeDef TIM_OCInitStructure;
RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2, ENABLE);
TIM_TimeBaseInitStructure.TIM_ClockDivision = 0x0;
TIM_TimeBaseInitStructure.TIM_CounterMode = TIM_CounterMode_Up;
TIM_TimeBaseInitStructure.TIM_Period = 9999;
TIM_TimeBaseInitStructure.TIM_Prescaler = 0;
TIM_TimeBaseInit(TIM2,&TIM_TimeBaseInitStructure);
TIM_OCInitStructure.TIM_OCIdleState = TIM_OutputState_Enable;
TIM_OCInitStructure.TIM_Pulse = 5000;
TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High;
TIM_OC2Init(TIM2,&TIM_OCInitStructure);
TIM_OC2PreloadConfig(TIM2, TIM_OCPreload_Enable);
TIM_Cmd(TIM2,ENABLE);
时钟源我选的是TIM2,配置大概是对的。但采样输出的结果全部是0,请问这是怎么回事?
