查看: 10139|回复: 2
stm32f103 串口通信问题
发表于 2017-5-26 10:59:32 | 显示全部楼层 |阅读模式
我的程序包括短信,打电话,服务器通信都是usart1通讯的,一切正常,现在改到usart2  A2,A3 程序不走,无任何反应,编译也正常,高手指点
void USART2_Config(void)
/* config USART2 clock */
RCC_APB1PeriphClockCmd(RCC_APB1Periph_USART2, ENABLE);
/* USART2 GPIO config */
/* Configure USART2 Tx (PA.02) as alternate function push-pull */
/* Configure USART2 Rx (PA.3) as input floating */
/* USART2 mode config */
USART_InitStructure.USART_BaudRate = 115200;
USART_Init(USART2, &USART_InitStructure);
USART_ITConfig(USART2, USART_IT_RXNE, ENABLE);
USART_Cmd(USART2, ENABLE);
void NVIC_Configuration(void)
/* Configure the NVIC Preemption Priority Bits */
/* Enable the USARTy Interrupt */
NVIC_InitStructure.NVIC_IRQChannel = USART2_IRQn;
* º¯ÊýÃû£ºfputc
* ÃèÊö  £ºÖض¨Ïòc¿âº¯Êýprintfµ½USART2
* ÊäÈë  £ºÎÞ
* Êä³ö  £ºÎÞ
* µ÷Óà £ºÓÉprintfµ÷ÓÃ
int fputc(int ch, FILE *f)
/* ½&laquorintfÄÚÈÝ·¢Íù´®¿Ú */
USART_SendData(USART2, (unsigned char) ch);
while (!(USART2->SR & USART_FLAG_TXE));
return (ch);
发表于 2017-5-26 18:48:04 | 显示全部楼层
中断函数名改了没
 楼主| 发表于 2017-5-27 12:22:53 | 显示全部楼层
flyleaf 发表于 2017-5-26 18:48
中断函数名改了没
}  这个有问题吗,该改的我也改了
GMT+8, 2024-11-23 11:00 , Processed in 0.034530 second(s), 23 queries , Gzip On.
