研究生
最后登录1970-1-1
在线时间 小时
注册时间2015-12-29
STM32F107VCT6 TJA1021接到串口4
实现LIN的主模式
目前LIN依然跑不通,希望有经验的可以给一些指导。
- static void lin_gpio_init(void)
- GPIO_InitTypeDef GPIO_InitStructure;
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC | RCC_APB2Periph_GPIOD, ENABLE);
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
- GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
- GPIO_InitGPIOC&GPIO_InitStructure);
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_11
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2;
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
- GPIO_Init(GPIOD, &GPIO_InitStructure);
- GPIO_SetBits(GPIOD,GPIO_Pin_2);
- static void lin_nvic_init(void)
- NVIC_InitTypeDef NVIC_InitStructure;
- NVIC_PriorityGroupConfig(NVIC_PriorityGroup_0);
- NVIC_InitStructure.NVIC_IRQChannel = UART4_IRQ;
- NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
- NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
- NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
- NVIC_Init(&NVIC_InitStructure);
- static void lin_uart_init(void)
- USART_InitTypeDef USART_InitStructure;
- RCC_APB1PeriphClockCmd(RCC_APB1Periph_UART4, ENABLE);
- USART_InitStructure.USART_BaudRate = 19200;
- USART_InitStructure.USART_WordLength = USART_WordLength_8b;
- USART_InitStructure.USART_StopBits = USART_StopBits_1;
- USART_InitStructure.USART_Parity = USART_Parity_No ;
- USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
- USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;
- USART_Init(macUSARTx, &USART_InitStructure);
- USART_LINBreakDetectLengthConfig(macUSARTx, USART_LINBreakDetectLength_11b);
- USART_LINCmd(UART4,ENABLE);
- USART_ITConfig(UART4, USART_IT_LBD, ENABLE);
- //USART_ITConfig(UART4, USART_IT_RXNE, ENABLE);
- USART_Cmd(UART4, ENABLE);
- void LINInit(void)
- lin_gpio_init();
- lin_nvic_init();
- lin_uart_init();
- void Usart_SendByte( USART_TypeDef * pUSARTx, uint8_t ch )
- /* 发送一个字节数据到USART1 */
- USART_SendData(pUSARTx, ch);
- /* 等待发送完毕 */
- while (USART_GetFlagStatus(pUSARTx, USART_FLAG_TXE) == RESET);
- static unsigned char LINCalcParity(unsigned char id)
- unsigned char parity, p0, p1;
- parity = id;
- p0 = (BIT(parity, 0)^BIT(parity, 1)^BIT(parity, 2)^BIT(parity, 4)) << 6; //偶校验位
- p1 = (!(BIT(parity, 1)^BIT(parity, 3)^BIT(parity, 4)^BIT(parity, 5))) << 7; //奇校验位
- parity |= (p0 | p1);
- return parity;
- /* 计算和校验位 */
- static unsigned char LINCalcChecksum(unsigned char *data)
- unsigned int sum = 0;
- unsigned char i;
- for(i = 0; i < 8; i++)
- sum += data[i];
- if(sum & 0xFF00)
- sum = (sum & 0x00FF) + 1;
- sum ^= 0x00FF;
- return (unsigned char)sum;
- #if 0
- msg_send.identifier = 0x30;
- msg_send.data[0] = 'F';
- msg_send.data[1] = 'R';
- msg_send.data[2] = 'E';
- msg_send.data[3] = 'E';
- msg_send.data[4] = 'F';
- msg_send.data[5] = 'L';
- msg_send.data[6] = 'Y';
- msg_send.data[7] = '!';
- #endif
- void LINSendTest(void)
- unsigned char check_sum, parity_id, i;
- USART_SendBreak(UART4);
- Usart_SendByte(UART4, 0x55);
- parity_id = LINCalcParity(msg_send.identifier);
- LINSendChar(parity_id);
- if(!LINSendChar(msg_send.data[i]))
- return(FALSE);
- check_sum = LINCalcChecksum(msg_send.data);
- // 发送校验和场
- LINSendChar(check_sum);
