查看: 10805|回复: 2
自己写的串口通讯为什么一直收到的是00,求大神帮忙
发表于 2017-7-16 18:44:02 | 显示全部楼层 |阅读模式
主函数#include "stm32f10x.h"
#include "main.h"
uint16_t Data[8]={0x01,0x03,0x02,0x05,0x07,0x04,0x44,0x09};
uint16_t cout=0,USART_RX_COUNT=0;
  uint16_t i;
  USART1_Config();
  while (1)
    if(cout==0)
       GPIO_SetBits(GPIOC,GPIO_Pin_10);
       cout=1;
    for(i=0;i<8;i++)
      UART1SendByte(Data);
    while (USART_GetFlagStatus(USART1,USART_FLAG_TC) !=SET);
    USART_SendData(USART1, Data);
    LED_Delay(1000);
      LED_Delay(12000);
     GPIO_ResetBits(GPIOC,GPIO_Pin_11);   /
USART配置
#include "bsp_usart.h"
#include "stm32f10x_usart.h"
void USART1_Config(void)
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1 , ENABLE);
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC, ENABLE);
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_11;
   USART_InitStructure.USART_BaudRate = 115200;
    USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None; //硬件流控制模式设置
    USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx; //接收和发送使能
    USART_Init(USART1, &USART_InitStructure);
    NVIC_Config_USART1(); //中断配置
    USART_ClearFlag(USART1, USART_FLAG_TC);//防止第一个数据被覆盖
    USART_ITConfig(USART1, USART_IT_RXNE, ENABLE);  //接收中断使能
    USART_Cmd(USART1, ENABLE); //使能
static void NVIC_Config_USART1(void)
   NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQn;
void UART1SendByte(uint16_t SendData)
        USART_SendData(USART1,SendData);
        while(USART_GetFlagStatus(USART1, USART_FLAG_TXE) == RESET);
unsigned char UART1GetByte(unsigned char* GetData)
        if(USART_GetFlagStatus(USART1, USART_FLAG_RXNE) == RESET)
        {  return 0;
        *GetData = USART_ReceiveData(USART1);
        return 1;
 楼主| 发表于 2017-7-16 18:45:10 | 显示全部楼层
自己分析了一下,返回数据为00,是因为unsigned char UART1GetByte(unsigned char* GetData)
        {  return 0;
        return 1;
这个函数没有被调用,但是调用数据不知道怎么写,新手不太明白,望大神指教一下。
 楼主| 发表于 2017-7-16 20:01:33 | 显示全部楼层
顶一下,大神帮忙看下
GMT+8, 2024-11-23 16:35 , Processed in 0.074340 second(s), 24 queries , Gzip On.
