查看: 11351|回复: 3
使用f103的I2C外设,不使能使用,即不用I2C_Cmd也可以?为什么啊?
发表于 2017-7-25 17:10:14 | 显示全部楼层 |阅读模式
main.c
#include "stm32f10x.h"
#include "bsp_usart.h"
#include "bsp_i2c.h"
        uint8_t readData[20]={0};
        uint8_t writeData[8]={4,5,6,7,8,9,10,11};
        uint8_t i=0;
        USART_Config();
  I2C_EE_Config();
        //发送一个字符串
        printf("这是一个I2C通讯实验\n");
        //写入一串数据
        EEPROM_Page_Write(0,writeData,8);
        //等待写入操作完成
  EEPROM_WaitForWriteEnd();
        //读取数据
        EEPROM_Read(0,readData,8);
        for(i=0;i<8;i++)
           printf("%d ",readData);  //%x为16进制输出
        printf("\n");
bsp_i2c.c
void I2C_EE_Config(void)
        GPIO_InitTypeDef   GPIO_InitStructure;
        I2C_InitTypeDef   I2C_InitStructure;
        //打开IIC GPIO的时钟
        EEPROM_I2C_GPIO_APBxClkCmd(EEPROM_I2C_SCL_GPIO_CLK,ENABLE);
        //打开IIC外设的时钟
        EEPROM_I2C_APBxClkCmd(EEPROM_I2C_CLK,ENABLE);
        //将I2C的GPIO配置为推挽复用模式
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_OD;
        GPIO_InitStructure.GPIO_Pin = EEPROM_I2C_SCL_GPIO_PIN;
        GPIO_Init(EEPROM_I2C_SCL_GPIO_PORT ,&GPIO_InitStructure);
        GPIO_InitStructure.GPIO_Pin = EEPROM_I2C_SDA_GPIO_PIN;
        //配置I2C的工作参数
        I2C_InitStructure.I2C_Ack = I2C_Ack_Enable;//使能应答
        I2C_InitStructure.I2C_AcknowledgedAddress = I2C_AcknowledgedAddress_7bit;
        I2C_InitStructure.I2C_ClockSpeed = EEPROM_I2_BAUDRATE;
        I2C_InitStructure.I2C_DutyCycle = I2C_DutyCycle_2;
        I2C_InitStructure.I2C_Mode = I2C_Mode_I2C;
        I2C_InitStructure.I2C_OwnAddress1 = STM32_I2C_OWN_ADDR;
        I2C_Init(EEPROM_I2C,&I2C_InitStructure);
        //I2C_Cmd(EEPROM_I2C,ENABLE);
//从EEPROM读取数据
void EEPROM_Read(uint8_t addr,uint8_t *data,uint8_t numByteToRead)
        //产生起始信号
        I2C_GenerateSTART(EEPROM_I2C, ENABLE);
        while(I2C_CheckEvent(EEPROM_I2C, I2C_EVENT_MASTER_MODE_SELECT) != SUCCESS);
        //EV5事件被检测到,发送设备地址
        I2C_Send7bitAddress(EEPROM_I2C, EEPROM_ADDR,I2C_Direction_Transmitter);
        while(I2C_CheckEvent(EEPROM_I2C, I2C_EVENT_MASTER_TRANSMITTER_MODE_SELECTED) != SUCCESS);
  //EV6事件被检测到,发送要操作的存储单元地址
        I2C_SendData(EEPROM_I2C, addr);
        while(I2C_CheckEvent(EEPROM_I2C, I2C_EVENT_MASTER_BYTE_TRANSMITTING) != SUCCESS);
        //第二次起始信号
        //产生起始信号
        //EV5事件被检测到,发送设备地址
        I2C_Send7bitAddress(EEPROM_I2C, EEPROM_ADDR,I2C_Direction_Receiver);
        while(I2C_CheckEvent(EEPROM_I2C, I2C_EVENT_MASTER_RECEIVER_MODE_SELECTED) != SUCCESS);
        while(numByteToRead)
         if(numByteToRead==1)
         //如果为最后一个字节
         I2C_AcknowledgeConfig(EEPROM_I2C, DISABLE);
         //EV7事件被检测到
         while(I2C_CheckEvent(EEPROM_I2C, I2C_EVENT_MASTER_BYTE_RECEIVED) != SUCCESS);
  //EV7事件被检测到,即数据寄存器有新的有效数据
        *data=I2C_ReceiveData(EEPROM_I2C);
        data++;
         numByteToRead--;
        //数据传输完成
        I2C_GenerateSTOP(EEPROM_I2C, ENABLE);
        //重新配置ACK使能,以便下次通讯
        I2C_AcknowledgeConfig(EEPROM_I2C, ENABLE);
//等待EEPROM内部时序完成
void EEPROM_WaitForWriteEnd(void)
        do{
        //产生起始信号
        while(I2C_GetFlagStatus(EEPROM_I2C,I2C_FLAG_SB) != SET);
        //EV5事件被检测到,发送设备地址
        while(I2C_GetFlagStatus(EEPROM_I2C, I2C_FLAG_ADDR) != SET);
        //内部时序完成
//向EEPROM写入多个字节(页写入),小于八个字节
void EEPROM_Page_Write(uint8_t addr,uint8_t *data,uint8_t numByteToWrite)
        //产生起始信号
        //EV5事件被检测到,发送设备地址
        //while(I2C_CheckEvent(EEPROM_I2C, I2C_EVENT_MASTER_BYTE_TRANSMITTING) != SUCCESS);
         while(numByteToWrite)
                 //EV8事件被检测到,发送要存储的数据
           I2C_SendData(EEPROM_I2C, *data);
           //while(I2C_CheckEvent(EEPROM_I2C,I2C_EVENT_MASTER_BYTE_TRANSMITTED) != SUCCESS);
                 data++;
                 numByteToWrite--;
         //数据传输完成
发表于 2017-7-25 17:20:09 | 显示全部楼层
看看有没有在其它地方使能,确实没有的话那就说明这样确实可以了
 楼主| 发表于 2017-7-25 19:35:00 | 显示全部楼层
如果我写成I2C_Cmd(EEPROM_I2C,DISABLE);就不能了,然后把那条语句删了还是可以,所以我觉得是默认使能的。
发表于 2017-7-26 09:35:06 | 显示全部楼层
嗯,实践出真知
GMT+8, 2024-11-28 14:52 , Processed in 0.029698 second(s), 24 queries , Gzip On.
