小学生
最后登录1970-1-1
在线时间 小时
注册时间2017-7-15
大家好! 我用开发板上的BSP_RTC例程,操作RTC:
1、例程 里面 RTC的时钟源 选择的是内部时钟源吗?
2、怎么选择外部 32.768时钟源?
3、我用例程 发现 RTC 在 断电的时候 时钟不跑!但是,开发板上 我插入了 备用电池,而且备用电池的电压也正常。
谢谢!
rtc_time.RTC_Time.RTC_H12=RTC_H12_AM;
rtc_time.RTC_Time.RTC_Hours =11;
rtc_time.RTC_Time.RTC_Minutes =55;
rtc_time.RTC_Time.RTC_Seconds =30;
rtc_time.RTC_Date.RTC_WeekDay =05;
rtc_time.RTC_Date.RTC_Date =16;
rtc_time.RTC_Date.RTC_Month =10;
rtc_time.RTC_Date.RTC_Year =15;
OSSchedLock(&err);
if(RTC_CheckAndConfig(&rtc_time,0)==1) bsp_result |=BSP_RTC;//ʹÓÃÍⲿ¾§ÕñΪRTCʱÖÓÔ´
OSSchedUnlock(&err);
static void Delay(uint16_t time)
uint16_t i;
while(--time)
for(i=0;i<2000;i++);
* @brief Configure the RTC peripheral by selecting the clock source.
* @param None
* @retval None
static uint8_t RTC_Config(uint8_t flag)
uint32_t count=0;
/* Enable the PWR clock */
RCC_APB1PeriphClockCmd(RCC_APB1Periph_PWR, ENABLE);
/* Allow access to RTC */
PWR_BackupAccessCmd(ENABLE);
if(flag==0) /* The RTC Clock may varies due to LSI frequency dispersion. */
/* Enable the LSI OSC */
RCC_LSICmd(ENABLE);
count=0;
/* Wait till LSI is ready */
while(RCC_GetFlagStatus(RCC_FLAG_LSIRDY) == RESET)
Delay(1000);
count++;
if(count>4000)return 1;
/* Select the RTC Clock Source */
RCC_RTCCLKConfig(RCC_RTCCLKSource_LSI);
else /* LSE used as RTC source clock */
/* Enable the LSE OSC */
RCC_LSEConfig(RCC_LSE_ON);
count=0;
/* Wait till LSE is ready */
while(RCC_GetFlagStatus(RCC_FLAG_LSERDY) == RESET)
Delay(100);
count++;
RCC_RTCCLKConfig(RCC_RTCCLKSource_LSE);
/* Enable the RTC Clock */
RCC_RTCCLKCmd(ENABLE);
/* Wait for RTC APB registers synchronisation */
RTC_WaitForSynchro();
return 0;
* @param None
* @retval None
uint8_t RTC_CheckAndConfig(RTC_TIME *rtc_time,uint8_t flag)
RTC_InitTypeDef RTC_InitStructure;
/* RTC configuration */
if(RTC_Config(flag)==1)return 1;
if (RTC_ReadBackupRegister(RTC_BKP_DR0) != 0x32F2)
/* Configure the RTC data register and RTC prescaler */
RTC_InitStructure.RTC_AsynchPrediv = 0x7F;
RTC_InitStructure.RTC_SynchPrediv = 0xFF; /* (32.768kHz / 128) - 1 = 0xFF*/
RTC_InitStructure.RTC_HourFormat = RTC_HourFormat_24;
/* Check on RTC init */
if (RTC_Init(&RTC_InitStructure) == ERROR)
printf("\n\r /!\\***** RTC Prescaler Config failed ********/!\\ \r\n");
/* Configure the time register */
if(RTC_SetTime(RTC_Format_BIN, &rtc_time->RTC_Time) == ERROR)
printf("\r\n>> !! RTC Set Time failed. !! <<\r\n");
return 1;
printf("\r\n>> !! RTC Set Time success. !! <<\r\n");
/* Indicator for the RTC configuration */
RTC_WriteBackupRegister(RTC_BKP_DR0, 0x32F2);
/* Configure the RTC date register */
if(RTC_SetDate(RTC_Format_BIN, &rtc_time->RTC_Date) == ERROR)
printf("\r\n>> !! RTC Set Date failed. !! <<\r\n");
return 1;
printf("\r\n>> !! RTC Set Date success. !! <<\r\n");
/* Check if the Power On Reset flag is set */
if (RCC_GetFlagStatus(RCC_FLAG_PORRST) != RESET)
printf("\r\n Power On Reset occurred....\r\n");
/* Check if the Pin Reset flag is set */
else if (RCC_GetFlagStatus(RCC_FLAG_PINRST) != RESET)
printf("\r\n External Reset occurred....\r\n");
printf("\r\n No need to configure RTC....\r\n");
/* Clear the RTC Alarm Flag */
RTC_ClearFlag(RTC_FLAG_ALRAF);
return 0;
