初中生
最后登录1970-1-1
在线时间 小时
注册时间2017-8-23
include "stm32f10x.h"
#include "./led/bsp_led.h"
#include "./usart/bsp_usart.h"
#include "./flash/bsp_spi_flash.h"
#include <stdlib.h>
#include "sram.h"
#define number 33
/*定义变量到外部SRAM*/
// long double double_buffer[number] __attribute__((section("EXRAM"))) = {0};
// int int_bufffer[number] __attribute__((section("EXRAM"))) = {0};
__IO uint32_t DeviceID = 0;
__IO uint32_t FlashID = 0;
void Delay(__IO uint32_t nCount);
uint8_t cal_flag = 0;
uint8_t k;
/*定义局部变量,如果实验数据太大内存溢出时,可用main函数外的两个变量定义到外部SRAM*/
long double double_buffer[ number] = {0};
int int_bufffer[ number] = {0};
LED_GPIO_Config();
LED_BLUE;
USART_Config();
printf("\r\n这是一个FLASH 读写小数和长整数实验 \r\n");
SPI_FLASH_Init();
/* »ñè¡ Flash Device ID */
DeviceID = SPI_FLASH_ReadDeviceID();
Delay( 200 );
/* »获取 SPI Flash ID */
FlashID = SPI_FLASH_ReadID();
printf("\r\nFlashID is 0x%X, Manufacturer Device ID is 0x%X\r\n", FlashID, DeviceID);
/* 检验 SPI Flash ID */
if (FlashID == sFLASH_ID)
LED_GREEN;
printf("\r\n¼ì2aμ½SPI FLASH W25Q64 !\r\n");
// /*读取数据标志位*/
SPI_FLASH_BufferRead(&cal_flag, SPI_FLASH_PageSize*0, 1);
if( cal_flag == 0xCD ) /*标志位等于0xcd,表示之前已写入数据*/
printf("\r\n检测到数据标志\r\n");
/*读取小数数据*/
SPI_FLASH_BufferRead((void*)double_buffer, SPI_FLASH_PageSize*1, sizeof(double_buffer));
/*读取整数数据*/
SPI_FLASH_BufferRead((void*)int_bufffer, SPI_FLASH_PageSize*2, sizeof(int_bufffer));
printf("\r\n从芯片读到数据\r\n");
for( k=0; k<number; k++ )
printf("小数 rx = %LF \r\n",double_buffer[k]);
printf("整数 rx = %d \r\n",int_bufffer[k]);
printf("\r\n没有检测到数据标志,FLASH没有存储数据,即将进行小数写入实验\r\n");
cal_flag =0xCD;
/*擦除扇区*/
SPI_FLASH_SectorErase(0);
/*写入标志到0页*/
SPI_FLASH_BufferWrite(&cal_flag, SPI_FLASH_PageSize*0, 1);
/*生成要写入的数据*/
double_buffer[k] = k +0.1;
int_bufffer[k]=k*500+1 ;
/*写入小数数据到第一页*/
SPI_FLASH_BufferWrite((void*)double_buffer, SPI_FLASH_PageSize*1, sizeof(double_buffer));
/*写入整数数据到第二页*/
SPI_FLASH_BufferWrite((void*)int_bufffer, SPI_FLASH_PageSize*2, sizeof(int_bufffer));
printf("向芯片写入数据");
/*打印到串口*/
printf("小数tx = %LF\r\n",double_buffer[k]);
printf("整数tx = %d\r\n",int_bufffer[k]);
printf("\r\n请复位开发板,以读取数据进行检验\r\n");
}// if (FlashID == sFLASH_ID)
LED_RED;
printf("\r\n获取不到 W25Q64 ID!\n\r");
// SPI_Flash_PowerDown();
while(1);
for(; nCount != 0; nCount--);
请老师测试
