查看: 10021|回复: 2
外设中断 PC13问题
发表于 2017-10-1 17:23:14 | 显示全部楼层 |阅读模式
问题:编译无错误,下载后灯灭了,按住KEY 2键没有实现翻转
1)中断C程序
#include "Exti_Inter_Pin_0.h"
static void NVIC_Inter(void)
        NVIC_InitTypeDef NVIC_Inter;
        //配置中断优先级
        NVIC_Inter.NVIC_IRQChannel =  EXTI15_10_IRQn ;
        NVIC_Inter.NVIC_IRQChannelCmd = ENABLE;
        NVIC_Inter.NVIC_IRQChannelPreemptionPriority = 0x01;
        NVIC_Inter.NVIC_IRQChannelSubPriority = 0x01;
        NVIC_Init( &NVIC_Inter);
void Exti_Inter_GPIOC_Pin_13(void)
        GPIO_InitTypeDef GPIOC_Pin_13_Inter;
       EXTI_InitTypeDef EXTI_Ini; //中断初始化
        NVIC_Inter();//配置中断优先级分组,属于内核部分
        // 初始化GPIOC_Pin_13引脚
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC, ENABLE);
        GPIOC_Pin_13_Inter.GPIO_Pin = GPIO_Pin_13;
  GPIOC_Pin_13_Inter.GPIO_Mode = GPIO_Mode_IN_FLOATING;
        GPIO_Init( GPIOC, &GPIOC_Pin_13_Inter);
        //初始化EXTI0中断
       GPIO_EXTILineConfig(GPIO_PortSourceGPIOC, GPIO_PinSource13);//先选则初始线
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO, ENABLE);//开启时钟
        EXTI_Ini.EXTI_Line = EXTI_Line13;
        EXTI_Ini.EXTI_LineCmd = ENABLE;
        EXTI_Ini.EXTI_Mode = EXTI_Mode_Interrupt;
        EXTI_Ini.EXTI_Trigger =  EXTI_Trigger_Rising;
        EXTI_Init(&EXTI_Ini);
2)中断头文件
#define TOGGLE              {GPIOB->ODR^=GPIO_Pin_0;}
3)中断函数
void EXTI15_10_IRQHandler (void)
        while( EXTI_GetITStatus( EXTI_Line13)!=1);
         TOGGLE;
        EXTI_ClearITPendingBit(EXTI_Line13);
4)主程序
int main()
     LED_GPIO_PB0_ON();//初始化PB0口
   Exti_Inter_GPIOC_Pin_13();
调试一下午,对照火哥的程序,我用了按键1的PA0口尝试了一下,发现成功了,但是用PC13口却没成功。没找出问题所在,郁闷。请大虾指点
发表于 2017-10-9 10:03:48 | 显示全部楼层
看代码也没看出问题在哪
发表于 2017-10-9 13:56:22 | 显示全部楼层
PC13 PC14 PC15 3个引脚驱动能力不行,手册上有
GMT+8, 2025-1-17 03:05 , Processed in 0.068585 second(s), 23 queries , Gzip On.
