查看: 19258|回复: 2
ucosiii wifi
发表于 2017-11-14 10:45:36 | 显示全部楼层 |阅读模式
火哥,我把wifi程序想用ucosiii来写,为啥在任务体里面就不出来了?没有调用wifi_function.c 里面的函数,任务函数如下:
static  void  AppTask ( void * p_arg )
        OS_ERR      err;
  char cCh;
        (void)p_arg;
        while (DEF_TRUE) {                                            //èÎÎñìå
        PC_Usart("\r\nò°»e WF-ESP8266 WiFiÄ£¿é2aêÔày3ì\r\n");                            //′òó¡2aêÔày3ììáê¾DÅÏ¢
  PC_Usart ( "\r\nÇëêäèëÄ£¿éμÄ2aêÔÄ£ê½μıàoÅ£¬±àoÅèçÏ£o\
              \r\n1.STAģ꽣o TCP Client\
              \r\n2.APģ꽣o AP Server\
              \r\n3.STA+APģ꽣o (STA)TCP Client + (AP)TCP Server\
              \r\nêäèë¸ñê½Îa£o±àoÅ+¿Õ¸ñ£¬μã»÷·¢Ëí\r\n" );
  scanf ( "%c",  & cCh );
  switch ( cCh )
                case '1':
                        pNet_Test = ESP8266_STA_TCP_Client;
                  PC_Usart("\r\n¼′½«½øDDμÄ2aêÔêÇ£o1.STAģ꽣o TCP Client\r\n");
                  break;
                case '2':
                        pNet_Test = ESP8266_AP_TCP_Server;
                  PC_Usart("\r\n¼′½«½øDDμÄ2aêÔêÇ£o2.APģ꽣o TCP Server\r\n");
                  break;
                case '3':
                        pNet_Test = ESP8266_StaTcpClient_ApTcpServer;
                  PC_Usart("\r\n¼′½«½øDDμÄ2aêÔêÇ£o3.STA+APģ꽣o (STA)TCP Client + (AP)TCP Server\r\n");
                  break;
                default:
                        pNet_Test = NULL;
                  PC_Usart("\r\nêäèë′íÎó£¬2»½øDD2aêÔ£¡\r\n");
                  break;
        if ( pNet_Test )
                  pNet_Test ();
        OSTimeDlyHMSM ( 0, 0, 0, 500, OS_OPT_TIME_DLY, & err );     //ÿ¸ô500ms·¢Ëíò»′Π
发表于 2017-11-14 14:40:15 | 显示全部楼层
代码乱码了,
 楼主| 发表于 2017-11-14 17:32:06 | 显示全部楼层
那些是中文字,没关系的
GMT+8, 2025-12-14 22:46 , Processed in 0.040430 second(s), 24 queries , Gzip On.
