查看: 24793|回复: 7
9通道ADC DMA传输错位问题
发表于 2017-12-11 11:07:26 | 显示全部楼层 |阅读模式
20火花
开发环境IAR8.10.1,芯片103VCT6
现象:ADC配置文件已设置只读,原本正常的数据顺序,重新编译后出现错位问题,不管他,过一会编译又正常。
C文件主要内容:
  1. #define ADC1_DR_Address    ((u32)0x40012400+0x4c)
  2. static uint16_t ADC_ConvertedValue[9];
  3. /**
  4. * [ADC1_GPIO_Config description]
  5. */
  6. static void ADC1_GPIO_Config(void)
  7. {
  8.         GPIO_InitTypeDef GPIO_InitStructure;
  9.
  10.         /* Enable ADC1 and GPIOC clock */
  11.         // RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1, ENABLE);
  12.         // RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC2, ENABLE);
  13.         // RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC3, ENABLE);
  14.         RCC_APB2PeriphClockCmd(GPIO_RCCx(JOYSTICK1_X_PIN), ENABLE);
  15.
  16.         GPIO_InitStructure.GPIO_Pin = ADC_PINS;
  17.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AIN;
  18.         GPIO_Init(GPIO_PORTx(JOYSTICK1_X_PIN), &GPIO_InitStructure);
  19.         RCC_APB2PeriphClockCmd(GPIO_RCCx(RS_STICK_PIN), ENABLE);
  20.         GPIO_InitStructure.GPIO_Pin = GPIO_PINx(RS_STICK_PIN) |  GPIO_PINx(RD_STICK_PIN);
  21.         GPIO_Init(GPIO_PORTx(RS_STICK_PIN), &GPIO_InitStructure);
  22.         RCC_APB2PeriphClockCmd(GPIO_RCCx(PWR_ADC_PIN), ENABLE);
  23.         GPIO_InitStructure.GPIO_Pin = GPIO_PINx(PWR_ADC_PIN);
  24.         GPIO_Init(GPIO_PORTx(PWR_ADC_PIN), &GPIO_InitStructure);
  25. }
  26. void adc_dma_init()
  27. {
  28.         DMA_InitTypeDef DMA_InitStructure;
  29.         RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1, ENABLE);
  30.         /* DMA channel1 configuration */
  31.         DMA_DeInit(DMA1_Channel1);
  32.         DMA_InitStructure.DMA_PeripheralBaseAddr = ADC1_DR_Address;         //ADC地址
  33.         DMA_InitStructure.DMA_MemoryBaseAddr = (u32)ADC_ConvertedValue;//内存地址~在这里进行赋值
  34.         DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC;
  35.         DMA_InitStructure.DMA_BufferSize = 9;
  36.         DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;//外设地址固定
  37.         DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;  //内存地址固定
  38.         DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;        //半字
  39.         DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;
  40.         DMA_InitStructure.DMA_Mode = DMA_Mode_Circular;                //循环传输
  41.         DMA_InitStructure.DMA_Priority = DMA_Priority_High;
  42.         DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;
  43.         DMA_Init(DMA1_Channel1, &DMA_InitStructure);
  44.
  45.         /* Enable DMA channel1 */
  46.         DMA_Cmd(DMA1_Channel1, ENABLE);
  47. }
  48. /* 函数名:ADC1_Mode_Config
  49. * 描述  :配置ADC1的工作模式为MDA模式
  50. * 输入  : 无
  51. * 输出  :无
  52. * 调用  :内部调用
  53. */
  54. static void ADC1_Mode_Config(void)
  55. {
  56.         ADC_InitTypeDef ADC_InitStructure;
  57.
  58.         RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1, ENABLE);
  59.         /* ADC1 configuration */
  60.
  61.         ADC_InitStructure.ADC_Mode = ADC_Mode_Independent;        //独立ADC模式
  62.         ADC_InitStructure.ADC_ScanConvMode = ENABLE ;          //禁止扫描模式,扫描模式用于多通道采集
  63.         ADC_InitStructure.ADC_ContinuousConvMode = ENABLE;        //开启连续转换模式,即不停地进行ADC转换
  64.         ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_None;        //不使用外部触发转换
  65.         ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;         //采集数据右对齐
  66.         ADC_InitStructure.ADC_NbrOfChannel = 9;                 //要转换的通道数目1
  67.         ADC_Init(ADC1, &ADC_InitStructure);
  68.         /*配置ADC时钟,为PCLK2的8分频,即9Hz*/
  69.         RCC_ADCCLKConfig(RCC_PCLK2_Div8);
  70.         /*配置ADC1的通道11为55.        5个采样周期,序列为1 */
  71.         ADC_RegularChannelConfig(ADC1, ADC_Channel_0,  1, ADC_SampleTime_239Cycles5);//PWR_ADC_PIN ADC_SampleTime_239Cycles5
  72.         ADC_RegularChannelConfig(ADC1, ADC_Channel_8,  2, ADC_SampleTime_239Cycles5);//RD_STICK_PIN ADC_SampleTime_55Cycles5
  73.         ADC_RegularChannelConfig(ADC1, ADC_Channel_9,  3, ADC_SampleTime_239Cycles5);//RS_STICK_PIN
  74.         ADC_RegularChannelConfig(ADC1, ADC_Channel_10, 4, ADC_SampleTime_239Cycles5);//JOYSTICK2_X_PIN
  75.         ADC_RegularChannelConfig(ADC1, ADC_Channel_11, 5, ADC_SampleTime_239Cycles5);//JOYSTICK2_Y_PIN
  76.         ADC_RegularChannelConfig(ADC1, ADC_Channel_12, 6, ADC_SampleTime_239Cycles5);//JOYSTICK1_Y_PIN
  77.         ADC_RegularChannelConfig(ADC1, ADC_Channel_13, 7, ADC_SampleTime_239Cycles5);//JOYSTICK1_X_PIN
  78.         ADC_RegularChannelConfig(ADC1, ADC_Channel_14, 8, ADC_SampleTime_239Cycles5);//LD_STICK_PIN
  79.         ADC_RegularChannelConfig(ADC1, ADC_Channel_15, 9, ADC_SampleTime_239Cycles5);//LS_STICK_PIN
  80.         /* Enable ADC1 DMA */
  81.         ADC_DMACmd(ADC1, ENABLE);
  82.
  83.         /* Enable ADC1 */
  84.         ADC_Cmd(ADC1, ENABLE);
  85.
  86.         /*复位校准寄存器 */
  87.         ADC_ResetCalibration(ADC1);
  88.         /*等待校准寄存器复位完成 */
  89.         while(ADC_GetResetCalibrationStatus(ADC1));
  90.
  91.         /* ADC校准 */
  92.         ADC_StartCalibration(ADC1);
  93.         /* 等待校准完成*/
  94.         while(ADC_GetCalibrationStatus(ADC1));
  95.
  96.         /* 由于没有采用外部触发,所以使用软件触发ADC转换 */
  97.         ADC_SoftwareStartConvCmd(ADC1, ENABLE);
  98. }
  99. /*
  100. * 函数名:ADC1_Init
  101. * 描述  :无
  102. * 输入  :无
  103. * 输出  :无
  104. * 调用  :外部调用
  105. */
  106. void ADC1_Init(void)
  107. {
  108.         ADC1_GPIO_Config();
  109.         adc_dma_init();
  110.         ADC1_Mode_Config();
  111. }
  112. u16 adc_single_channel_get(u8 channel)
  113. {
  114.         return ADC_ConvertedValue[channel];
  115. }
  116. void adc_all_channel_get(u16 data[])
  117. {
  118.         data[0] = ADC_ConvertedValue[1];
  119.         data[1] = ADC_ConvertedValue[2];
  120.         data[2] = ADC_ConvertedValue[3];
  121.         data[3] = ADC_ConvertedValue[4];
  122.         data[4] = ADC_ConvertedValue[5];
  123.         data[5] = ADC_ConvertedValue[6];
  124.         data[6] = ADC_ConvertedValue[7];
  125.         data[7] = ADC_ConvertedValue[8];
  126. }
头文件:
  1. typedef enum
  2. {
  3.         PWR_ADC_NUM                        = 0,
  4.         RD_STICK_NUM                = 1,
  5.         RS_STICK_NUM                = 2,
  6.         JOYSTICK2_X_NUM                = 3,
  7.         JOYSTICK2_Y_NUM                = 4,
  8.         JOYSTICK1_Y_NUM                = 5,
  9.         JOYSTICK1_X_NUM                = 6,
  10.         LD_STICK_NUM                = 7,
  11.         LS_STICK_NUM                = 8
  12. }AD_SEQUENCE_NEUM;
  13. void ADC1_Init(void);
  14. u16 adc_single_channel_get(u8 channel);
  15. void adc_all_channel_get(u16 data[]);
基本功能读数没任何问题,但是就是通道顺序错位,各位有遇到么?
最佳答案
查看完整内容
你先使能dma,再启动adc转换这个问题就没有了
发表于 2017-12-11 11:07:27 | 显示全部楼层
发表于 2017-12-11 11:29:40 | 显示全部楼层
你用了ADC1的9个通道,但是你初始化IO口的时候貌似没有9个IO啊?
 楼主| 发表于 2017-12-11 11:37:07 | 显示全部楼层
感谢老大的关注,有的,要不然也不能正常工作,所有通道工作数据没问题
我只是用宏定义集中到一起了,这是详细定义
#define JOYSTICK1_X_PIN            PC_3
#define JOYSTICK1_Y_PIN         PC_2
#define JOYSTICK2_X_PIN         PC_0
#define JOYSTICK2_Y_PIN         PC_1
#define LD_STICK_PIN                PC_4
#define LS_STICK_PIN                PC_5
#define ADC_PINS         (GPIO_PINx(JOYSTICK1_X_PIN)        | \
                                        GPIO_PINx(JOYSTICK1_Y_PIN)        | \
                                        GPIO_PINx(JOYSTICK2_X_PIN)        | \
                                        GPIO_PINx(JOYSTICK2_Y_PIN)        | \
                                        GPIO_PINx(LD_STICK_PIN)                | \
                                        GPIO_PINx(LS_STICK_PIN))
#define PWR_ADC_PIN                 PA_0
#define RD_STICK_PIN                PB_0
#define RS_STICK_PIN                PB_1
发表于 2017-12-11 12:00:33 | 显示全部楼层
我只是用宏定义集中到一起了,这 ...
那这样看不出啥问题啊
 楼主| 发表于 2017-12-11 12:41:18 | 显示全部楼层
fire 发表于 2017-12-11 12:00
那这样看不出啥问题啊
我也是非常纳闷啊,跑的好好的程序,我就点了一下rebuild all,就出问题了。
会不会是编译器,或者芯片问题啊
 楼主| 发表于 2017-12-11 12:41:38 | 显示全部楼层
那这样看不出啥问题啊
要不我把文件传上来
 楼主| 发表于 2018-5-15 12:55:36 | 显示全部楼层
抱歉后来问题解决后,忘记上论坛了,问题确实如你所说,非常感谢
GMT+8, 2024-11-24 02:15 , Processed in 0.030580 second(s), 23 queries , Gzip On.
