查看: 12793|回复: 2
求助DAC +DMA配置失败
发表于 2018-4-20 09:05:16 | 显示全部楼层 |阅读模式
void DAC1_Init(void)
    DAC_ChannelConfTypeDef DACCH1_Config;
    DAC1_Handler.Instance=DAC;
    HAL_DAC_Init(&DAC1_Handler);                 //3õê¼»ˉDAC
    DACCH1_Config.DAC_Trigger=DAC_TRIGGER_T4_TRGO;             //2»ê1óÃ′¥·¢1|Äü
    DACCH1_Config.DAC_OutputBuffer=DAC_OUTPUTBUFFER_DISABLE;//DAC1êä3ö»o3å1رÕ
    HAL_DAC_ConfigChannel(&DAC1_Handler,&DACCH1_Config,DAC_CHANNEL_1);//DACí¨μà1ÅäÖÃ
    HAL_DAC_Start_DMA(&DAC1_Handler,DAC_CHANNEL_1,(u32*)&DAC->DHR12R1,BUFFERSIZE,DAC_ALIGN_12B_R);
//DACμ×2ãÇy¶ˉ£¬ê±ÖóÅäÖã¬òy½Å ÅäÖÃ
//′Ëoˉêy»á±»HAL_DAC_Init()μ÷óÃ
//hdacAC¾ä±ú
void HAL_DAC_MspInit(DAC_HandleTypeDef* hdac)
    GPIO_InitTypeDef GPIO_Initure;
    __HAL_RCC_DAC_CLK_ENABLE();             //ê1ÄüDACê±Öó
    __HAL_RCC_GPIOA_CLK_ENABLE();                        //¿aÆôGPIOAê±Öó
    GPIO_Initure.Pin=GPIO_PIN_4;            //PA4
    GPIO_Initure.Mode=GPIO_MODE_ANALOG;     //Ä£Äa
    GPIO_Initure.Pull=GPIO_NOPULL;          //2»′øéÏÏÂà-
    HAL_GPIO_Init(GPIOA,&GPIO_Initure);
void MYDAC1DMA_Config(void)
    __HAL_RCC_DMA1_CLK_ENABLE();//DMA2ê±Öóê1Äü
    __HAL_LINKDMA(&DAC1_Handler,DMA_Handle1,DAC1DMA_Handler);    //½«DMAóëUSART1áaÏμÆeà′(·¢ËíDMA)
    //Tx DMAÅäÖÃ
    DAC1DMA_Handler.Instance=DMA1_Stream5;                            //êy¾Yá÷Ñ¡Ôñ
    DAC1DMA_Handler.Init.Channel=DMA_CHANNEL_7;                        //í¨μàÑ¡Ôñ
    DAC1DMA_Handler.Init.Direction=DMA_MEMORY_TO_PERIPH;             //′æ′¢Æ÷μ½íaéè
    DAC1DMA_Handler.Init.PeriphInc=DMA_PINC_DISABLE;                 //íaéè·ÇÔöá¿Ä£ê½
    DAC1DMA_Handler.Init.MemInc=DMA_MINC_ENABLE;                     //′æ′¢Æ÷Ôöá¿Ä£ê½
    DAC1DMA_Handler.Init.PeriphDataAlignment=DMA_PDATAALIGN_HALFWORD;    //íaéèêy¾Y3¤¶è:16λ
    DAC1DMA_Handler.Init.MemDataAlignment=DMA_PDATAALIGN_HALFWORD;       //′æ′¢Æ÷êy¾Y3¤¶è:16λ
    DAC1DMA_Handler.Init.Mode=DMA_CIRCULAR;                            //Ñ-»·Ä£ê½
    DAC1DMA_Handler.Init.Priority=DMA_PRIORITY_HIGH;               //¸ßóÅÏ輶
    DAC1DMA_Handler.Init.FIFOMode=DMA_FIFOMODE_DISABLE;
    DAC1DMA_Handler.Init.FIFOThreshold=DMA_FIFO_THRESHOLD_HALFFULL;
    DAC1DMA_Handler.Init.MemBurst=DMA_MBURST_SINGLE;                 //′æ′¢Æ÷í»·¢μ¥′Î′«êä
    DAC1DMA_Handler.Init.PeriphBurst=DMA_PBURST_SINGLE;              //íaéèí»·¢μ¥′Î′«êä
    HAL_DMA_DeInit(&DAC1DMA_Handler);
    HAL_DMA_Init(&DAC1DMA_Handler);
                //********DMAË«»o3åéèÖÿaê¼********
        __HAL_UNLOCK(&DAC1DMA_Handler);
        HAL_DMAEx_MultiBufferStart(&DAC1DMA_Handler,(u32)&DAC->DHR12R1,(u32)buf2,(u32)buf3,BUFFERSIZE);//¿aÆôË«»o3å                                                  //10usÑóê±£¬·àÖ1-O2óÅ»ˉ3öÎêìa
    __HAL_DMA_ENABLE_IT(&DAC1DMA_Handler,DMA_IT_TC);             //¿aÆô′«êäíê3éÖD¶Ï
                //********DMAË«»o3åéèÖýáêø********
        HAL_NVIC_SetPriority(DMA1_Stream5_IRQn, 0, 1);
        HAL_NVIC_EnableIRQ(DMA1_Stream5_IRQn);
如上图,寄存器S0CR始终为0,
配置的是DMA1和ADC1
发表于 2018-4-20 14:46:30 | 显示全部楼层
是不是时钟之类的没开
 楼主| 发表于 2018-4-20 15:06:19 | 显示全部楼层
笑你像狗 发表于 2018-4-20 14:46
是不是时钟之类的没开
有的,只是发现DMA并没有开始传输
GMT+8, 2024-11-23 03:21 , Processed in 0.032277 second(s), 26 queries , Gzip On.
