查看: 17492|回复: 4
GUIBuilder程序移植后窗口口显示不正常,求大神帮忙
发表于 2018-5-4 12:51:35 | 显示全部楼层 |阅读模式
22火花
#include "MainTask.h"
*                SEGGER Microcontroller GmbH & Co. KG                *
*        Solutions for real time microcontroller applications        *
* C-file generated by:                                               *
*        GUI_Builder for emWin version 5.28                          *
*        Compiled Jan 30 2015, 16:41:06                              *
*        (c) 2015 Segger Microcontroller GmbH & Co. KG               *
*        Internet: www.segger.com  Support: support@segger.com       *
// USER START (Optionally insert additional includes)
// USER END
#include "DIALOG.h"
*       Defines
#define ID_FRAMEWIN_0 (GUI_ID_USER + 0x00)
#define ID_BUTTON_0 (GUI_ID_USER + 0x01)
// USER START (Optionally insert additional defines)
// USER END
*       Static data
// USER START (Optionally insert additional static data)
// USER END
*       _aDialogCreate
static const GUI_WIDGET_CREATE_INFO _aDialogCreate[] = {
  { FRAMEWIN_CreateIndirect, "Framewin", ID_FRAMEWIN_0, 0, 0, 240, 320, 0, 0x64, 0 },
  { BUTTON_CreateIndirect, "Button", ID_BUTTON_0, 76, 113, 80, 20, 0, 0x0, 0 },
  // USER START (Optionally insert additional widgets)
  // USER END
*       Static code
// USER START (Optionally insert additional static code)
// USER END
*       _cbDialog
static void _cbDialog(WM_MESSAGE * pMsg) {
  WM_HWIN hItem;
  int     NCode;
  int     Id;
  // USER START (Optionally insert additional variables)
  // USER END
  switch (pMsg->MsgId) {
  case WM_INIT_DIALOG:
    // Initialization of 'Framewin'
    hItem = pMsg->hWin;
    FRAMEWIN_SetFont(hItem, GUI_FONT_13_1);
    FRAMEWIN_SetTextAlign(hItem, GUI_TA_HCENTER | GUI_TA_VCENTER);
    FRAMEWIN_SetText(hItem, "suntong");
    FRAMEWIN_SetTitleHeight(hItem, 30);
    // USER START (Optionally insert additional code for further widget initialization)
    // USER END
    break;
  case WM_NOTIFY_PARENT:
    Id    = WM_GetId(pMsg->hWinSrc);
    NCode = pMsg->Data.v;
    switch(Id) {
    case ID_BUTTON_0: // Notifications sent by 'Button'
      switch(NCode) {
      case WM_NOTIFICATION_CLICKED:
        // USER START (Optionally insert code for reacting on notification message)
        // USER END
        break;
      case WM_NOTIFICATION_RELEASED:
        // USER END
        break;
      // USER START (Optionally insert additional code for further notification handling)
      // USER END
      break;
    // USER START (Optionally insert additional code for further Ids)
    // USER END
    break;
  // USER START (Optionally insert additional message handling)
  // USER END
  default:
    WM_DefaultProc(pMsg);
    break;
*       Public code
*       CreateFramewin
WM_HWIN CreateFramewin(void);
WM_HWIN CreateFramewin(void) {
  WM_HWIN hWin;
  hWin = GUI_CreateDialogBox(_aDialogCreate, GUI_COUNTOF(_aDialogCreate), _cbDialog, WM_HBKWIN, 0, 0);
  return hWin;
// USER START (Optionally insert additional public code)
// USER END
/*************************** End of file ****************************/
WM_HWIN hWin;
void MainTask(void)
        GUI_Clear();
        hWin = CreateFramewin();      //创建窗体,父窗体是桌面背景
          GUI_Delay(20);
        }                          //调用GUI_Delay函数延时20MS(最终目的是调用GUI_Exec()函数)
发表于 2018-5-4 14:51:39 | 显示全部楼层
帮顶,目前还没学习到这里。。。。。。
发表于 2018-5-4 14:52:08 | 显示全部楼层
用guibuilder生成的代码是会有很多问题的,只能当参考
发表于 2019-9-17 18:44:28 | 显示全部楼层
设置一下按键属性,可能可行 我用guibuilder生成的代码一直没问题都是直接复制的
发表于 2019-9-29 18:09:09 | 显示全部楼层
我用自己板子跑了下,代码是没问题的,有可能是你emwin移植没弄好。
GMT+8, 2025-4-15 17:00 , Processed in 0.105721 second(s), 26 queries , Gzip On.
