查看: 9403|回复: 1
霸天虎通过硬件IIC读写AT24C02
发表于 2018-5-4 18:18:15 | 显示全部楼层 |阅读模式
附录:读取AT24C02代码
* 从EEPROM中读取一块数据
* pBuffer 存放读出数据的缓存区指针
* WriteAddr 存放数据的内部地址
* NumberByteToRead 从EEPROM中读取的字节数
uint32_t I2C_EEPROM_BufferRead(uint8_t *pBuffer,uint8_t ReadAddr,uint16_t NumberByteToRead)
        //检测总线是否空闲,如若不是,则等待
        I2CTimeout = I2CT_FLAG_TIMEOUT;
        while(I2C_CheckEvent(EEPROM_I2C,I2C_FLAG_BUSY)!=ERROR)
                if((I2CTimeout--) == 0)
                        return I2C_TIMEOUT_UserCallback(9);
        //发送起始信号
        I2C_GenerateSTART(EEPROM_I2C,ENABLE);
        //等待SB,MSL,BUSY置1
        while(I2C_CheckEvent(EEPROM_I2C,I2C_EVENT_MASTER_MODE_SELECT)==ERROR)
                        return I2C_TIMEOUT_UserCallback(10);
        //发送EERPOM器件地址,写方向
        I2C_Send7bitAddress(EEPROM_I2C,EEPROM_ADRESS,I2C_Direction_Transmitter);
        //延时5ms
        Delay_ms(5);
        printf("I2C1->SR1 == %X\n",I2C1->SR1);
        //等待 ADDR,TXE,MSL,BUSY,TRA 置1
        while(I2C_CheckEvent(EEPROM_I2C,I2C_EVENT_MASTER_TRANSMITTER_MODE_SELECTED)==ERROR)
                        return I2C_TIMEOUT_UserCallback(11);
//        if(((EEPROM_I2C->SR1)&0x0002)==0)
//                return I2C_TIMEOUT_UserCallback(11);
//        EEPROM_I2C->SR2;
        //通过重新写入PE,清除ADDR位
        I2C_Cmd(EEPROM_I2C,ENABLE);
        //写入要读取的内部地址
        I2C_SendData(EEPROM_I2C,ReadAddr);
        //等待 BTF,TXE,MSL,BUSY,TRA        置1
        while(I2C_CheckEvent(EEPROM_I2C,I2C_EVENT_MASTER_BYTE_TRANSMITTED)==ERROR)
                        return I2C_TIMEOUT_UserCallback(12);
        //发送起始信号
        //等待SB,MSL,BUSY置1/        I2CTimeout = I2C_FLAG_TIMEOUT;
                        return I2C_TIMEOUT_UserCallback(13);
        //发送EERPOM器件地址,写方向
        I2C_Send7bitAddress(EEPROM_I2C,EEPROM_ADRESS,I2C_Direction_Receiver);
        while(I2C_CheckEvent(EEPROM_I2C,I2C_EVENT_MASTER_RECEIVER_MODE_SELECTED)==ERROR)
                        return I2C_TIMEOUT_UserCallback(14);
        while(NumberByteToRead)
                if(NumberByteToRead == 1)
                        I2C_AcknowledgeConfig(EEPROM_I2C,DISABLE);
                        I2C_GenerateSTOP(EEPROM_I2C,ENABLE);
                *pBuffer = EEPROM_I2C->DR;
                pBuffer++;
                NumberByteToRead--;
        //方便下次I2C传输,使能应答
        I2C_AcknowledgeConfig(EEPROM_I2C,ENABLE);
        return 1;
发表于 2018-5-4 18:41:33 | 显示全部楼层
帮顶。。。。。。
GMT+8, 2024-11-26 02:13 , Processed in 0.028515 second(s), 23 queries , Gzip On.
