查看: 9908|回复: 3
DCMI无法进入中断
发表于 2018-6-12 14:48:44 | 显示全部楼层 |阅读模式
引脚和摄像头是连对的,而且示波器上也测过,摄像头寄存器配置也成功。
void DMA_Config(uint32_t DMA_Memory0BaseAddr,uint16_t DMA_BufferSize)
  DMA_InitTypeDef  DMA_InitStructure;
        //NVIC_InitTypeDef NVIC_InitStructure;
  /* ÅäÖÃDMA′óDCMIÖD»ñè¡êy¾Y*/
  /* ê1ÄüDMA*/
  RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_DMA2, ENABLE);
  DMA_Cmd(DMA2_Stream1,DISABLE);
  while (DMA_GetCmdStatus(DMA2_Stream1) != DISABLE){}
  DMA_DeInit(DMA2_Stream1);
  DMA_InitStructure.DMA_Channel = DMA_Channel_1;
  DMA_InitStructure.DMA_PeripheralBaseAddr = DCMI_DR_ADDRESS;        //DCMIêy¾Y¼Ä′æÆ÷μØÖ·
  DMA_InitStructure.DMA_Memory0BaseAddr = DMA_Memory0BaseAddr; //DMA′«êäμÄÄ¿μÄμØÖ·(′«èëμÄ2Îêy)
  DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralToMemory;
  DMA_InitStructure.DMA_BufferSize =DMA_BufferSize;                                                 //′«êäμÄêy¾Y′óD¡(′«èëμÄ2Îêy)
  DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;                        //′æ′¢Æ÷μØÖ·×Ô¶ˉμYÔö
  DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_Word;
  DMA_InitStructure.DMA_MemoryDataSize = DMA_PeripheralDataSize_Word;
  DMA_InitStructure.DMA_Mode = DMA_Mode_Circular;        //Ñ-»·Ä£ê½
  DMA_InitStructure.DMA_FIFOMode = DMA_FIFOMode_Enable;
  DMA_InitStructure.DMA_FIFOThreshold = DMA_FIFOThreshold_Full;
  DMA_InitStructure.DMA_MemoryBurst = DMA_MemoryBurst_Single;//DMA_MemoryBurst_INC8  DMA_MemoryBurst_Single
  /*DMA3õê¼»ˉ */
  DMA_Init(DMA2_Stream1, &DMA_InitStructure);
        DMA_ITConfig(DMA2_Stream1,DMA_IT_TC,ENABLE);//′«êäíê3éÖD¶Ï
void MT_GPIO_Init(void)
          /***DCMIòy½ÅÅäÖÃ***/
          /* ê1ÄüDCMIê±Öó */
          RCC_AHB1PeriphClockCmd(DCMI_VSYNC_GPIO_CLK | DCMI_PIXCLK_GPIO_CLK|DCMI_HSYNC_GPIO_CLK |
        DCMI_D0_GPIO_CLK| DCMI_D1_GPIO_CLK| DCMI_D2_GPIO_CLK| DCMI_D3_GPIO_CLK|
        DCMI_D4_GPIO_CLK| DCMI_D5_GPIO_CLK| DCMI_D6_GPIO_CLK| DCMI_D7_GPIO_CLK, ENABLE);
          /*¿ØÖÆ/í¬2½DÅoÅÏß*/
          GPIO_InitStructure.GPIO_Pin = DCMI_VSYNC_GPIO_PIN;
          GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP ;//GPIO_PuPd_DOWN  GPIO_PuPd_UP
          GPIO_Init(DCMI_VSYNC_GPIO_PORT, &GPIO_InitStructure);
          GPIO_PinAFConfig(DCMI_VSYNC_GPIO_PORT, DCMI_VSYNC_PINSOURCE, DCMI_VSYNC_AF);
          GPIO_InitStructure.GPIO_Pin = DCMI_HSYNC_GPIO_PIN ;
          GPIO_Init(DCMI_HSYNC_GPIO_PORT, &GPIO_InitStructure);
          GPIO_PinAFConfig(DCMI_HSYNC_GPIO_PORT, DCMI_HSYNC_PINSOURCE, DCMI_HSYNC_AF);
          GPIO_InitStructure.GPIO_Pin = DCMI_PIXCLK_GPIO_PIN ;
          GPIO_Init(DCMI_PIXCLK_GPIO_PORT, &GPIO_InitStructure);
          GPIO_PinAFConfig(DCMI_PIXCLK_GPIO_PORT, DCMI_PIXCLK_PINSOURCE, DCMI_PIXCLK_AF);
                /*êy¾YDÅoÅ*/
          GPIO_InitStructure.GPIO_Pin = DCMI_D0_GPIO_PIN ;
          GPIO_Init(DCMI_D0_GPIO_PORT, &GPIO_InitStructure);
          GPIO_PinAFConfig(DCMI_D0_GPIO_PORT, DCMI_D0_PINSOURCE, DCMI_D0_AF);
          GPIO_InitStructure.GPIO_Pin = DCMI_D1_GPIO_PIN ;
          GPIO_Init(DCMI_D1_GPIO_PORT, &GPIO_InitStructure);
          GPIO_PinAFConfig(DCMI_D1_GPIO_PORT, DCMI_D1_PINSOURCE, DCMI_D1_AF);
          GPIO_InitStructure.GPIO_Pin = DCMI_D2_GPIO_PIN ;
          GPIO_Init(DCMI_D2_GPIO_PORT, &GPIO_InitStructure);
          GPIO_PinAFConfig(DCMI_D2_GPIO_PORT, DCMI_D2_PINSOURCE, DCMI_D2_AF);
          GPIO_InitStructure.GPIO_Pin = DCMI_D3_GPIO_PIN ;
          GPIO_Init(DCMI_D3_GPIO_PORT, &GPIO_InitStructure);
          GPIO_PinAFConfig(DCMI_D3_GPIO_PORT, DCMI_D3_PINSOURCE, DCMI_D3_AF);
          GPIO_InitStructure.GPIO_Pin = DCMI_D4_GPIO_PIN ;
          GPIO_Init(DCMI_D4_GPIO_PORT, &GPIO_InitStructure);
          GPIO_PinAFConfig(DCMI_D4_GPIO_PORT, DCMI_D4_PINSOURCE, DCMI_D4_AF);
          GPIO_InitStructure.GPIO_Pin = DCMI_D5_GPIO_PIN ;
          GPIO_Init(DCMI_D5_GPIO_PORT, &GPIO_InitStructure);
          GPIO_PinAFConfig(DCMI_D5_GPIO_PORT, DCMI_D5_PINSOURCE, DCMI_D5_AF);
          GPIO_InitStructure.GPIO_Pin = DCMI_D6_GPIO_PIN ;
          GPIO_Init(DCMI_D6_GPIO_PORT, &GPIO_InitStructure);
          GPIO_PinAFConfig(DCMI_D6_GPIO_PORT, DCMI_D6_PINSOURCE, DCMI_D6_AF);
          GPIO_InitStructure.GPIO_Pin = DCMI_D7_GPIO_PIN ;
          GPIO_Init(DCMI_D7_GPIO_PORT, &GPIO_InitStructure);
          GPIO_PinAFConfig(DCMI_D7_GPIO_PORT, DCMI_D7_PINSOURCE, DCMI_D7_AF);
void Camera_Init()
        DCMI_InitTypeDef DCMI_InitStructure;
  while(MT9V034_Init()==0)//¼Ä′æÆ÷ÅäÖÃ
           MT_GPIO_Init();
  RCC_AHB2PeriphClockCmd(RCC_AHB2Periph_DCMI, ENABLE);
  /* DCMI ÅäÖÃ*/
        DCMI_DeInit();
  DCMI_InitStructure.DCMI_CaptureMode = DCMI_CaptureMode_Continuous;
  DCMI_InitStructure.DCMI_SynchroMode = DCMI_SynchroMode_Hardware;
  DCMI_InitStructure.DCMI_PCKPolarity = DCMI_PCKPolarity_Rising;
  DCMI_InitStructure.DCMI_VSPolarity = DCMI_VSPolarity_High;//DCMI_VSPolarity_High
  DCMI_InitStructure.DCMI_HSPolarity = DCMI_VSPolarity_High;//DCMI_HSPolarity_Low
  DCMI_InitStructure.DCMI_CaptureRate = DCMI_CaptureRate_All_Frame;
  DCMI_InitStructure.DCMI_ExtendedDataMode = DCMI_ExtendedDataMode_8b;
  DCMI_Init(&DCMI_InitStructure);
        DCMI_ITConfig (DCMI_IT_FRAME,ENABLE);
        //ÅäÖÃDMA′«ê䣬ֱ½óÅäÖÃÑ-»·′«êä¼′¿é
  DMA_Config((uint32_t)&Image_Data,IMAGE_DATA);
        /* ÅäÖÃÖD¶Ï */
  NVIC_InitStructure.NVIC_IRQChannel = DMA2_Stream1_IRQn;
        NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority =0;
        NVIC_InitStructure.NVIC_IRQChannel = DCMI_IRQn ;        //Ö¡ÖD¶Ï
void Camera_Start()
         DCMI_CaptureCmd(ENABLE);
   DCMI_Cmd(ENABLE);
         DMA_Cmd(DMA2_Stream1, ENABLE);
下面是两个中断函数
void DCMI_IRQHandler(void)
        if(DCMI_GetITStatus(DCMI_IT_FRAME)!=RESET)//???????
                DCMI_ClearITPendingBit(DCMI_IT_FRAME);//??????
void DMA2_Stream1_IRQHandler(void)
        if(DMA_GetITStatus(DMA2_Stream1,DMA_IT_TCIF1)==SET)//DMA2_Stream1????
                GPIO_ToggleBits(LED1_GPIO_PORT,LED1_PIN);
                Get_Use_Image();
                DMA_ClearITPendingBit(DMA2_Stream1,DMA_IT_TCIF1);//????????
发表于 2018-6-12 16:26:57 | 显示全部楼层
手动给DCMI一个电平信号看看
 楼主| 发表于 2018-6-13 12:59:02 | 显示全部楼层
flyleaf 发表于 2018-6-12 16:26
手动给DCMI一个电平信号看看
也还是进不了中断
发表于 2018-6-13 14:06:34 | 显示全部楼层
805207107 发表于 2018-6-13 12:59
也还是进不了中断
那就检查dcmi的时钟、使能配置
GMT+8, 2024-11-24 04:21 , Processed in 0.027139 second(s), 23 queries , Gzip On.
