查看: 11309|回复: 1
我参考了从SD卡读字库的例程但是总是在一个地方出现硬件错误帮忙,看看
发表于 2018-9-6 11:12:00 | 显示全部楼层 |阅读模式
void LCD_DispChar_CH ( uint16_t usX, uint16_t usY, uint16_t usChar)
    uint8_t ucPage, ucColumn;
    uint8_t ucBuffer [ 24*24/8 ];
    uint32_t usTemp;
    uint32_t  xpos =0;
    uint32_t  Xaddress = 0;
    if(Ltdc_Handler.LayerCfg[ActiveLayer].PixelFormat == LTDC_PIXEL_FORMAT_RGB565)
    { /* RGB565 format */
        /*xpos表示当前行的显存偏移位置*/
        xpos = usX*XSIZE_PHYS*2;
    { /* ARGB8888 format */
        xpos = usX*XSIZE_PHYS*4;
    /*Xaddress表示像素点*/
    Xaddress += usY;
    macGetGBKCode ( ucBuffer, usChar );        //取字模数据
    /*ucPage表示当前行数*/
    for ( ucPage = 0; ucPage < macHEIGHT_CH_CHAR; ucPage ++ )
        /* 取出3个字节的数据,在lcd上即是一个汉字的一行 */
        usTemp = ucBuffer [ ucPage * 3 ];
        usTemp = ( usTemp << 8 );
        usTemp |= ucBuffer [ ucPage * 3 + 1 ];
        usTemp |= ucBuffer [ ucPage * 3 + 2];
        for ( ucColumn = 0; ucColumn < macWIDTH_CH_CHAR; ucColumn ++ )
            if ( usTemp & ( 0x01 << 23 ) )  //高位在前         (每次都在这里出现硬件错误)
                //字体色
                /* Write data value to all SDRAM memory */
                *(__IO uint16_t*) (Ltdc_Handler.LayerCfg[ActiveLayer].FBStartAdress + (2*Xaddress) + xpos) = DrawProp[ActiveLayer].TextColor;
                //字体色
                *(__IO uint32_t*) (Ltdc_Handler.LayerCfg[ActiveLayer].FBStartAdress + (4*Xaddress) + xpos) = DrawProp[ActiveLayer].TextColor;
                //背景色
                //字体色
                *(__IO uint16_t*) (Ltdc_Handler.LayerCfg[ActiveLayer].FBStartAdress + (2*Xaddress) + xpos) = DrawProp[ActiveLayer].BackColor;
                //字体色
                *(__IO uint32_t*) (Ltdc_Handler.LayerCfg[ActiveLayer].FBStartAdress + (4*Xaddress) + xpos) = DrawProp[ActiveLayer].BackColor;
            /*指向当前行的下一个点*/
            Xaddress++;
            usTemp <<= 1;
        /*显示完一行*/
        /*指向字符显示矩阵下一行的第一个像素点*/
        Xaddress += (XSIZE_PHYS - macWIDTH_CH_CHAR);
 楼主| 发表于 2018-9-6 11:17:49 | 显示全部楼层
LTDC—LCD显示汉字(字库在SD卡)这个例程,746的
GMT+8, 2024-11-1 15:28 , Processed in 0.031846 second(s), 24 queries , Gzip On.
