查看: 9858|回复: 1
MQTT 订阅问题
发表于 2018-10-10 15:46:21 | 显示全部楼层 |阅读模式
我在使用霸道开发板  移植 MQTT   订阅总是收不到消息。有经验的,帮帮我看看,感激不尽
订阅函数为
[mw_shl_code=c,true]
int mqtt_subscrib(char *pTopic,char *pMessage)
        MQTTPacket_connectData data = MQTTPacket_connectData_initializer;
        int rc = 0;
        unsigned char buf[200];
        int buflen = sizeof(buf);
        int msgid = 1;
        MQTTString topicString = MQTTString_initializer;
        int req_qos = 0;
        int len = 0;
        rc = transport_open();
        if(rc < 0){
    printf("transport_open error\r\n");
                return rc;
          data.clientID.cstring = "mmme";        //客户设备ID客户端标识,用于区分每个客户端 )
        data.keepAliveInterval = 1;        //服务器保持时间(服务器保持连接时间,超过该时间后,服务器会主动断开连接,单位为秒)
        data.cleansession = 1;                        //该标志置1服务器必须丢弃之前保持的客户端的信息,将该连接视为“不存在”
        data.username.cstring = "admin";                                //MQTT云服务器登录用户名
        data.password.cstring = "password";                        //MQTT云服务器登录密码
        len = MQTTSerialize_connect(buf, buflen, &data);
        rc = transport_sendPacketBuffer(buf, len);
  if(rc != len){
    printf("connect transport_sendPacketBuffer error\r\n");
    goto exit;
        /* wait for connack */
        if (MQTTPacket_read(buf, buflen, transport_getdata) == CONNACK)
                unsigned char sessionPresent, connack_rc,refur=0;
                refur =MQTTDeserialize_connack(&sessionPresent, &connack_rc, buf, buflen);
                if ( refur!= 1 )  //|| connack_rc != 0
                        printf("Unable to connect, return code %d\r\n ", connack_rc);
                        goto exit;
        }else{
    printf("MQTTPacket_read error\r\n");
                goto exit;
        /* subscribe */
        topicString.cstring = pTopic;
        len = MQTTSerialize_subscribe(buf, buflen, 0, msgid, 1, &topicString, &req_qos);
  if(rc != len){
    printf("connect transport_sendPacketBuffer error \r\n");
    goto exit;
        if (MQTTPacket_read(buf, buflen, transport_getdata) == SUBACK)         /* wait for suback */
                unsigned short submsgid;
                int subcount;
                int granted_qos;
                rc = MQTTDeserialize_suback(&submsgid, 1, &subcount, &granted_qos, buf, buflen);
                if (granted_qos != 0)
                        printf("granted qos != 0, %d   \r\n", granted_qos);
                        goto exit;
                goto exit;
        /* loop getting msgs on subscribed topic */
        memset(buf,0,buflen);
  //transport_getdata接收数据会阻塞,除非服务器断开连接后才返回
  if (MQTTPacket_read(buf, buflen, transport_getdata) == PUBLISH){
    unsigned char dup;
    int qos;
    unsigned char retained;
    unsigned short msgid;
    int payloadlen_in;
    unsigned char* payload_in;
    MQTTString receivedTopic;
    rc = MQTTDeserialize_publish(&dup, &qos, &retained, &msgid, &receivedTopic,
        &payload_in, &payloadlen_in, buf, buflen);
    printf("message arrived %d: %s \r\n", payloadlen_in, payload_in);
    strcpy(pMessage,(const char *)payload_in);
  printf("disconnecting \r\n ");
  len = MQTTSerialize_disconnect(buf, buflen);
exit:
           rc=-1;
        transport_close();//关闭socket
  return rc;
}[/mw_shl_code]
主函数部分就直接调用了
[mw_shl_code=c,true]int main(void)
        int rc;
        char meassage[200]={0};
        systick_init(72);        /*初始化Systick工作时钟*/
        USART1_Config();        /*初始化串口通信:115200@8-n-1*/
        i2c_CfgGpio();        /*初始化eeprom*/
        gpio_for_w5500_config();                                                /*初始化MCU相关引脚*/
        reset_w5500();        /*硬复位W5500*/
        TIM3_Int_Init(100,719);
        set_w5500_mac();        /*配置MAC地址*/
//        set_w5500_ip();        /*配置IP地址*/
        socket_buf_init(txsize, rxsize);                /*初始化8个Socket的发送接收缓存大小*/
  printf(" 电脑作为TCP服务器,让W5500作为 TCP客户端去连接 \r\n");
        printf(" 服务器IP:%d.%d.%d.%d\r\n",domain_ip[0],domain_ip[1],domain_ip[2],domain_ip[3]);
        printf(" 监听端口:%d \r\n",remote_port);
        while(1)                            /*循环执行的函数*/
                    do_dhcp();
                while(dhcp_ok)
//                        do_tcp_client();
//                        delay_s(1);
                        memset(meassage,0,sizeof(meassage));
                        rc=0;
                        printf("\r\n mqtt_subscrib state \r\n");
                        rc = mqtt_subscrib("147",meassage);
                        printf("\r\n rc = %d\r\n",rc);
                        if(rc >= 0){
                        printf("meassage = %s  \r\n \r\n ",meassage);
                                delay_s(10);
[/mw_shl_code]
发表于 2018-10-12 08:55:25 | 显示全部楼层
仿真问题出在哪一步呢?
GMT+8, 2024-11-23 07:43 , Processed in 0.046822 second(s), 24 queries , Gzip On.
