查看: 11483|回复: 5
SPIFlash启动和XIP运行时的时钟初始化问题
发表于 2018-10-23 12:38:36 | 显示全部楼层 |阅读模式
请问当系统ROM从外部FlexSPI连接的SPI Nor Flash启动时,从头部读取flash的memconfig数据后,初始化时钟使用的哪路PLL时钟?以及是怎么设定的Mux和Div呢?主要是想后面用户程序在设定配置PLL的时候避开原来的配置以免修改错参数,导致意外的跑飞,谢谢!
发表于 2018-10-23 13:18:26 | 显示全部楼层
从火哥提供的NXP官方 Flashloader代码里我扣出来了这些代码, 看起来是PFD480_PFD0, 具体看代码
[mw_shl_code=c,true]// FLEXSPI clock configuration, safe frequency: 30MHz
    CCM->CSCMR1 = ((CCM->CSCMR1 &
                    ~(CCM_CSCMR1_FLEXSPI_CLK_SEL_MASK | CCM_CSCMR1_FLEXSPI_PODF_MASK | CCM_CSCMR1_PERCLK_PODF_MASK |
                      CCM_CSCMR1_PERCLK_CLK_SEL_MASK)) |
                   CCM_CSCMR1_FLEXSPI_CLK_SEL(3) | CCM_CSCMR1_FLEXSPI_PODF(7) | CCM_CSCMR1_PERCLK_PODF(1));
void flexspi_clock_config(uint32_t instance, uint32_t freq, uint32_t sampleClkMode)
    uint32_t pfd480 = 0;
    uint32_t cscmr1 = 0;
    uint32_t frac = 0;
    uint32_t podf = 0;
    typedef struct _flexspi_clock_param
        uint8_t frac;
        uint8_t podf;
    } flexspi_clock_param_t;
    const flexspi_clock_param_t k_sdr_clock_config[kFlexSpiSerialClk_200MHz + 1] = {
        // Reserved, 30MHz     50MHz     60MHz        75MHz    80MHz       100MHz   133MHz       166MHz   200MHz
        { 0, 0 }, { 34, 8 }, { 22, 8 }, { 24, 6 }, { 30, 4 }, { 18, 6 }, { 14, 6 }, { 17, 4 }, { 26, 2 }, { 22, 2 }
    const flexspi_clock_param_t k_ddr_clock_config[kFlexSpiSerialClk_200MHz + 1] = {
        // Reserved, 30MHz,  50MHz,       60MHz,      75MHz,   80Mhz,   100MHz,      133MHz,   166MHz,     200MHz
        { 0, 0 }, { 24, 6 }, { 22, 4 }, { 12, 6 }, { 30, 2 }, { 18, 3 }, { 22, 2 }, { 33, 1 }, { 26, 1 }, { 22, 1 }
    do
        if ((sampleClkMode != kFlexSpiClk_SDR) && (sampleClkMode != kFlexSpiClk_DDR))
            break;
        pfd480 = CCM_ANALOG->PFD_480 & (~CCM_ANALOG_PFD_480_PFD0_FRAC_MASK);
        cscmr1 = CCM->CSCMR1 & (~CCM_CSCMR1_FLEXSPI_PODF_MASK);
        // Note: Per ANALOG IP Owner's recommendation, FRAC should be even number,
        //       PODF should be even nubmer as well if the divider is greater than 1
        const flexspi_clock_param_t *flexspi_config_array = NULL;
        if (sampleClkMode == kFlexSpiClk_SDR)
            flexspi_config_array = &k_sdr_clock_config[0];
            flexspi_config_array = &k_ddr_clock_config[0];
        if (freq >= kFlexSpiSerialClk_30MHz)
            if (freq > kFlexSpiSerialClk_200MHz)
                freq = kFlexSpiSerialClk_30MHz;
            frac = flexspi_config_array[freq].frac;
            podf = flexspi_config_array[freq].podf;
            pfd480 |= CCM_ANALOG_PFD_480_PFD0_FRAC(frac);
            cscmr1 |= CCM_CSCMR1_FLEXSPI_PODF(podf - 1);
            FLEXSPI->MCR0 |= FLEXSPI_MCR0_MDIS_MASK;
            flexspi_clock_gate_disable(instance);
            if (pfd480 != CCM_ANALOG->PFD_480)
                CCM_ANALOG->PFD_480 = pfd480;
            if (cscmr1 != CCM->CSCMR1)
                CCM->CSCMR1 = cscmr1;
            flexspi_clock_gate_enable(instance);
            FLEXSPI->MCR0 &= ~FLEXSPI_MCR0_MDIS_MASK;
            // Do nothing
    } while (0);
}[/mw_shl_code]
 楼主| 发表于 2018-10-23 13:19:15 | 显示全部楼层
感谢,那我也去扣一下那块代码
 楼主| 发表于 2018-10-23 13:38:28 | 显示全部楼层
顺便问一下,这个代码的话是不是因为是固化在ROM里面的,我们是没办法去修改的吧,或者换句话说,如果代码是跑在spi flash上的话, PFD480_PFD0这个频率以及后面的PFD设定在应用代码里就不能碰了,否则就直接跑飞了,是么?
发表于 2018-10-23 13:47:00 | 显示全部楼层
knight_hu 发表于 2018-10-23 13:38
顺便问一下,这个代码的话是不是因为是固化在ROM里面的,我们是没办法去修改的吧,或者换句话说,如果代码 ...
改也是可以改的,只是我的理解是改CLOCK的代码不能在FLASH里,得复制到RAM里执行,而且在改时钟的时候得关中断,得避免DMA等其他master访问FLASH,要不然可能有未期望的行为发生
发表于 2018-10-23 13:54:58 | 显示全部楼层
[mw_shl ...
厉害了
GMT+8, 2025-4-10 13:22 , Processed in 0.059388 second(s), 24 queries , Gzip On.
