初中生
最后登录1970-1-1
在线时间 小时
注册时间2018-10-17
原来115200的波特率加入外部SRAM后波特率变成了57600,程序里面的配置是115200,上位机接收的时候要设置成57600才能接收正确,想知道是有什么地方配置错误了吗?才导致时钟变慢还是有什么地方需要另外配置。下面是system_stm32f4xx.c的配置,屏蔽掉了库自带的FSMC初始化
[mw_shl_code=c,true]void SystemInit_ExtMemCtl(void)
/*-- GPIOs Configuration -----------------------------------------------------*/
+ SRAM pins assignment +
| PD0 <-> FMC_D2 | PE0 <-> FMC_NBL0 | PF0 <-> FMC_A0 | PG0 <-> FMC_A10 |
| PD1 <-> FMC_D3 | PE1 <-> FMC_NBL1 | PF1 <-> FMC_A1 | PG1 <-> FMC_A11 |
| PD4 <-> FMC_NOE | PE3 <-> FMC_A19 | PF2 <-> FMC_A2 | PG2 <-> FMC_A12 |
| PD5 <-> FMC_NWE | PE4 <-> FMC_A20 | PF3 <-> FMC_A3 | PG3 <-> FMC_A13 |
| PD8 <-> FMC_D13 | PE7 <-> FMC_D4 | PF4 <-> FMC_A4 | PG4 <-> FMC_A14 |
| PD9 <-> FMC_D14 | PE8 <-> FMC_D5 | PF5 <-> FMC_A5 | PG5 <-> FMC_A15 |
| PD10 <-> FMC_D15 | PE9 <-> FMC_D6 | PF12 <-> FMC_A6 | PG9 <-> FMC_NE2 |
| PD11 <-> FMC_A16 | PE10 <-> FMC_D7 | PF13 <-> FMC_A7 |-----------------+
| PD12 <-> FMC_A17 | PE11 <-> FMC_D8 | PF14 <-> FMC_A8 |
| PD13 <-> FMC_A18 | PE12 <-> FMC_D9 | PF15 <-> FMC_A9 |
| PD14 <-> FMC_D0 | PE13 <-> FMC_D10 |-----------------+
| PD15 <-> FMC_D1 | PE14 <-> FMC_D11 |
| | PE15 <-> FMC_D12 |
/* Enable GPIOD, GPIOE, GPIOF and GPIOG interface clock */
// RCC->AHB1ENR |= 0x00000078;
// /* Connect PDx pins to FMC Alternate function */
// GPIOD->AFR[0] = 0x00cc00cc;
// GPIOD->AFR[1] = 0xcccccccc;
// /* Configure PDx pins in Alternate function mode */
// GPIOD->MODER = 0xaaaa0a0a;
// /* Configure PDx pins speed to 100 MHz */
// GPIOD->OSPEEDR = 0xffff0f0f;
// /* Configure PDx pins Output type to push-pull */
// GPIOD->OTYPER = 0x00000000;
// /* No pull-up, pull-down for PDx pins */
// GPIOD->PUPDR = 0x00000000;
// /* Connect PEx pins to FMC Alternate function */
// GPIOE->AFR[0] = 0xcccccccc;
// GPIOE->AFR[1] = 0xcccccccc;
// /* Configure PEx pins in Alternate function mode */
// GPIOE->MODER = 0xaaaaaaaa;
// /* Configure PEx pins speed to 100 MHz */
// GPIOE->OSPEEDR = 0xffffffff;
// /* Configure PEx pins Output type to push-pull */
// GPIOE->OTYPER = 0x00000000;
// /* No pull-up, pull-down for PEx pins */
// GPIOE->PUPDR = 0x00000000;
// /* Connect PFx pins to FMC Alternate function */
// GPIOF->AFR[0] = 0x00cccccc;
// GPIOF->AFR[1] = 0xcccc0000;
// /* Configure PFx pins in Alternate function mode */
// GPIOF->MODER = 0xaa000aaa;
// /* Configure PFx pins speed to 100 MHz */
// GPIOF->OSPEEDR = 0xff000fff;
// /* Configure PFx pins Output type to push-pull */
// GPIOF->OTYPER = 0x00000000;
// /* No pull-up, pull-down for PFx pins */
// GPIOF->PUPDR = 0x00000000;
// /* Connect PGx pins to FMC Alternate function */
// GPIOG->AFR[0] = 0x00cccccc;
// GPIOG->AFR[1] = 0x000000c0;
// /* Configure PGx pins in Alternate function mode */
// GPIOG->MODER = 0x00080aaa;
// /* Configure PGx pins speed to 100 MHz */
// GPIOG->OSPEEDR = 0x000c0fff;
// /* Configure PGx pins Output type to push-pull */
// GPIOG->OTYPER = 0x00000000;
// /* No pull-up, pull-down for PGx pins */
// GPIOG->PUPDR = 0x00000000;
///*-- FMC Configuration ------------------------------------------------------*/
// /* Enable the FMC/FSMC interface clock */
// RCC->AHB3ENR |= 0x00000001;
//#if defined (STM32F427_437xx) || defined (STM32F429_439xx)
// /* Configure and enable Bank1_SRAM2 */
// FMC_Bank1->BTCR[2] = 0x00001011;
// FMC_Bank1->BTCR[3] = 0x00000201;
// FMC_Bank1E->BWTR[2] = 0x0fffffff;
//#endif /* STM32F427_437xx || STM32F429_439xx */
//#if defined (STM32F40_41xxx)
// FSMC_Bank1->BTCR[2] = 0x00001011;
// FSMC_Bank1->BTCR[3] = 0x00000201;
// FSMC_Bank1E->BWTR[2] = 0x0fffffff;
// FSMC_Bank1->BTCR[0]=0X00000000;
// FSMC_Bank1->BTCR[1]=0X00000000;
// FSMC_Bank1E->BWTR[0]=0X00000000;
//#endif /* STM32F40_41xxx */
FSMC_NORSRAMInitTypeDef FSMC_NORSRAMInitStructure;
FSMC_NORSRAMTimingInitTypeDef readWriteTiming;
RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOB|RCC_AHB1Periph_GPIOD|RCC_AHB1Periph_GPIOE|RCC_AHB1Periph_GPIOF|RCC_AHB1Periph_GPIOG, ENABLE);//ê1ÄüPD,PE,PF,PGê±Öó
RCC_AHB3PeriphClockCmd(RCC_AHB3Periph_FSMC,ENABLE);//ê1ÄüFSMCê±Öó
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_15;//PB15 íÆíìêä3ö,¿ØÖƱ31a
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_OUT;//ÆÕí¨êä3öÄ£ê½
GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;//íÆíìêä3ö
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;//100MHz
GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;//éÏà-
GPIO_Init(GPIOB, &GPIO_InitStructure);//3õê¼»ˉ //PB15 íÆíìêä3ö,¿ØÖƱ31a
GPIO_InitStructure.GPIO_Pin = (3<<0)|(3<<4)|(0XFF<<8)|GPIO_Pin_7;//PD0,1,4,5,7 NE1,8~15 AF OUT
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;//¸′óÃêä3ö
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_100MHz;//100MHz
GPIO_Init(GPIOD, &GPIO_InitStructure);//3õê¼»ˉ
GPIO_InitStructure.GPIO_Pin = (3<<0)|(0X1FF<<7);//PE0,1,7~15,AF OUT
GPIO_Init(GPIOE, &GPIO_InitStructure);//3õê¼»ˉ
GPIO_InitStructure.GPIO_Pin = (0X3F<<0)|(0XF<<12); //PF0~5,12~15
GPIO_Init(GPIOF, &GPIO_InitStructure);//3õê¼»ˉ
GPIO_InitStructure.GPIO_Pin =(0X3F<<0);//PG0~5
GPIO_Init(GPIOG, &GPIO_InitStructure);//3õê¼»ˉ
GPIO_PinAFConfig(GPIOD,GPIO_PinSource0,GPIO_AF_FSMC);//PD0,AF12
GPIO_PinAFConfig(GPIOD,GPIO_PinSource1,GPIO_AF_FSMC);//PD1,AF12
GPIO_PinAFConfig(GPIOD,GPIO_PinSource4,GPIO_AF_FSMC);
GPIO_PinAFConfig(GPIOD,GPIO_PinSource5,GPIO_AF_FSMC);
GPIO_PinAFConfig(GPIOD,GPIO_PinSource7,GPIO_AF_FSMC);
GPIO_PinAFConfig(GPIOD,GPIO_PinSource8,GPIO_AF_FSMC);
GPIO_PinAFConfig(GPIOD,GPIO_PinSource9,GPIO_AF_FSMC);
GPIO_PinAFConfig(GPIOD,GPIO_PinSource10,GPIO_AF_FSMC);
GPIO_PinAFConfig(GPIOD,GPIO_PinSource11,GPIO_AF_FSMC);
GPIO_PinAFConfig(GPIOD,GPIO_PinSource12,GPIO_AF_FSMC);
GPIO_PinAFConfig(GPIOD,GPIO_PinSource13,GPIO_AF_FSMC);
GPIO_PinAFConfig(GPIOD,GPIO_PinSource14,GPIO_AF_FSMC);
GPIO_PinAFConfig(GPIOD,GPIO_PinSource15,GPIO_AF_FSMC);//PD15,AF12
GPIO_PinAFConfig(GPIOE,GPIO_PinSource0,GPIO_AF_FSMC);
GPIO_PinAFConfig(GPIOE,GPIO_PinSource1,GPIO_AF_FSMC);
GPIO_PinAFConfig(GPIOE,GPIO_PinSource7,GPIO_AF_FSMC);//PE7,AF12
GPIO_PinAFConfig(GPIOE,GPIO_PinSource8,GPIO_AF_FSMC);
GPIO_PinAFConfig(GPIOE,GPIO_PinSource9,GPIO_AF_FSMC);
GPIO_PinAFConfig(GPIOE,GPIO_PinSource10,GPIO_AF_FSMC);
GPIO_PinAFConfig(GPIOE,GPIO_PinSource11,GPIO_AF_FSMC);
GPIO_PinAFConfig(GPIOE,GPIO_PinSource12,GPIO_AF_FSMC);
GPIO_PinAFConfig(GPIOE,GPIO_PinSource13,GPIO_AF_FSMC);
GPIO_PinAFConfig(GPIOE,GPIO_PinSource14,GPIO_AF_FSMC);
GPIO_PinAFConfig(GPIOE,GPIO_PinSource15,GPIO_AF_FSMC);//PE15,AF12
GPIO_PinAFConfig(GPIOF,GPIO_PinSource0,GPIO_AF_FSMC);//PF0,AF12
GPIO_PinAFConfig(GPIOF,GPIO_PinSource1,GPIO_AF_FSMC);//PF1,AF12
GPIO_PinAFConfig(GPIOF,GPIO_PinSource2,GPIO_AF_FSMC);//PF2,AF12
GPIO_PinAFConfig(GPIOF,GPIO_PinSource3,GPIO_AF_FSMC);//PF3,AF12
GPIO_PinAFConfig(GPIOF,GPIO_PinSource4,GPIO_AF_FSMC);//PF4,AF12
GPIO_PinAFConfig(GPIOF,GPIO_PinSource5,GPIO_AF_FSMC);//PF5,AF12
GPIO_PinAFConfig(GPIOF,GPIO_PinSource12,GPIO_AF_FSMC);//PF12,AF12
GPIO_PinAFConfig(GPIOF,GPIO_PinSource13,GPIO_AF_FSMC);//PF13,AF12
GPIO_PinAFConfig(GPIOF,GPIO_PinSource14,GPIO_AF_FSMC);//PF14,AF12
GPIO_PinAFConfig(GPIOF,GPIO_PinSource15,GPIO_AF_FSMC);//PF15,AF12
GPIO_PinAFConfig(GPIOG,GPIO_PinSource0,GPIO_AF_FSMC);
GPIO_PinAFConfig(GPIOG,GPIO_PinSource1,GPIO_AF_FSMC);
GPIO_PinAFConfig(GPIOG,GPIO_PinSource2,GPIO_AF_FSMC);
GPIO_PinAFConfig(GPIOG,GPIO_PinSource3,GPIO_AF_FSMC);
GPIO_PinAFConfig(GPIOG,GPIO_PinSource4,GPIO_AF_FSMC);
GPIO_PinAFConfig(GPIOG,GPIO_PinSource5,GPIO_AF_FSMC);
// GPIO_PinAFConfig(GPIOG,GPIO_PinSource10,GPIO_AF_FSMC);
readWriteTiming.FSMC_AddressSetupTime = 0x00; //μØÖ·½¨á¢ê±¼ä£¨ADDSET£©Îa1¸öHCLK 1/36M=27ns
readWriteTiming.FSMC_AddressHoldTime = 0x00; //μØÖ·±£3Ö걼䣨ADDHLD£©Ä£ê½AÎ′óÃμ½
readWriteTiming.FSMC_DataSetupTime = 0x08; ////êy¾Y±£3Ö걼䣨DATAST£©Îa9¸öHCLK 6*9=54ns
readWriteTiming.FSMC_BusTurnAroundDuration = 0x00;
readWriteTiming.FSMC_CLKDivision = 0x00;
readWriteTiming.FSMC_DataLatency = 0x00;
readWriteTiming.FSMC_AccessMode = FSMC_AccessMode_A; //Ä£ê½A
FSMC_NORSRAMInitStructure.FSMC_Bank = FSMC_Bank1_NORSRAM1;// ÕaàïÎòÃÇê1óÃNE1
FSMC_NORSRAMInitStructure.FSMC_DataAddressMux = FSMC_DataAddressMux_Disable;
FSMC_NORSRAMInitStructure.FSMC_MemoryType =FSMC_MemoryType_SRAM;// FSMC_MemoryType_SRAM; //SRAM
FSMC_NORSRAMInitStructure.FSMC_MemoryDataWidth = FSMC_MemoryDataWidth_16b;//′æ′¢Æ÷êy¾Y¿í¶èÎa16bit
FSMC_NORSRAMInitStructure.FSMC_BurstAccessMode =FSMC_BurstAccessMode_Disable;// FSMC_BurstAccessMode_Disable;
FSMC_NORSRAMInitStructure.FSMC_WaitSignalPolarity = FSMC_WaitSignalPolarity_Low;
FSMC_NORSRAMInitStructure.FSMC_AsynchronousWait=FSMC_AsynchronousWait_Disable;
FSMC_NORSRAMInitStructure.FSMC_WrapMode = FSMC_WrapMode_Disable;
FSMC_NORSRAMInitStructure.FSMC_WaitSignalActive = FSMC_WaitSignalActive_BeforeWaitState;
FSMC_NORSRAMInitStructure.FSMC_WriteOperation = FSMC_WriteOperation_Enable; //′æ′¢Æ÷D′ê1Äü
FSMC_NORSRAMInitStructure.FSMC_WaitSignal = FSMC_WaitSignal_Disable;
FSMC_NORSRAMInitStructure.FSMC_ExtendedMode = FSMC_ExtendedMode_Disable; // ¶áD′ê1óÃÏàí¬μÄê±Dò
FSMC_NORSRAMInitStructure.FSMC_WriteBurst = FSMC_WriteBurst_Disable;
FSMC_NORSRAMInitStructure.FSMC_ReadWriteTimingStruct = &readWriteTiming;
FSMC_NORSRAMInitStructure.FSMC_WriteTimingStruct = &readWriteTiming; //¶áD′í¬Ñùê±Dò
FSMC_NORSRAMInit(&FSMC_NORSRAMInitStructure); //3õê¼»ˉFSMCÅäÖÃ
FSMC_NORSRAMCmd(FSMC_Bank1_NORSRAM1, ENABLE); // ê1ÄüBANK1Çøóò1
Bank1_SRAM2 is configured as follow:
In case of FSMC configuration
NORSRAMTimingStructure.FSMC_AddressSetupTime = 1;
NORSRAMTimingStructure.FSMC_AddressHoldTime = 0;
NORSRAMTimingStructure.FSMC_DataSetupTime = 2;
NORSRAMTimingStructure.FSMC_BusTurnAroundDuration = 0;
NORSRAMTimingStructure.FSMC_CLKDivision = 0;
NORSRAMTimingStructure.FSMC_DataLatency = 0;
NORSRAMTimingStructure.FSMC_AccessMode = FMC_AccessMode_A;
FSMC_NORSRAMInitStructure.FSMC_Bank = FSMC_Bank1_NORSRAM2;
FSMC_NORSRAMInitStructure.FSMC_MemoryType = FSMC_MemoryType_SRAM;
FSMC_NORSRAMInitStructure.FSMC_BurstAccessMode = FSMC_BurstAccessMode_Disable;
FSMC_NORSRAMInitStructure.FSMC_AsynchronousWait = FSMC_AsynchronousWait_Disable;
FSMC_NORSRAMInitStructure.FSMC_ReadWriteTimingStruct = &NORSRAMTimingStructure;
FSMC_NORSRAMInitStructure.FSMC_WriteTimingStruct = &NORSRAMTimingStructure;
In case of FMC configuration
NORSRAMTimingStructure.FMC_AddressSetupTime = 1;
NORSRAMTimingStructure.FMC_AddressHoldTime = 0;
NORSRAMTimingStructure.FMC_DataSetupTime = 2;
NORSRAMTimingStructure.FMC_BusTurnAroundDuration = 0;
NORSRAMTimingStructure.FMC_CLKDivision = 0;
NORSRAMTimingStructure.FMC_DataLatency = 0;
NORSRAMTimingStructure.FMC_AccessMode = FMC_AccessMode_A;
FMC_NORSRAMInitStructure.FMC_Bank = FMC_Bank1_NORSRAM2;
FMC_NORSRAMInitStructure.FMC_DataAddressMux = FMC_DataAddressMux_Disable;
FMC_NORSRAMInitStructure.FMC_MemoryType = FMC_MemoryType_SRAM;
FMC_NORSRAMInitStructure.FMC_MemoryDataWidth = FMC_MemoryDataWidth_16b;
FMC_NORSRAMInitStructure.FMC_BurstAccessMode = FMC_BurstAccessMode_Disable;
FMC_NORSRAMInitStructure.FMC_AsynchronousWait = FMC_AsynchronousWait_Disable;
FMC_NORSRAMInitStructure.FMC_WaitSignalPolarity = FMC_WaitSignalPolarity_Low;
FMC_NORSRAMInitStructure.FMC_WrapMode = FMC_WrapMode_Disable;
FMC_NORSRAMInitStructure.FMC_WaitSignalActive = FMC_WaitSignalActive_BeforeWaitState;
FMC_NORSRAMInitStructure.FMC_WriteOperation = FMC_WriteOperation_Enable;
FMC_NORSRAMInitStructure.FMC_WaitSignal = FMC_WaitSignal_Disable;
FMC_NORSRAMInitStructure.FMC_ExtendedMode = FMC_ExtendedMode_Disable;
FMC_NORSRAMInitStructure.FMC_WriteBurst = FMC_WriteBurst_Disable;
FMC_NORSRAMInitStructure.FMC_ContinousClock = FMC_CClock_SyncOnly;
FMC_NORSRAMInitStructure.FMC_ReadWriteTimingStruct = &NORSRAMTimingStructure;
FMC_NORSRAMInitStructure.FMC_WriteTimingStruct = &NORSRAMTimingStructure;
}[/mw_shl_code]
软件配置按照教程配置的
软件按照教程配置的
找不到什么原因导致的,有没有遇见过同样情况的,希望指导一下。
