查看: 10661|回复: 1
Flah id 读取出错
发表于 2019-3-11 10:32:12 | 显示全部楼层 |阅读模式
对SPI Flash W25Q64进行写操作时,改变发送的数据的字节数,读取到的id居然是变化的,比如字节数为10时id是0xef4017,是对的,把字节数改成255时,就变成了0xef40ff等等。在出现的几次错误中0xef和0x40都是对的,就是低8位总是变。请问各位大神这是怎么回事呢?
main()代码(其他函数与例程一致):
[mw_shl_code=c,true]#include "stm32f10x.h"
#include "bsp_led.h"
#include "bsp_key.h"
#include "bsp_usart.h"
#include "bsp_spi_flash.h"
#define DATA_SIZE 240
#define DATA_ADDR 0x01010a
    uint32_t i = 0;
    uint8_t flag = 0;
    uint8_t data_write[DATA_SIZE];
    uint8_t data_read[DATA_SIZE];
    uint32_t flash_id_seq;
    for(i = 0; i < DATA_SIZE; i++)
        data_write = i & 0xff;
    Key_GPIO_Config();
    USART_Config();
    FLASH_SPI_Config();
    flash_id_seq = FLASH_SPI_ReadJEDECID();
    printf("flash id: %#x\n", flash_id_seq);
    if(flash_id_seq == FLASH_ID_SEQ)
        printf("Flash is ready!\n\n");
        if(GPIO_ReadInputDataBit(KEY1_GPIO_PORT, KEY1_GPIO_PIN) == SET)
            while(GPIO_ReadInputDataBit(KEY1_GPIO_PORT, KEY1_GPIO_PIN) == SET)
                if(flag == 0)
                    #if 1
                    //read
                    printf("read data before erase:\n");
                    FLASH_SPI_ReadData(data_read, DATA_SIZE, DATA_ADDR);
                        printf("%#x\n", data_read);
                    FLASH_SPI_SectorErase(DATA_ADDR);
                    printf("read data after erase:\n");
                    //write
                    printf("write data\n");
                    FLASH_SPI_PageProgram(data_write, DATA_SIZE, DATA_ADDR);
                    //FLASH_SPI_Program(data_write, DATA_SIZE, DATA_ADDR);
                        printf("%#x\n", data_write);
                    //read
                    printf("read data after write:\n");
                    #endif
                    flag = 1;
        flag = 0;
[/mw_shl_code]
 楼主| 发表于 2019-3-11 10:33:30 | 显示全部楼层
而且读写数据都是正常的,就只有ID错了。。。
GMT+8, 2024-11-24 00:53 , Processed in 0.029739 second(s), 23 queries , Gzip On.
