查看: 12311|回复: 3
0xDEADBEEE
发表于 2019-3-15 22:48:22 | 显示全部楼层 |阅读模式
我在用Jlink下载程式的时候,他虽然会有verify flash这个步骤,可是之后会直接当掉,程式会在0xDEADBEEE的地址停住,然后大部分的register里面的资料都是DEADBEEF,有人知道是为什么吗?
这是Jlink connect会出现的信息:
J-Link>connect
Device "MIMXRT1052QSPI" selected.
Connecting to target via SWD
Found SW-DP with ID 0x0BD11477
AP map detection skipped. Manually configured AP map found.
AP[0]: AHB-AP (IDR: Not set)
AP[0]: Core found
AP[0]: AHB-AP ROM base: 0xE00FD000
CPUID register: 0x411FC271. Implementer code: 0x41 (ARM)
Found Cortex-M7 r1p1, Little endian.
FPUnit: 8 code (BP) slots and 0 literal slots
CoreSight components:
ROMTbl[0] @ E00FD000
Cache: No cache
Cortex-M7 identified.
有时候他会有detect到cache,而且也会有coresight
J-Link>connect
AP[0]: Core found
ROMTbl[0][0]: E00FE000, CID: B105100D, PID: 000BB4C8 ROM Table
ROMTbl[1] @ E00FE000
ROMTbl[1][0]: E00FF000, CID: B105100D, PID: 000BB4C7 ROM Table
ROMTbl[2] @ E00FF000
ROMTbl[2][0]: E000E000, CID: B105E00D, PID: 000BB00C SCS-M7
ROMTbl[2][1]: E0001000, CID: B105E00D, PID: 000BB002 DWT
ROMTbl[2][2]: E0002000, CID: B105E00D, PID: 000BB00E FPB-M7
ROMTbl[2][3]: E0000000, CID: B105E00D, PID: 000BB001 ITM
ROMTbl[1][1]: E0041000, CID: B105900D, PID: 001BB975 ETM-M7
ROMTbl[1][2]: E0042000, CID: B105900D, PID: 004BB906 CTI
ROMTbl[0][1]: E0040000, CID: B105900D, PID: 000BB9A9 TPIU-M7
ROMTbl[0][2]: E0043000, CID: B105F00D, PID: 001BB101 TSG
Cache: Separate I- and D-cache.
I-Cache L1: 32 KB, 512 Sets, 32 Bytes/Line, 2-Way
D-Cache L1: 32 KB, 256 Sets, 32 Bytes/Line, 4-Way
发表于 2019-3-16 08:36:22 | 显示全部楼层
他应该进度停止显示了,但还在正常验证的吧,等一下就能完成的
 楼主| 发表于 2019-3-17 22:56:02 来自手机 | 显示全部楼层
哪个進度条
 楼主| 发表于 2019-6-16 11:44:09 来自手机 | 显示全部楼层
這後來發現是我不小心弄壞了mcu  :p
GMT+8, 2025-4-9 16:08 , Processed in 0.061841 second(s), 25 queries , Gzip On.
