查看: 12015|回复: 1
硬件IIC从机无应答
发表于 2019-4-12 11:16:48 | 显示全部楼层 |阅读模式
本人现在正在做两片STM32的IIC通讯主机选用的是IO模拟IIC而从机是通过硬件IIC中断来做的,直接上从机程序:
static void I2C_GPIO_Config(void)
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB,ENABLE);
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6;//scl
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_OD;
        GPIO_InitStructure.GPIO_Pin = GPIO_Speed_50MHz;
        GPIO_Init(GPIOB,&GPIO_InitStructure);
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_7;//sda
static void I2C_Mode_Config(void)
        I2C_InitTypeDef I2C_InitStructure;
        RCC_APB1PeriphClockCmd(RCC_APB1Periph_I2C1,ENABLE);
        I2C_DeInit(I2C1);
        I2C_InitStructure.I2C_Mode = I2C_Mode_I2C;
        I2C_InitStructure.I2C_DutyCycle = I2C_DutyCycle_2;
        I2C_InitStructure.I2C_OwnAddress1 = 0X30;
        I2C_InitStructure.I2C_Ack = I2C_Ack_Enable;
        I2C_InitStructure.I2C_ClockSpeed = 100000;
        I2C_InitStructure.I2C_AcknowledgedAddress = I2C_AcknowledgedAddress_7bit;
        I2C_Init(I2C1,&I2C_InitStructure);
        I2C_ITConfig(I2C1,(I2C_IT_ERR |I2C_IT_EVT |I2C_IT_BUF),ENABLE);
        I2C_Cmd(I2C1,ENABLE);
void I2C_clear_ADDR(I2C_TypeDef* I2Cx)
        I2C_GetFlagStatus(I2Cx, I2C_FLAG_ADDR);
        ((void)(I2Cx->SR2));
void I2C_clear_STOPF(I2C_TypeDef* I2Cx) {
        I2C_GetFlagStatus(I2Cx, I2C_FLAG_STOPF);
        I2C_Cmd(I2Cx, ENABLE);
void I2C_SLAVE_Init(void)
        I2C_GPIO_Config();
        I2C_Mode_Config();
  * @brief  This function handles I2C1_EV_IRQHandler
  * @param  None
  * @retval None
void I2C1_EV_IRQHandler()
        if(I2C_GetITStatus(I2C1,I2C_IT_AF))
                I2C_ClearITPendingBit(I2C1,I2C_IT_AF);
        switch(I2C_GetLastEvent(I2C1))
                case I2C_EVENT_SLAVE_RECEIVER_ADDRESS_MATCHED:
                        I2C_clear_ADDR(I2C1);
                break;
                case I2C_EVENT_SLAVE_BYTE_RECEIVED:
                        iic_flag.Buffer_Rx_IIC1[iic_flag.Rx_Idx_IIC1++] = I2C_ReceiveData(I2C1);
                        if(iic_flag.Rx_Idx_IIC1 >= 2) iic_flag.Rx_Idx_IIC1 =0;
                        switch(iic_flag.Buffer_Rx_IIC1[0])
                                case 0x10:
                                        iic_flag.Buffer_Tx_IIC1[0] = 0x21;
                                break;
                                case 0x12:
                                        iic_flag.Buffer_Tx_IIC1[0] = 0x44;
                                break;
                                case 0x23:
                                        iic_flag.Buffer_Tx_IIC1[0] = 0x76;
                                break;
                                case 0x34:
                                        iic_flag.Buffer_Tx_IIC1[0] = 0x67;
                                break;
                                default: break;
                        if(I2C_GetFlagStatus(I2C1,I2C_FLAG_DUALF))
                        else if(I2C_GetFlagStatus(I2C1,I2C_FLAG_GENCALL))
                break;
                case I2C_EVENT_SLAVE_STOP_DETECTED:
                        I2C_clear_STOPF(I2C1);
                break;
                case I2C_EVENT_SLAVE_TRANSMITTER_ADDRESS_MATCHED:
                        I2C_SendData(I2C1,0X00);
                break;
                case I2C_EVENT_SLAVE_BYTE_TRANSMITTED:
                        I2C_GetFlagStatus(I2C1,I2C_FLAG_BTF);
                        I2C_SendData(I2C1,iic_flag.Buffer_Tx_IIC1[iic_flag.Tx_Idx_IIC1++]);
                        if(iic_flag.Tx_Idx_IIC1>2) iic_flag.Tx_Idx_IIC1=0;
                break;
                case I2C_EVENT_SLAVE_ACK_FAILURE:
                break;
                case I2C_EVENT_SLAVE_TRANSMITTER_SECONDADDRESS_MATCHED:
                break;
                case I2C_EVENT_SLAVE_GENERALCALLADDRESS_MATCHED:
                break;
                default:
                        break;
        //I2C1->CR1 |= 0X0001;
        __IO u16 SR1Register =0;
        __IO u16 SR2Register =0;
        SR1Register = I2C1->SR1;
        SR2Register = I2C1->SR2;
        //判断I2C是从机模式-最低位(MSL=0)
        if((SR2Register&0x0001)!=0x0001)
                //ADDR:根据状态判断获取从机IIC地址成功
                if((SR1Register&0X0002) == 0X0002)
                SR1Register =0;
                SR2Register =0;
                iic_flag.Tx_Idx_IIC1 =0;
                //接收数据(RXNE=1:EV2)
                if((SR1Register& 0X0040) == 0X0040)
                        iic_flag.Buffer_Rx_IIC1[iic_flag.Rx_Idx_IIC1++] = I2C1->DR;
                        SR1Register = 0;
                        SR2Register = 0;
                        case 0x10:
                        break;
                        case 0x12:
                        break;
                        case 0x23:
                        break;
                        case 0x34:
                        break;
                        default: break;
                //检测到停止条件(STOP=1:EV4)
                if((SR1Register&0X0010) == 0X0010)
                        I2C1->CR1 |= 0x0001;
                        SR1Register =0;
                        SR2Register =0;
                        iic_flag.Flag_RcvOK_IIC1 =1;
                //发送数据(TxE = 1:EV3,EV3-1)
                if((SR1Register&0X0080) == 0X0080)
                        SR1Register = 0;
                        SR2Register = 0;
                        I2C1->DR = 0X21;//iic_flag.Buffer_Tx_IIC1[iic_flag.Tx_Idx_IIC1++];
                //检测到非应答
                if((SR1Register&0X0400) == 0X0400)
                        I2C1->SR1 &= 0XFDFF;
                        SR1Register =0;
                        SR2Register =0;
void NVIC_Config_Init(void)
        NVIC_InitStructure.NVIC_IRQChannel = I2C1_EV_IRQn;
        NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority =1 ;
        NVIC_InitStructure.NVIC_IRQChannel = I2C1_ER_IRQn;
        NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority =2 ;
void Handware_Init(void)
        //SysTick_Init();
        I2C_SLAVE_Init();
        NVIC_Config_Init();
        //USB_USART_Config();
  * @brief  主函数
  * @param  无
  * @retval 无
        Handware_Init();
                if(timflag.Timing500msFlag==1)
                        timflag.Timing500msFlag=0;
                        //printf("rxdata[0]=%d\r\n",iic_flag.Buffer_Rx_IIC1[0]);
                        //printf("rxdata[1]=%d\r\n",iic_flag.Buffer_Rx_IIC1[1]);
                if(iic_flag.Flag_RcvOK_IIC1 ==1)
                                case 0x10:
                                        printf("电压值volt:%d\r\n",iic_flag.Buffer_Rx_IIC1[1]);
                                break;
                                case 0x12:
                                        printf("电流值cur:%d\r\n",iic_flag.Buffer_Rx_IIC1[1]);
                                break;
                                case 0x23:
                                        printf("额定功率:%d\r\n",iic_flag.Buffer_Rx_IIC1[1]);
                                break;
                                case 0x34:
                                        printf("时间time:%d\r\n",iic_flag.Buffer_Rx_IIC1[1]);
                                break;
                                default: break;
                        //memset(iic_flag.Buffer_Rx_IIC1,0,20);
                        //memset(iic_flag.Buffer_Tx_IIC1,0,20);
                        iic_flag.Flag_RcvOK_IIC1=0;
总体程序大致如此,主循环里面都屏蔽了,主要就是IIC配置和中断函数了
但是我通过示波器并没有发现有应答,而且SR1寄存器总是出现0X0110,代表总线错误和检测到停止信号,有时候会进入地址匹配SR1 = 0x0112;现在真的是黔驴技穷了
希望大佬帮忙
发表于 2019-4-13 08:50:46 | 显示全部楼层
        I2C_DeInit(I2C1);
先Disable再初始化
GMT+8, 2024-11-23 03:18 , Processed in 0.027897 second(s), 23 queries , Gzip On.
