查看: 18437|回复: 2
FLASH读保护设置问题
发表于 2019-4-21 17:27:27 | 显示全部楼层 |阅读模式
各位同学好,我在看STM32F07的FLASH读写保护的知识,目前是运行的开发板的例程,但是发现不能修改保护级别为1级, 一直是0级。
这里是代码:
FLASH_OB_Unlock();
FLASH_ClearFlag(FLASH_FLAG_EOP | FLASH_FLAG_OPERR | FLASH_FLAG_WRPERR |
FLASH_FLAG_PGAERR | FLASH_FLAG_PGPERR|FLASH_FLAG_PGSERR);
FLASH_OB_RDPConfig(OB_RDP_Level_1);
status=FLASH_OB_Launch();
status = FLASH_WaitForLastOperation();
这里是书上的描述:
Modifying user option bytes on STM32F405xx/07xx and STM32F415xx/17xx
To modify the user option value, follow the sequence below:
1. Check that no Flash memory operation is ongoing by checking the BSY bit in the
FLASH_SR register
2. Write the desired option value in the FLASH_OPTCR register.
3. Set the option start bit (OPTSTRT) in the FLASH_OPTCR register
4. Wait for the BSY bit to be cleared.
发表于 2019-4-22 14:25:59 | 显示全部楼层
修改之后要重新上电复位
 楼主| 发表于 2019-4-27 16:46:36 | 显示全部楼层
多谢,回头试试!
GMT+8, 2025-12-14 11:25 , Processed in 0.037754 second(s), 24 queries , Gzip On.
