查看: 12727|回复: 3
自己编译的内核,启动失败
发表于 2019-12-17 22:41:23 | 显示全部楼层 |阅读模式
参照 http://tutorial.linux.doc.embedf ... uilding_kernel.html 下载、编译内核。
没把内核烧到mmc,用以下命令启动内核
[mw_shl_code=c,true]nfs 80800000 192.168.0.2:/nfsroot/zImage
nfs ${fdt_addr} 192.168.0.2:/nfsroot/imx6ull-14x14-evk-gpmi-weim-50-70-dht11-leds.dtb
bootz ${loadaddr} - ${fdt_addr}[/mw_shl_code]
结果报错:
[mw_shl_code=c,true]VFS: Cannot open root device "(null)" or unknown-block(0,0): error -6
Please append a correct "root=" boot option; here are the available partitions:
0100           65536 ram0  (driver?)
0101           65536 ram1  (driver?)
0102           65536 ram2  (driver?)
0103           65536 ram3  (driver?)
0104           65536 ram4  (driver?)
0105           65536 ram5  (driver?)
0106           65536 ram6  (driver?)
0107           65536 ram7  (driver?)
0108           65536 ram8  (driver?)
0109           65536 ram9  (driver?)
010a           65536 ram10  (driver?)
010b           65536 ram11  (driver?)
010c           65536 ram12  (driver?)
010d           65536 ram13  (driver?)
010e           65536 ram14  (driver?)
010f           65536 ram15  (driver?)
Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0)
---[ end Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0)
drivers/leds/led-core.c,    led_set_brightness,    121
[/mw_shl_code]
跪求大佬解答如何修改?
 楼主| 发表于 2019-12-17 22:53:51 | 显示全部楼层
已解决,用如下命令
[mw_shl_code=c,true]run mmcargs
nfs 80800000 192.168.0.2:/nfsroot/zImage;nfs ${fdt_addr} 192.168.0.2:/nfsroot/imx6ull-14x14-evk-emmc-50-70-dht11-leds.dtb;bootz ${loadaddr} - ${fdt_addr}
[/mw_shl_code]
发表于 2020-1-20 18:31:39 | 显示全部楼层
发表于 2020-9-13 09:27:47 | 显示全部楼层
楼主,你这个编译的内核是4.1.15的nxp的版本吗,你是怎么把zImage烧写到板子里面的,这个指令是uboot的启动命令吗。你这个是再uboot启动时键盘按键打断之后,手工启动你自己的内核是吗?那么你的内核文件zImage放在哪里的呢,
GMT+8, 2025-4-23 07:07 , Processed in 0.079514 second(s), 24 queries , Gzip On.
