查看: 27448|回复: 5
为什么我RCC->出来的是uint32_t,GPIOB->也是uint32_t
发表于 2020-2-5 19:38:58 | 显示全部楼层 |阅读模式
stm32f10x.h
/*片上外设基地址 */
#define                        PERIPH_BASE        ((unsigned int)0x40000000)
/*总线基地址,GPIO 都挂载到 APB2 上 */
#define                        APB2PERIPH_BASE        (PERIPH_BASE+0x10000)
#define                        AHBPERIPH_BASE        (PERIPH_BASE+0x20000)
/*GPIO外设基地址*/
#define                        GPIOA_BASE        (APB2PERIPH_BASE+0x0800)
#define                        GPIOB_BASE        (APB2PERIPH_BASE+0x0C00)
#define                        GPIOC_BASE        (APB2PERIPH_BASE+0x1000)
#define                        GPIOD_BASE        (APB2PERIPH_BASE+0x1400)
#define                        GPIOE_BASE        (APB2PERIPH_BASE+0x1800)
#define                        GPIOF_BASE        (APB2PERIPH_BASE+0x1C00)
#define                        GPIOG_BASE        (APB2PERIPH_BASE+0x2000)
/*RCC 外设基地址*/
#define                        RCC_BASE        (AHBPERIPH_BASE+0x1000)
typedef unsigned int      uint32_t;
typedef unsigned short    uint16_t;
//GPIO寄存器结构体定义
typedef struct
        uint32_t CRL;
        uint32_t CRH;
        uint32_t IDR;
        uint32_t ODR;
        uint32_t BSRR;
        uint32_t BRR;
        uint32_t LCKR;
}GPIO_TypeDef;
//GPIO外设声明
#define                GPIOA                                        ((GPIO_TypeDef *) GPIOA_BASE)
#define                 GPIOB                                           ((GPIO_TypeDef *) GPIOB_BASE)
#define                GPIOC                                        ((GPIO_TypeDef *) GPIOC_BASE)
#define                GPIOD                                        ((GPIO_TypeDef *) GPIOD_BASE)
#define                GPIOE                                        ((GPIO_TypeDef *) GPIOE_BASE)
#define                GPIOF                                        ((GPIO_TypeDef *) GPIOF_BASE)
#define                GPIOG                                        ((GPIO_TypeDef *) GPIOG_BASE)
//RCC寄存器结构体定义
typedef struct
        uint32_t CR;
        uint32_t CFGR;
        uint32_t CIR;
        uint32_t APB2RSTR;
        uint32_t APB1RSTR;
        uint32_t AHBENR;
        uint32_t APB2ENR;
        uint32_t APB1ENR;
        uint32_t BDCR;
        uint32_t CSR;
}RCC_TypeDef;
发表于 2020-2-5 21:17:11 | 显示全部楼层
把工程放到没有中文路径地方试试
 楼主| 发表于 2020-2-6 12:47:21 | 显示全部楼层
WishWish 发表于 2020-2-5 21:17
把工程放到没有中文路径地方试试
这是什么原因
发表于 2020-2-6 14:00:30 | 显示全部楼层
字面意思 换GPIOB.ODR
 楼主| 发表于 2020-2-6 15:17:41 | 显示全部楼层
WishWish 发表于 2020-2-6 14:00
字面意思 换GPIOB.ODR
问题找到了,是第一行那个宏最后用了中文的括号。谢了!
发表于 2021-2-28 22:07:20 | 显示全部楼层
我也是,为啥不直接弹出定义好的寄存器
GMT+8, 2024-11-23 17:24 , Processed in 0.034255 second(s), 27 queries , Gzip On.
