查看: 15412|回复: 3
STM32H743PRO开发板下载程序问题
发表于 2020-3-8 10:13:59 | 显示全部楼层 |阅读模式
[size=13.3333px]下载配套例程“5-GPIO输出—使用固件库点亮LED灯”程序,出现如下问题:
[size=13.3333px]
[size=13.3333px]1.程序编译无错误:
[size=13.3333px]*** Using Compiler 'V5.06 update 4 (build 422)', folder: 'C:\Keil_v5\ARM\ARMCC\Bin'
Build target 'Fire_H7'
"..\..\Output\Fire_H7.axf" - 0 Error(s), 0 Warning(s).
Build Time Elapsed:  00:00:01
2、下载到开发板出现如下问题:
Load "..\\..\\Output\\Fire_H7.axf"
Erase Done.
Programming Done.
Contents mismatch at: 08000060H  (Flash=FFH  Required=C7H) !
Contents mismatch at: 08000061H  (Flash=FFH  Required=02H) !
Contents mismatch at: 08000062H  (Flash=FFH  Required=00H) !
Contents mismatch at: 08000063H  (Flash=FFH  Required=08H) !
Contents mismatch at: 08000064H  (Flash=FFH  Required=C7H) !
Contents mismatch at: 08000065H  (Flash=FFH  Required=02H) !
Contents mismatch at: 08000066H  (Flash=FFH  Required=00H) !
Contents mismatch at: 08000067H  (Flash=FFH  Required=08H) !
Contents mismatch at: 08000068H  (Flash=FFH  Required=C7H) !
Contents mismatch at: 08000069H  (Flash=FFH  Required=02H) !
Contents mismatch at: 0800006AH  (Flash=FFH  Required=00H) !
Contents mismatch at: 0800006BH  (Flash=FFH  Required=08H) !
Contents mismatch at: 0800006CH  (Flash=FFH  Required=C7H) !
Contents mismatch at: 0800006DH  (Flash=FFH  Required=02H) !
Contents mismatch at: 0800006EH  (Flash=FFH  Required=00H) !
Contents mismatch at: 0800006FH  (Flash=FFH  Required=08H) !
Contents mismatch at: 08000070H  (Flash=FFH  Required=C7H) !
Contents mismatch at: 08000071H  (Flash=FFH  Required=02H) !
Contents mismatch at: 08000072H  (Flash=FFH  Required=00H) !
Contents mismatch at: 08000073H  (Flash=FFH  Required=08H) !
Contents mismatch at: 08000074H  (Flash=FFH  Required=C7H) !
Contents mismatch at: 08000075H  (Flash=FFH  Required=02H) !
Contents mismatch at: 08000076H  (Flash=FFH  Required=00H) !
Contents mismatch at: 08000077H  (Flash=FFH  Required=08H) !
Contents mismatch at: 08000078H  (Flash=FFH  Required=C7H) !
Contents mismatch at: 08000079H  (Flash=FFH  Required=02H) !
Contents mismatch at: 0800007AH  (Flash=FFH  Required=00H) !
Contents mismatch at: 0800007BH  (Flash=FFH  Required=08H) !
Contents mismatch at: 0800007CH  (Flash=FFH  Required=C7H) !
Contents mismatch at: 0800007DH  (Flash=FFH  Required=02H) !
Contents mismatch at: 0800007EH  (Flash=FFH  Required=00H) !
Contents mismatch at: 0800007FH  (Flash=FFH  Required=08H) !
Contents mismatch at: 08000080H  (Flash=FFH  Required=C7H) !
Contents mismatch at: 08000081H  (Flash=FFH  Required=02H) !
Contents mismatch at: 08000082H  (Flash=FFH  Required=00H) !
Contents mismatch at: 08000083H  (Flash=FFH  Required=08H) !
Contents mismatch at: 08000084H  (Flash=FFH  Required=C7H) !
Contents mismatch at: 08000085H  (Flash=FFH  Required=02H) !
Contents mismatch at: 08000086H  (Flash=FFH  Required=00H) !
Contents mismatch at: 08000087H  (Flash=FFH  Required=08H) !
Contents mismatch at: 08000088H  (Flash=FFH  Required=C7H) !
Contents mismatch at: 08000089H  (Flash=FFH  Required=02H) !
Contents mismatch at: 0800008AH  (Flash=FFH  Required=00H) !
Contents mismatch at: 0800008BH  (Flash=FFH  Required=08H) !
Contents mismatch at: 0800008CH  (Flash=FFH  Required=C7H) !
Contents mismatch at: 0800008DH  (Flash=FFH  Required=02H) !
Contents mismatch at: 0800008EH  (Flash=FFH  Required=00H) !
Contents mismatch at: 0800008FH  (Flash=FFH  Required=08H) !
Contents mismatch at: 08000090H  (Flash=FFH  Required=C7H) !
Contents mismatch at: 08000091H  (Flash=FFH  Required=02H) !
Contents mismatch at: 08000092H  (Flash=FFH  Required=00H) !
Contents mismatch at: 08000093H  (Flash=FFH  Required=08H) !
Contents mismatch at: 08000094H  (Flash=FFH  Required=C7H) !
Contents mismatch at: 08000095H  (Flash=FFH  Required=02H) !
Contents mismatch at: 08000096H  (Flash=FFH  Required=00H) !
Contents mismatch at: 08000097H  (Flash=FFH  Required=08H) !
Contents mismatch at: 08000098H  (Flash=FFH  Required=C7H) !
Contents mismatch at: 08000099H  (Flash=FFH  Required=02H) !
Contents mismatch at: 0800009AH  (Flash=FFH  Required=00H) !
Contents mismatch at: 0800009BH  (Flash=FFH  Required=08H) !
Contents mismatch at: 0800009CH  (Flash=FFH  Required=C7H) !
Contents mismatch at: 0800009DH  (Flash=FFH  Required=02H) !
Contents mismatch at: 0800009EH  (Flash=FFH  Required=00H) !
Contents mismatch at: 0800009FH  (Flash=FFH  Required=08H) !
Contents mismatch at: 080000C0H  (Flash=FFH  Required=C7H) !
Contents mismatch at: 080000C1H  (Flash=FFH  Required=02H) !
Contents mismatch at: 080000C2H  (Flash=FFH  Required=00H) !
Contents mismatch at: 080000C3H  (Flash=FFH  Required=08H) !
Contents mismatch at: 080000C4H  (Flash=FFH  Required=C7H) !
Contents mismatch at: 080000C5H  (Flash=FFH  Required=02H) !
Contents mismatch at: 080000C6H  (Flash=FFH  Required=00H) !
Contents mismatch at: 080000C7H  (Flash=FFH  Required=08H) !
Contents mismatch at: 080000C8H  (Flash=FFH  Required=C7H) !
Contents mismatch at: 080000C9H  (Flash=FFH  Required=02H) !
Contents mismatch at: 080000CAH  (Flash=FFH  Required=00H) !
Contents mismatch at: 080000CBH  (Flash=FFH  Required=08H) !
Contents mismatch at: 080000CCH  (Flash=FFH  Required=C7H) !
Contents mismatch at: 080000CDH  (Flash=FFH  Required=02H) !
Contents mismatch at: 080000CEH  (Flash=FFH  Required=00H) !
Contents mismatch at: 080000CFH  (Flash=FFH  Required=08H) !
Contents mismatch at: 080000D0H  (Flash=FFH  Required=C7H) !
Contents mismatch at: 080000D1H  (Flash=FFH  Required=02H) !
Contents mismatch at: 080000D2H  (Flash=FFH  Required=00H) !
Contents mismatch at: 080000D3H  (Flash=FFH  Required=08H) !
Contents mismatch at: 080000D4H  (Flash=FFH  Required=C7H) !
Contents mismatch at: 080000D5H  (Flash=FFH  Required=02H) !
Contents mismatch at: 080000D6H  (Flash=FFH  Required=00H) !
Contents mismatch at: 080000D7H  (Flash=FFH  Required=08H) !
Contents mismatch at: 080000D8H  (Flash=FFH  Required=C7H) !
Contents mismatch at: 080000D9H  (Flash=FFH  Required=02H) !
Contents mismatch at: 080000DAH  (Flash=FFH  Required=00H) !
Contents mismatch at: 080000DBH  (Flash=FFH  Required=08H) !
Contents mismatch at: 080000DCH  (Flash=FFH  Required=C7H) !
Contents mismatch at: 080000DDH  (Flash=FFH  Required=02H) !
Contents mismatch at: 080000DEH  (Flash=FFH  Required=00H) !
Contents mismatch at: 080000DFH  (Flash=FFH  Required=08H) !
Contents mismatch at: 08000100H  (Flash=FFH  Required=C7H) !
Contents mismatch at: 08000101H  (Flash=FFH  Required=02H) !
Contents mismatch at: 08000102H  (Flash=FFH  Required=00H) !
Contents mismatch at: 08000103H  (Flash=FFH  Required=08H) !
Too many errors to display !
Error: Flash Download failed  -  "Cortex-M7"
Flash Load finished at 10:10:06
3. KILE版本 V5.23.0.0
配置与例程一致。
请帮助解决
4、单独使用核心板下载程序也是如上问题,底板肯定没有故障,问题出在核心板上
5、刚买的板子,第一次使用,以前一直在用正点原子的阿波罗板子,这回改用野火的板子出现这样的问题,搞了两天都没有搞好;后来把程序修改移植到正点原子阿波罗H743板子上,KILE配置一样,可以正常运行,实在是搞不明白啦,请火哥帮助解决一下,谢谢
发表于 2020-3-8 11:17:06 | 显示全部楼层
 楼主| 发表于 2020-3-9 19:43:44 | 显示全部楼层
WishWish 发表于 2020-3-8 11:17
http://www.firebbs.cn/forum.php?mod=viewthread&tid=27711&extra=
是不是要安装H7 2.3.1固件,才能正常下载?
发表于 2020-3-9 22:13:58 | 显示全部楼层
芯片丝印是743V 就要
GMT+8, 2024-11-26 08:23 , Processed in 0.032318 second(s), 27 queries , Gzip On.
