初中生
最后登录1970-1-1
在线时间 小时
注册时间2020-1-19
uint32_t I2C_EE_PageWrite(u8* pBuffer, u8 WriteAddr, u8 NumByteToWrite)
I2CTimeout = I2CT_LONG_TIMEOUT;
while(I2C_GetFlagStatus(EEPROM_I2Cx, I2C_FLAG_BUSY))
if((I2CTimeout--) == 0) return I2C_TIMEOUT_UserCallback(4);
/* Send START condition */
I2C_GenerateSTART(EEPROM_I2Cx, ENABLE);
I2CTimeout = I2CT_FLAG_TIMEOUT;
/* Test on EV5 and clear it */
while(!I2C_CheckEvent(EEPROM_I2Cx, I2C_EVENT_MASTER_MODE_SELECT))
if((I2CTimeout--) == 0) return I2C_TIMEOUT_UserCallback(5);
/* Send EEPROM address for write */
I2C_Send7bitAddress(EEPROM_I2Cx, EEPROM_ADDRESS, I2C_Direction_Transmitter);
/* Test on EV6 and clear it */
while(!I2C_CheckEvent(EEPROM_I2Cx, I2C_EVENT_MASTER_TRANSMITTER_MODE_SELECTED))
if((I2CTimeout--) == 0) return I2C_TIMEOUT_UserCallback(6);
/* Send the EEPROM's internal address to write to */
I2C_SendData(EEPROM_I2Cx, WriteAddr);
/* Test on EV8 and clear it */
while(! I2C_CheckEvent(EEPROM_I2Cx, I2C_EVENT_MASTER_BYTE_TRANSMITTED))
if((I2CTimeout--) == 0) return I2C_TIMEOUT_UserCallback(7);
/* While there is data to be written */
while(NumByteToWrite--)
/* Send the current byte */
I2C_SendData(EEPROM_I2Cx, *pBuffer);
/* Point to the next byte to be written */
pBuffer++;
while (!I2C_CheckEvent(EEPROM_I2Cx, I2C_EVENT_MASTER_BYTE_TRANSMITTED))
if((I2CTimeout--) == 0) return I2C_TIMEOUT_UserCallback(8);
/* Send STOP condition */
I2C_GenerateSTOP(EEPROM_I2Cx, ENABLE);
return 1;
oid I2C_EE_BufferWrite(u8* pBuffer, u8 WriteAddr, u16 NumByteToWrite)
u8 NumOfPage = 0, NumOfSingle = 0, Addr = 0, count = 0;
Addr = WriteAddr % I2C_PageSize;
count = I2C_PageSize - Addr;
NumOfPage = NumByteToWrite / I2C_PageSize;
NumOfSingle = NumByteToWrite % I2C_PageSize;
/* If WriteAddr is I2C_PageSize aligned */
if(Addr == 0)
/* If NumByteToWrite < I2C_PageSize */
if(NumOfPage == 0)
I2C_EE_PageWrite(pBuffer, WriteAddr, NumOfSingle);
I2C_EE_WaitEepromStandbyState();
/* If NumByteToWrite > I2C_PageSize */
while(NumOfPage--)
I2C_EE_PageWrite(pBuffer, WriteAddr, I2C_PageSize);
WriteAddr += I2C_PageSize;
pBuffer += I2C_PageSize;
if(NumOfSingle!=0)
/* If WriteAddr is not I2C_PageSize aligned */
if(NumOfPage== 0)
NumByteToWrite -= count;
if(count != 0)
I2C_EE_PageWrite(pBuffer, WriteAddr, count);
WriteAddr += count;
pBuffer += count;
while(NumOfPage--)
if(NumOfSingle != 0)
火哥为什么pBuffer指针在I2C_EE_PageWrite函数中自加了 I2C_SendData(EEPROM_I2Cx, *pBuffer);
pBuffer++; 但是在I2C_EE_BufferWrite当中又加上页面大小呢? while(NumOfPage--) {
pBuffer += I2C_PageSize;他自加的时候指针不是已经跳转了8次吗?再加不就多了吗?另外那个WriteAddr地址变量不是写一个数据就直接跳到下一个地址吗?为什么还是要加页面大小?他在页写的时候都没有地址变量自加,说明他是自己跳转啊,为什么还要加页面大小呢?请指教
