查看: 15876|回复: 3
wifi问题
发表于 2020-5-4 10:31:45 | 显示全部楼层 |阅读模式
Debian GNU/Linux 10 npi ttymxc0
embedfire.com Debian Image 2020-04-09
Support/FAQ: www.firebbs.cn/forum.php
default username:password is [debian:temppwd]
npi login: [   24.433003] [dhd] dhd_conf_read_config : Ignore config file /lib/firmware/bcm/AP6236/Wi-Fi/config.txt
[   24.442429] [dhd] dhd_conf_set_path_params : Final fw_path=/lib/firmware/bcm/AP6236/Wi-Fi/fw_bcm43436b0.bin
[   24.453853] [dhd] dhd_conf_set_path_params : Final nv_path=/lib/firmware/bcm/AP6236/Wi-Fi/nvram_ap6236.txt
[   24.464777] [dhd] dhd_conf_set_path_params : Final clm_path=/lib/firmware/bcm/AP6236/Wi-Fi/clm_bcm43436b0.blob
[   24.476075] [dhd] dhd_conf_set_path_params : Final conf_path=/lib/firmware/bcm/AP6236/Wi-Fi/config.txt
[   24.723461] [dhd] dhd_conf_set_txglom_params : txglom_mode=multi-desc
[   24.732235] [dhd] dhd_conf_set_txglom_params : txglomsize=36, deferred_tx_len=0
[   24.740856] [dhd] dhd_conf_set_txglom_params : txinrx_thres=128, dhd_txminmax=-1
[   24.749491] [dhd] dhd_conf_set_txglom_params : tx_max_offset=0, txctl_tmo_fix=300
[   24.758315] [dhd] dhd_conf_get_disable_proptx : fw_proptx=1, disable_proptx=-1
[   24.811413] [dhd] dhd_conf_set_country : set country CN, revision 0
[   24.828962] [dhd] dhd_conf_set_country : Country code: CN (CN/0)
[   24.841520] [dhd] CONFIG-ERROR) dhd_conf_set_intiovar : txbf setting failed -23
[   24.852639] [dhd] CONFIG-ERROR) dhd_conf_set_intiovar : ampdu_mpdu setting failed -29
[   25.858937] [dhd-wlan0] wl_run_escan : LEGACY_SCAN sync ID: 0, bssidx: 0
[   31.972133] [dhd-wlan0] wl_run_escan : LEGACY_SCAN sync ID: 1, bssidx: 0
debian
Password: [   38.117184] [dhd-wlan0] wl_run_escan : LEGACY_SCAN sync ID: 2, bssidx: 0
[   44.266014] [dhd-wlan0] wl_run_escan : LEGACY_SCAN sync ID: 3, bssidx: 0
 楼主| 发表于 2020-5-4 10:32:29 | 显示全部楼层
原来还能上wifi,现在成这样了,咋回事
 楼主| 发表于 2020-5-4 11:57:52 | 显示全部楼层
找到原因了。。。是因为wifi信号源太远,找不到当前连接的wifi
发表于 2020-8-26 10:58:38 | 显示全部楼层
你好,请问你后来是怎么弄的?
GMT+8, 2025-4-23 14:01 , Processed in 0.099569 second(s), 23 queries , Gzip On.
