查看: 8844|回复: 0
大数运算加法
发表于 2020-5-19 20:12:54 | 显示全部楼层 |阅读模式
  1. #include <stdio.h>
  2. #include <stdlib.h>
  3. #include <string.h>
  4. typedef int bool;
  5. #define false (-1)
  6. #define true (0)
  7. static bool char_check(char c) {
  8.     if (c > '9') {
  9.         return false;
  10.     }
  11.     if (c < '0') {
  12.         return false;
  13.     }
  14.     return true;
  15. }
  16. static bool str_check(const char* src) {
  17.     for ( ; *src; src++) {
  18.         if (false == char_check(*src)) {
  19.             return false;
  20.         }
  21.     }
  22.     return true;
  23. }
  24. static void str_reverse(char* s) {
  25.     char temp;
  26.     char* r = s + strlen(s) - 1;
  27.     while (s < r) {
  28.         temp = *s;
  29.         *s++ = *r;
  30.         *r-- = temp;
  31.     }
  32. }
  33. static bool char_add(char a, char b, char* c, char* d) {
  34.     if (false == char_check(a)) {
  35.         return false;
  36.     }
  37.     if (false == char_check(b)) {
  38.         return false;
  39.     }
  40.     a -= '0';
  41.     b -= '0';
  42.     *d = a + b + (*c);
  43.     if (*d > 9) {
  44.         *d -= 10;
  45.         *c = 1;
  46.     }
  47.     else {
  48.         *c = 0;
  49.     }
  50.     *d += '0';
  51.     return true;
  52. }
  53. static bool str_add(const char* a, const char* b, char* d) {
  54.     char aa, bb, c = 0;
  55.     int len_a = strlen(a), len_b = strlen(b);
  56.     char* p_a = a + len_a - 1;
  57.     char* p_b = b + len_b - 1;
  58.     char* p_d = d;
  59.     if (false == str_check(a)) {
  60.         return false;
  61.     }
  62.     if (false == str_check(b)) {
  63.         return false;
  64.     }
  65.     for ( ; (len_a > 0) || (len_b > 0); ) {
  66.         aa = len_a > 0? *p_a-- : '0';
  67.         bb = len_b > 0? *p_b-- : '0';
  68.         char_add(aa, bb, &c, p_d++);
  69.         len_a--;
  70.         len_b--;
  71.     }
  72.     str_reverse(d);
  73.     return true;
  74. }
  75. int main()
  76. {
  77.     char* a = "16664129129421912941294";
  78.     char* b = "34666666666543854397591";
  79.     char c[100] = "";
  80.     str_add(a, b, c);
  81.     printf("%s!\n", c);
  82.     return 0;
  83. }
GMT+8, 2025-4-4 10:34 , Processed in 0.073032 second(s), 24 queries , Gzip On.
