查看: 5192|回复: 1
[freertos] 编译时出错,求助各位大侠!
发表于 2020-7-6 19:45:36 | 显示全部楼层 |阅读模式
编译时,报错,报错信息如下:
Build started: Project: Ksec_FreeRTOS
*** Using Compiler 'V5.06 update 6 (build 750)', folder: 'C:\Program Files\Keil_v5\ARM\ARMCC\Bin'
Build target 'FreeFRTOS'
linking...
.\Objects\Ksec_FreeRTOS.axf: Error: L6218E: Undefined symbol vTaskSwitchContext (referred from port.o).
.\Objects\Ksec_FreeRTOS.axf: Error: L6218E: Undefined symbol listSET_LIST_ITEM_OWNER (referred from task.o).
Not enough information to list image symbols.
Not enough information to list load addresses in the image map.
Finished: 2 information, 0 warning and 2 error messages.
".\Objects\Ksec_FreeRTOS.axf" - 2 Error(s), 0 Warning(s).
Target not created.
Build Time Elapsed:  00:00:01
求助各位高手,这是什么原因呀?
发表于 2020-7-7 08:40:26 | 显示全部楼层
vTaskSwitchContext listSET_LIST_ITEM_OWNER
这两个函数找不到定义
GMT+8, 2025-7-30 09:15 , Processed in 0.130544 second(s), 26 queries , Gzip On.
