大学生
最后登录1970-1-1
在线时间 小时
注册时间2020-4-29
楼主 |
发表于 2020-7-14 09:46:26
显示全部楼层
/* TIM6 init function */
void MX_TIM6_Init(void)
TIM_MasterConfigTypeDef sMasterConfig = {0};
htim6.Instance = TIM6;
htim6.Init.Prescaler = 71;
htim6.Init.CounterMode = TIM_COUNTERMODE_UP;
htim6.Init.Period = 1000;
htim6.Init.AutoReloadPreload = TIM_AUTORELOAD_PRELOAD_ENABLE;
if (HAL_TIM_Base_Init(&htim6) != HAL_OK)
Error_Handler();
sMasterConfig.MasterOutputTrigger = TIM_TRGO_RESET;
sMasterConfig.MasterSlaveMode = TIM_MASTERSLAVEMODE_DISABLE;
if (HAL_TIMEx_MasterConfigSynchronization(&htim6, &sMasterConfig) != HAL_OK)
Error_Handler();
void HAL_TIM_Base_MspInit(TIM_HandleTypeDef* tim_baseHandle)
if(tim_baseHandle->Instance==TIM6)
/* USER CODE BEGIN TIM6_MspInit 0 */
/* USER CODE END TIM6_MspInit 0 */
/* TIM6 clock enable */
__HAL_RCC_TIM6_CLK_ENABLE();
/* TIM6 interrupt Init */
HAL_NVIC_SetPriority(TIM6_IRQn, 1, 0);
HAL_NVIC_EnableIRQ(TIM6_IRQn);
/* USER CODE BEGIN TIM6_MspInit 1 */
/* USER CODE END TIM6_MspInit 1 */
这是定时器配置,1ms中断一次,抢占优先级1
void HAL_UART_MspInit(UART_HandleTypeDef* uartHandle)
GPIO_InitTypeDef GPIO_InitStruct = {0};
if(uartHandle->Instance==UART4)
/* USER CODE BEGIN UART4_MspInit 0 */
/* USER CODE END UART4_MspInit 0 */
/* UART4 clock enable */
__HAL_RCC_UART4_CLK_ENABLE();
__HAL_RCC_GPIOC_CLK_ENABLE();
/**UART4 GPIO Configuration
PC10 ------> UART4_TX
PC11 ------> UART4_RX
GPIO_InitStruct.Pin = DIN4_Pin;
GPIO_InitStruct.Mode = GPIO_MODE_AF_PP;
GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_HIGH;
HAL_GPIO_Init(DIN4_GPIO_Port, &GPIO_InitStruct);
GPIO_InitStruct.Pin = DOUT4_Pin;
GPIO_InitStruct.Mode = GPIO_MODE_INPUT;
GPIO_InitStruct.Pull = GPIO_NOPULL;
HAL_GPIO_Init(DOUT4_GPIO_Port, &GPIO_InitStruct);
/* UART4 interrupt Init */
HAL_NVIC_SetPriority(UART4_IRQn, 0, 0);
HAL_NVIC_EnableIRQ(UART4_IRQn);
/* USER CODE BEGIN UART4_MspInit 1 */
/* USER CODE END UART4_MspInit 1 */
这是串口4配置,抢占优先级0,比定时器高。串口4是和智能液晶屏通信的,当屏幕上有按下操作,会返回一个键值
每定时到1s,我往串口4里写一次时间,现在是只有上电开机第一次写时间,接收到串口4返回了“O”“K”,接下来就怎么也进不到串口中断了,写时间也不返回值,按屏幕也不返回键值
