查看: 40911|回复: 0
STM32的DAC输出正弦波问题,求大佬指导
发表于 2020-8-24 11:44:49 | 显示全部楼层 |阅读模式
5火花
我用STM32的DAC输出一个如下图所示的正弦波,为何在最高点时会突然跌落,代码如下,请求大佬指导,谢谢啦
正弦输出函数
#include "bsp_dac.h"
#define POINT_NUM 256
const uint16_t Sine12bit[POINT_NUM] = {
        2148,2198,2248,2298,2347,2395,2443,2490,2536,2580,2624,2667,2708,2747,2785,2822,2856,2880,2920,2949,2976,3001,3023,3044,3062,
        3078,3091,3102,3111,3111,3111,3111,3111,3111,3111,3102,3091,3078,3062,3044,3023,3001,2976,2949,2920,2889,2856,2822,2785,2747,
        2708,2667,2624,2580,2536,2490,2443,2395,2347,2298,2248,2198,2148,2098,2048,1997,1947,1898,1849,1800,1753,1706,1660,1615,1571,
        1529,1488,1448,1410,1374,1339,1306,1275,1246,1219,1195,1172,1152,1134,1118,1104,1093,1085,1079,1075,1074,1075,1079,1085,1093,
        1104,1118,1134,1152,1172,1195,1219,1246,1275,1306,1339,1374,1410,1448,1488,1529,1571,1615,1660,1706,1753,1800,1849,1898,1947,
        1997,2048,2098,
        2148,2249,2349,2448,2546,2643,2738,2832,2924,3013,3101,3186,3268,3347,3423,3496,3565,3631,3693,3751,3805,3854,3899,3940,3976,
        4008,4035,4057,4074,4074,4074,4074,4074,4074,4074,4057,4035,4008,3976,3940,3899,3854,3805,3751,3693,3631,3565,3496,3423,3347,
        3268,3186,3101,3013,2924,2832,2738,2643,2546,2448,2349,2249,2148,2048,1948,1847,1747,1648,1550,1453,1358,1264,1172,1083,995,
        910,828,749,673,600,531,465,403,345,291,242,197,156,120,88,61,39,22,10,2,0,2,10,22,39,61,88,120,156,197,242,291,345,403,465,
        531,600,673,749,828,910,995,1083,1172,1264,1358,1453,1550,1648,1747,1847,1948,2048
uint32_t DualSine12bit[POINT_NUM];
  * @brief  Ê¹ÄÜDACµÄʱÖÓ£¬³õʼ»¯GPIO
  * @param  ÎÞ
  * @retval ÎÞ
static void DAC_Config(void)
        DAC_InitTypeDef  DAC_InitStructure;
  /* ʹÄÜGPIOAʱÖÓ */
        /* ʹÄÜDACʱÖÓ */
  RCC_APB1PeriphClockCmd(RCC_APB1Periph_DAC, ENABLE);
  /* DACµÄGPIOÅäÖã¬Ä£ÄâÊäÈë */
  GPIO_InitStructure.GPIO_Pin =    GPIO_Pin_4|GPIO_Pin_5;
  /* ÅäÖÃDAC ͨµÀ1 */
  DAC_InitStructure.DAC_Trigger = DAC_Trigger_T2_TRGO;                                                //ʹÓÃTIM2×÷Ϊ´¥·¢Ô´
  DAC_InitStructure.DAC_WaveGeneration = DAC_WaveGeneration_None;        //²»Ê¹Óò¨Ðη¢ÉúÆ÷
  DAC_InitStructure.DAC_OutputBuffer = DAC_OutputBuffer_Disable;        //²»Ê¹ÓÃDACÊä³ö»º³å
  DAC_Init(DAC_Channel_1, &DAC_InitStructure);
  /* ÅäÖÃDAC ͨµÀ2 */
  DAC_Init(DAC_Channel_2, &DAC_InitStructure);
  /* ʹÄÜͨµÀ1 ÓÉPA4Êä³ö */
  DAC_Cmd(DAC_Channel_1, ENABLE);
  /* ʹÄÜͨµÀ2 ÓÉPA5Êä³ö */
  DAC_Cmd(DAC_Channel_2, ENABLE);
  /* ʹÄÜDACµÄDMAÇëÇó */
  DAC_DMACmd(DAC_Channel_2, ENABLE);
  * @brief  ÅäÖÃTIM
  * @param  ÎÞ
  * @retval ÎÞ
static void DAC_TIM_Config(void)
        TIM_TimeBaseInitTypeDef    TIM_TimeBaseStructure;
        /* ʹÄÜTIM2ʱÖÓ£¬TIM2CLK Ϊ72M */
  RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2, ENABLE);
  /* TIM2»ù±¾¶¨Ê±Æ÷ÅäÖà */
// TIM_TimeBaseStructInit(&TIM_TimeBaseStructure);
  TIM_TimeBaseStructure.TIM_Period = (280-1);        //¶¨Ê±ÖÜÆÚ 20
  TIM_TimeBaseStructure.TIM_Prescaler = 0x0;                                                               //Ô¤·ÖƵ£¬²»·ÖƵ 72M / (0+1) = 72M
  TIM_TimeBaseStructure.TIM_ClockDivision = 0x0;                                                    //ʱÖÓ·ÖÆµÏµÊý
  TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;          //ÏòÉϼÆÊýģʽ
  TIM_TimeBaseInit(TIM2, &TIM_TimeBaseStructure);
  /* ÅäÖÃTIM2´¥·¢Ô´ */
  TIM_SelectOutputTrigger(TIM2, TIM_TRGOSource_Update);
        /* ʹÄÜTIM2 */
  TIM_Cmd(TIM2, ENABLE);
  * @brief  ÅäÖÃDMA
  * @param  ÎÞ
  * @retval ÎÞ
static void DAC_DMA_Config(void)
        DMA_InitTypeDef  DMA_InitStructure;
        /* ʹÄÜDMA2ʱÖÓ */
        RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA2, ENABLE);
        /* ÅäÖÃDMA2 */
  DMA_InitStructure.DMA_PeripheralBaseAddr = DAC_DHR12RD_ADDRESS;                                        //ÍâÉèÊý¾ÝµØÖ·
  DMA_InitStructure.DMA_MemoryBaseAddr = (uint32_t)&DualSine12bit ;                                //ÄÚ´æÊý¾ÝµØÖ· DualSine12bit
  DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralDST;        //Êý¾Ý´«Êä·½ÏòÄÚ´æÖÁÍâÉè
  DMA_InitStructure.DMA_BufferSize = POINT_NUM;        //»º´æ´óСΪPOINT_NUM×Ö½Ú
  DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;                                //ÍâÉèÊý¾ÝµØÖ·¹Ì¶¨
  DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;        //ÄÚ´æÊý¾ÝµØÖ·×ÔÔö
  DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_Word;        //ÍâÉèÊý¾ÝÒÔ×ÖΪµ¥Î»
  DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_Word;                                        //ÄÚ´æÊý¾ÝÒÔ×ÖΪµ¥Î»
  DMA_InitStructure.DMA_Mode = DMA_Mode_Circular;        //Ñ­»·Ä£Ê½
  DMA_InitStructure.DMA_Priority = DMA_Priority_High;        //¸ßDMAͨµÀÓÅÏȼ¶
  DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;        //·ÇÄÚ´æÖÁÄÚ´æÄ£Ê½
  DMA_Init(DMA2_Channel4, &DMA_InitStructure);
  /* ʹÄÜDMA2-14ͨµÀ */
  DMA_Cmd(DMA2_Channel4, ENABLE);
  * @brief  DAC³õʼ»¯º¯Êý
  * @param  ÎÞ
  * @retval ÎÞ
void DAC_Mode_Init(void)
        uint32_t Idx = 0;
        DAC_Config();
        DAC_TIM_Config();
        /* Ìî³äÕýÏÒ²¨ÐÎÊý¾Ý£¬Ë«Í¨µÀÓÒ¶ÔÆë*/
  for (Idx = 0; Idx < POINT_NUM; Idx++)
    DualSine12bit[Idx] = (Sine12bit[Idx]<<16) +Sine12bit[Idx];
        DAC_DMA_Config();
DAC输出波形如图所示
GMT+8, 2025-12-14 11:49 , Processed in 0.044339 second(s), 27 queries , Gzip On.
