查看: 11154|回复: 1
AGM AG6K,面向大批量成本敏感的应用FPGA器件
发表于 2020-8-25 09:26:34 | 显示全部楼层 |阅读模式
AG6K FPGA devices are targeted to high-volume, cost-sensitive, applications, enabling system designers to meet increasing performance requirements while lowering costs.
Features
  • High-density architecture with 6K LEs
  • M9K embedded memory blocks, up to 414Kbits of RAM space
  • Up to 23 18 x 18-bit embedded multipliers are each configurable as two independent 9 x 9-bit multipliers
  • Provides 2 PLLs per device provide clock multiplication and phase shifting
  • High-speed differential I/O standard support, including LVDS, RSDS, mini-LVDS, LVPECL
  • Single-ended I/O standard support, including 3.3V, 2.5V, 1.8V, and 1.5V LVCMOS and LVTTL
  • General package options, LQFP-144, -176 and FBGA-256
  • Flexible device configuration through JTAG and SPI interface
  • Support remote update, by "dual-boot" like implementation
  • Contact kh_hsiah@126.com for more detail information
AG6K FPGA器件面向大批量,对成本敏感的应用,使系统设计人员能够满足不断增长的性能要求,同时降低成本。
特征
  • 具有6K LE的高密度架构
  • M9K嵌入式内存块,最大414Kbit的RAM空间
  • 最多可将23个18 x 18位嵌入式乘法器配置为两个独立的9 x 9位乘法器
  • 每个器件提供2个PLL,提供时钟乘法和相移
  • 高速差分I / O标准支持,包括LVDS,RSDS,mini-LVDS,LVPECL
  • 单端I / O标准支持,包括3.3V,2.5V,1.8V和1.5V LVCMOS和LVTTL
  • 通用封装选项LQFP-144,-176和FBGA-256
  • 通过JTAG和SPI接口进行灵活的设备配置
  • 支持远程更新,通过“双重启动”之类的实现
  • 联系 kh_hsiah@126.com, 解锁更多技术及设计信息
发表于 2020-8-25 15:08:06 | 显示全部楼层
牛逼
GMT+8, 2025-4-22 12:54 , Processed in 0.117410 second(s), 24 queries , Gzip On.
