查看: 16359|回复: 0
[求助] 运行bluetoothctl后报错
发表于 2020-8-31 19:38:53 | 显示全部楼层 |阅读模式
[root@imx6ull]:~$:bluetoothctl
dbus[190]: arguments to dbus_connection_get_object_path_data() were incorrect, assertion "connection != NULL" failed in file dbus-connection.c line 5905.
This is normally a bug in some application using the D-Bus library.
  D-Bus not built with -rdynamic so unable to print a backtrace
Aborted
请问上述错误,该如何解决?
GMT+8, 2025-4-20 08:05 , Processed in 0.061243 second(s), 23 queries , Gzip On.
