查看: 20219|回复: 1
新手求助
发表于 2020-9-12 08:59:47 | 显示全部楼层 |阅读模式
#include "Key.h"
#include "SysTick.h"
#include "74HC595.h"
u8 key;
u8 keys[]={0,1,2,3,4,5,6,7,8,9,10,11};
void row_Configuration(void)
        GPIO_InitTypeDef GPIO_InitStructure;//定义初始化结构体
        RCC_APB2PeriphClockCmd( RCC_APB2Periph_GPIOA, ENABLE);//开外设端口时钟
        GPIO_InitStructure.GPIO_Pin = KEY_ROWS;//外设引脚号
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;//引脚模式
        GPIO_InitStructure.GPIO_Speed=GPIO_Speed_50MHz;
        GPIO_Init(GPIOA , &GPIO_InitStructure);//调用库函数初始化引脚
        GPIO_InitStructure.GPIO_Pin = KEY_COLS;//外设引脚号
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPD;//引脚模式下拉
        GPIO_WriteBit(GPIOA,KEY_ROWS,Bit_SET);
void col_Configuration(void)
        RCC_APB2PeriphClockCmd( KEY_CLK, ENABLE);//开外设端口时钟
        GPIO_Init(KEY_GPIOX , &GPIO_InitStructure);//调用库函数初始化引脚
        GPIO_InitStructure.GPIO_Mode =GPIO_Mode_Out_PP;//引脚模式
        GPIO_WriteBit(GPIOA,KEY_COLS,Bit_SET);
void Key_Value(void)
        u8 row;
        u8 col;
        u8 i;
        u8 make;
        u8 temp;
        u8 temp1;
        row_Configuration();
        make=GPIOA->IDR;
        make &= 0X7F;
        if(make != 0X0F)
                Delay_ms(30);
                if(make != 0X0F)
                        temp = GPIOA->IDR ;
                        temp &= 0x70;//应为是3*4矩阵丢掉最高位
                        switch(temp)//
                                case 0x40 : col=0;break;
                                case 0x20 : col=1;break;
                                case 0x10 : col=2;break;
                        col_Configuration();//翻转行列变化
                        temp1 = GPIOA->IDR ;
                        temp1 &= 0x7F;//应为是3*4矩阵丢掉最高位
                        switch(temp1)
                                case 0x71 : row=0;
                                break;
                                case 0x72 : row=1;
                                break;
                                case 0x74 : row=2;
                                break;
                                case 0x78 : row=3;
                                break;
                while(i!=0xE0)
                        i=GPIOA->IDR;
                        i &= 0xef;
        led8_display(0,1);
        led8_display(1,8);
        led8_display(2,4);
        key=keys[row*3+col];
        led8_display(3,key);
 楼主| 发表于 2020-9-12 09:13:27 | 显示全部楼层
我用行列扫描法写了个矩阵驱动,硬件调试数码管能显示按键值,实际使用的时候不行,到底哪个环节有问题新手不懂
GMT+8, 2024-11-25 11:51 , Processed in 0.031049 second(s), 23 queries , Gzip On.
