查看: 26362|回复: 0
求指教:DMA外设到存储没有返回值
发表于 2020-11-13 11:16:15 | 显示全部楼层 |阅读模式
===代码如下:
#include "stm32f10x.h"
#include <stdio.h>
#include <string.h>
//PC2 LED1
//PC3 LED2
//PA0 KEY1
//PA9 UART_TX
//PA10 UART_RX
void USART1_Configuration(void);
void RCC_Configuration(void);
void GPIO_Configuration(void);
int fputc(int ch, FILE *f);
void DMA_Configuration(void);
uint8_t SrcBuf[12] = "xxxxxxxxxxx";
//UART重定向
    if (ch == '\n')
        while (USART_GetFlagStatus(USART1, USART_FLAG_TC) == RESET);
        USART_SendData(USART1, '\r');
    USART_SendData(USART1, ch);
    return ch;
    SystemInit();
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1, ENABLE);
    GPIO_InitTypeDef GPIO_Stucturue;
    GPIO_StructInit(&GPIO_Stucturue);               //
    GPIO_Stucturue.GPIO_Pin = GPIO_Pin_9;           //usart1 TX
    GPIO_Stucturue.GPIO_Mode = GPIO_Mode_AF_PP;     //复用推挽输出
    GPIO_Init(GPIOA, &GPIO_Stucturue);
    GPIO_Stucturue.GPIO_Pin = GPIO_Pin_10;   //RX
    GPIO_Stucturue.GPIO_Mode = GPIO_Mode_IN_FLOATING; //浮空输入//复用开漏输入
    USART_InitStructure.USART_BaudRate = 115200;
    USART_InitStructure.USART_Mode = USART_Mode_Tx;
    USART_Init(USART1, &USART_InitStructure);
    USART_Cmd(USART1, ENABLE);
    DMA_DeInit(DMA1_Channel5);
    DMA_InitStructure.DMA_PeripheralBaseAddr = (uint32_t)&USART1->DR;//DR地址,
    DMA_InitStructure.DMA_MemoryBaseAddr = (uint32_t)SrcBuf;//数组名即为数组首地址
    DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC;//从外设读取数据
    DMA_InitStructure.DMA_BufferSize = 11;
    DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_Byte;
    DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_Byte;
    DMA_InitStructure.DMA_Mode = DMA_Mode_Normal;
    DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;//存储器到存储器ENABLE,存储器到外设DISABLE
    DMA_Init(DMA1_Channel5, &DMA_InitStructure);
int main()
    uint8_t flag = 1;
    RCC_Configuration();
    GPIO_Configuration();
    USART1_Configuration();
    //存储器到存储器DMA
    DMA_Configuration();
    //发送第一位数据之前,先清除TC标志,否则容易造成第一位发送不出去
    USART_ClearFlag(USART1, USART_FLAG_TC);
    USART_DMACmd(USART1, USART_DMAReq_Rx, ENABLE);
    DMA_Cmd(DMA1_Channel5, ENABLE);
    printf("hello\n");
    while (flag)
        if (strstr(SrcBuf, "LED")) //uint8_t SrcBuf[12] = "xxxxxxxxxxx";
        printf(SrcBuf);
            flag = 0;
        printf("NO");
        flag = 0;
===串口调试助手发送LED+回车,无返回值;
===求大哥们帮忙分析一下;小弟不才,在此谢过
GMT+8, 2024-11-25 07:08 , Processed in 0.030715 second(s), 26 queries , Gzip On.
