查看: 24781|回复: 0
I2C-EEPROM, 基于stm32f429, 读取的数据都为0
发表于 2021-1-24 16:09:43 | 显示全部楼层 |阅读模式
问题:通过IIC往EEPROM中写入一个数据 ,但是从该地址读取的数据总为0.
代码如下:
static void I2C_GPIO_Config(void)
        GPIO_InitTypeDef I2C_GPIO_InitStruct;
        RCC_AHB1PeriphClockCmd(I2C_SCL_CLK|I2C_SDA_CLK, ENABLE);
        GPIO_PinAFConfig(I2C_SDA_PORT, I2C_SDA_PINSOURCE, GPIO_AF_I2C1);
        GPIO_PinAFConfig(I2C_SCL_PORT, I2C_SCL_PINSOURCE, GPIO_AF_I2C1);
        I2C_GPIO_InitStruct.GPIO_Mode = GPIO_Mode_AF;
        I2C_GPIO_InitStruct.GPIO_OType = GPIO_OType_OD;   /*经测试必须是OD输出,而不能是PP输出*/
        I2C_GPIO_InitStruct.GPIO_PuPd = GPIO_PuPd_NOPULL;
        I2C_GPIO_InitStruct.GPIO_Speed = GPIO_Speed_50MHz;
        I2C_GPIO_InitStruct.GPIO_Pin = I2C_SCL_PIN;
        GPIO_Init(I2C_SCL_PORT, &I2C_GPIO_InitStruct);
        I2C_GPIO_InitStruct.GPIO_Pin = I2C_SDA_PIN;
        GPIO_Init(I2C_SDA_PORT, &I2C_GPIO_InitStruct);
void I2C_Config(void)
        I2C_GPIO_Config();
        RCC_APB1PeriphClockCmd(I2C_CLK, ENABLE);
        I2C_InitTypeDef I2C_InitStruct;
        I2C_InitStruct.I2C_Mode = I2C_Mode_I2C;
        I2C_InitStruct.I2C_ClockSpeed  = 400000;
        I2C_InitStruct.I2C_Ack = I2C_Ack_Enable ;
        I2C_InitStruct.I2C_DutyCycle = I2C_DutyCycle_2;
        I2C_InitStruct.I2C_OwnAddress1 = 0xA0;
        I2C_InitStruct.I2C_AcknowledgedAddress = I2C_AcknowledgedAddress_7bit;
        I2C_Init(I2C1, &I2C_InitStruct);
        I2C_Cmd (I2C1, ENABLE);
static uint32_t ErrorCallback(u8 error_code)
        printf("\r\nerror code:%hhd\n\r", error_code);
        return 1;
@brief: 写入一个字节
@para1: 指向1个字节数据源的指针
@retval: 状态值,0表示正常
uint8_t I2C_SendByte(uint8_t* pBuffer, uint8_t Addr_of_EE)
        I2C_GenerateSTART(I2C, ENABLE);
        uint32_t timer = TIMEOUT;
        while(!I2C_CheckEvent(I2C, I2C_EVENT_MASTER_MODE_SELECT))
                timer--;
                if(timer == 0)  ErrorCallback(1);
        I2C_Send7bitAddress(I2C, EEPROM_ADDR, I2C_Direction_Transmitter);
        timer = TIMEOUT;
        while(!I2C_CheckEvent(I2C, I2C_EVENT_MASTER_TRANSMITTER_MODE_SELECTED))
                timer--;
                if(timer == 0 ) ErrorCallback(2);
        I2C_SendData(I2C, Addr_of_EE);
        timer = TIMEOUT;
        while(!I2C_CheckEvent(I2C, I2C_EVENT_MASTER_BYTE_TRANSMITTED))
                timer--;
                if(timer == 0 ) ErrorCallback(3);
        I2C_SendData(I2C, *pBuffer);
        timer = TIMEOUT;
                timer--;
                if(timer == 0 ) ErrorCallback(4);
        I2C_GenerateSTOP(I2C, ENABLE);
        return 0;
@brief: 读取字节
@retval:
uint8_t I2C_EE_Read(uint8_t* pDstBuffer, uint8_t Addr_of_EE, uint16_t size)
        Wait_EE_Ready();
                timer--;
                if(timer == 0)  ErrorCallback(9);
        timer = TIMEOUT;
                timer--;
                if(timer == 0) ErrorCallback(10);
        timer = TIMEOUT;
                if(timer-- == 0 ) ErrorCallback(11);
        Wait_EE_Ready();
                timer--;
                if(timer == 0)  ErrorCallback(12);
        I2C_Send7bitAddress(I2C, EEPROM_ADDR, I2C_Direction_Receiver);
        timer =TIMEOUT;
        while(!I2C_CheckEvent(I2C, I2C_EVENT_MASTER_RECEIVER_MODE_SELECTED))
                if(timer-- == 0) ErrorCallback(13);
        I2C_AcknowledgeConfig(I2C, ENABLE);
        while(size)
                if(size == 1)
                        I2C_AcknowledgeConfig(I2C, DISABLE);
                timer =TIMEOUT;
                while(!I2C_CheckEvent(I2C, I2C_EVENT_MASTER_BYTE_RECEIVED))
                        if(timer-- == 0) ErrorCallback(14);
                *pDstBuffer = I2C_ReceiveData(I2C);
                pDstBuffer++;
                size--;
        return 0;
求大神帮忙debug
GMT+8, 2024-11-25 01:53 , Processed in 0.037011 second(s), 24 queries , Gzip On.
