研究生
最后登录1970-1-1
在线时间 小时
注册时间2019-5-23
* @brief Configures the TIMx Trigger as External Clock
* @param TIMx: where x can be 1, 2, 3, 4, 5, 8, 9, 10, 11, 12, 13 or 14
* to select the TIM peripheral.
* @param TIM_TIxExternalCLKSource: Trigger source.
* This parameter can be one of the following values:
* @arg TIM_TIxExternalCLK1Source_TI1ED: TI1 Edge Detector
* @arg TIM_TIxExternalCLK1Source_TI1: Filtered Timer Input 1
* @arg TIM_TIxExternalCLK1Source_TI2: Filtered Timer Input 2
* @param TIM_ICPolarity: specifies the TIx Polarity.
* @arg TIM_ICPolarity_Rising
* @arg TIM_ICPolarity_Falling
* @param ICFilter: specifies the filter value.
* This parameter must be a value between 0x0 and 0xF.
* @retval None
void TIM_TIxExternalClockConfig(TIM_TypeDef* TIMx, uint16_t TIM_TIxExternalCLKSource,
uint16_t TIM_ICPolarity, uint16_t ICFilter)
/* Check the parameters */
assert_param(IS_TIM_LIST1_PERIPH(TIMx));
assert_param(IS_TIM_IC_POLARITY(TIM_ICPolarity));
assert_param(IS_TIM_IC_FILTER(ICFilter));
/* Configure the Timer Input Clock Source */
if (TIM_TIxExternalCLKSource == TIM_TIxExternalCLK1Source_TI2)
TI2_Config(TIMx, TIM_ICPolarity, TIM_ICSelection_DirectTI, ICFilter);
TI1_Config(TIMx, TIM_ICPolarity, TIM_ICSelection_DirectTI, ICFilter);
/* Select the Trigger source */
TIM_SelectInputTrigger(TIMx, TIM_TIxExternalCLKSource);
/* Select the External clock mode1 */
TIMx->SMCR |= TIM_SlaveMode_External1;
根据高级定时器的结构图不是应该有四个通道的吗?分别是TI1,TI2,TI3,TI4的吗?为啥这里就只有TI1和TI2呢?没有找到TI3和TI4的通道配置的,有谁知道吗?
