查看: 10600|回复: 4
[求助] 为什么ifconfig中不包含can设备?
发表于 2021-3-18 12:29:16 | 显示全部楼层 |阅读模式
eth1: flags=4099<UP,BROADCAST,MULTICAST>  mtu 1500
        ether 6a:09:56:05:ce:76  txqueuelen 1000  (Ethernet)
        RX packets 0  bytes 0 (0.0 B)
        RX errors 0  dropped 0  overruns 0  frame 0
        TX packets 0  bytes 0 (0.0 B)
        TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
eth2: flags=-28669<UP,BROADCAST,MULTICAST,DYNAMIC>  mtu 1500
        ether c2:f6:99:89:94:98  txqueuelen 1000  (Ethernet)
lo: flags=73<UP,LOOPBACK,RUNNING>  mtu 65536
        inet 127.0.0.1  netmask 255.0.0.0
        inet6 ::1  prefixlen 128  scopeid 0x10<host>
        loop  txqueuelen 1000  (Local Loopback)
        RX packets 2460  bytes 157650 (153.9 KiB)
        TX packets 2460  bytes 157650 (153.9 KiB)
sit0: flags=128<NOARP>  mtu 1480
        sit  txqueuelen 1000  (IPv6-in-IPv4)
config文件中有:
CONFIG_CAN_FLEXCAN=y
 楼主| 发表于 2021-3-18 12:32:05 | 显示全部楼层
这里也说明can驱动存在了
debian@npi:/proc$ grep -i flexcan kallsyms
00000000 t flexcan_read_be
00000000 t flexcan_write_be
00000000 t flexcan_mb_read_be
00000000 t flexcan_mb_write_be
00000000 t flexcan_read_le
00000000 t flexcan_write_le
00000000 t flexcan_mb_read_le
00000000 t flexcan_mb_write_le
00000000 t flexcan_chip_enable
00000000 t flexcan_chip_disable
00000000 t flexcan_noirq_suspend
00000000 t flexcan_runtime_resume
00000000 t flexcan_runtime_suspend
00000000 t flexcan_noirq_resume
00000000 t flexcan_chip_stop
00000000 t flexcan_chip_start
00000000 t flexcan_resume
00000000 t flexcan_suspend
00000000 t flexcan_remove
00000000 t flexcan_set_mode
00000000 t flexcan_start_xmit
00000000 t flexcan_mailbox_read
00000000 t flexcan_irq
00000000 t flexcan_get_berr_counter
00000000 t flexcan_close
00000000 t flexcan_probe
00000000 t flexcan_open
00000000 r flexcan_of_match
发表于 2021-3-19 08:45:18 | 显示全部楼层
ifconfig -a
 楼主| 发表于 2021-3-19 18:31:27 | 显示全部楼层
ifconfig -a也没有
debian@npi:~$ ifconfig -a
        ether a2:0f:73:cf:3a:17  txqueuelen 1000  (Ethernet)
eth2: flags=-28605<UP,BROADCAST,RUNNING,MULTICAST,DYNAMIC>  mtu 1500
        inet 192.168.8.101  netmask 255.255.255.0  broadcast 192.168.8.255
        inet6 fe80::cca9:42ff:fe8a:477d  prefixlen 64  scopeid 0x20<link>
        ether ce:a9:42:8a:47:7d  txqueuelen 1000  (Ethernet)
        RX packets 235  bytes 34942 (34.1 KiB)
        TX packets 206  bytes 18649 (18.2 KiB)
        RX packets 84  bytes 7004 (6.8 KiB)
        TX packets 84  bytes 7004 (6.8 KiB)
发表于 2021-4-29 16:09:41 | 显示全部楼层
877509395@qq.co 发表于 2021-3-19 18:31
ifconfig -a也没有
eth1: flags=4099  mtu 1500
设备树插件开了没
GMT+8, 2024-11-23 19:06 , Processed in 0.031083 second(s), 23 queries , Gzip On.
