查看: 29165|回复: 0
fsmc如何驱动 nand flash
发表于 2021-4-2 09:30:31 | 显示全部楼层 |阅读模式
static void NAND_GPIO_Config(void)
        GPIO_InitTypeDef  GPIO_InitStructure;
  FSMC_NAND_PCCARDTimingInitTypeDef  p;
  FSMC_NANDInitTypeDef FSMC_NANDInitStructure;
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD | RCC_APB2Periph_GPIOE
                          | RCC_APB2Periph_GPIOG, ENABLE);
        RCC_AHBPeriphClockCmd(RCC_AHBPeriph_FSMC,ENABLE);
  /*pd11-cle pd12-ale    ce-pd7   pd5-we  pd4-re*/
  GPIO_InitStructure.GPIO_Pin =  GPIO_Pin_14 | GPIO_Pin_15 | GPIO_Pin_0 | GPIO_Pin_1 |
        GPIO_Pin_11|GPIO_Pin_12|GPIO_Pin_7|GPIO_Pin_4|GPIO_Pin_5;
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_7 | GPIO_Pin_8 | GPIO_Pin_9 | GPIO_Pin_10;
  GPIO_Init(GPIOE, &GPIO_InitStructure);
        /*RBbusyout  nint   pg6*/
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU;
  GPIO_Init(GPIOG, &GPIO_InitStructure);
  p.FSMC_SetupTime = 0x1;
  p.FSMC_WaitSetupTime = 0x3;
  p.FSMC_HoldSetupTime = 0x2;
  p.FSMC_HiZSetupTime = 0x1;
  FSMC_NANDInitStructure.FSMC_Bank = FSMC_Bank2_NAND; //Ñ¡Ôñnand¿é2
  FSMC_NANDInitStructure.FSMC_Waitfeature = FSMC_Waitfeature_Enable; //??FSMC?????
  FSMC_NANDInitStructure.FSMC_MemoryDataWidth = FSMC_MemoryDataWidth_8b; //NAND Flash??????8?
  FSMC_NANDInitStructure.FSMC_ECC = FSMC_ECC_Enable;                  //??ECC??
  FSMC_NANDInitStructure.FSMC_ECCPageSize = FSMC_ECCPageSize_2048Bytes; //ECC???2048
  FSMC_NANDInitStructure.FSMC_TCLRSetupTime = 0x00;
  FSMC_NANDInitStructure.FSMC_TARSetupTime = 0x00;
  FSMC_NANDInitStructure.FSMC_CommonSpaceTimingStruct = &p;
  FSMC_NANDInitStructure.FSMC_AttributeSpaceTimingStruct = &p;
  FSMC_NANDInit(&FSMC_NANDInitStructure);
  /*!??FSMC BANK2 */
  FSMC_NANDCmd(FSMC_Bank2_NAND, ENABLE);
我的板子pg6引脚连得R/B,即FSMC_INT与nand flash相连、我看网上的资料还初始化了PD6即FSMC_NWAIT引脚         。
FSMC_NWAIT和fsmc_int选 用上有什么不同,使用FSMC_INT要做什么处理
GMT+8, 2024-11-23 22:50 , Processed in 0.027254 second(s), 23 queries , Gzip On.
