查看: 30261|回复: 2
[求助] CentOS下内核编译失败
发表于 2021-4-18 18:45:23 | 显示全部楼层 |阅读模式
我的虚拟机很早之前装了CentOS系统,编译内核时失败;
按照指引,已安装了提到的工具(make gcc-arm-linux-gnueabihf gcc bison flex libssl-dev lzop),除了Debian特有的安装工具dekg-dev
编译提示以下信息:
make[1]: Leaving directory `/home/break/fireLinux/ebf-buster-linux/build_image/build'
make: *** [sub-make] Error 2
make[1]: Entering directory `/home/break/fireLinux/ebf-buster-linux/build_image/build'
/bin/sh /home/break/fireLinux/ebf-buster-linux/scripts/package/mkdebian
dpkg-buildpackage -r"fakeroot -u" -a$(cat debian/arch) -b -nc -uc
/bin/sh: dpkg-buildpackage: command not found
make[2]: *** [bindeb-pkg] Error 127
make[1]: *** [bindeb-pkg] Error 2
各位大佬,应该能在centos上编译通过呢??求助,不想重装系统啊
发表于 2021-4-19 16:14:59 | 显示全部楼层
建议还是使用Ubuntu18 省得瞎折腾
发表于 2021-5-28 16:18:59 | 显示全部楼层
故障原因:
缺了  dpkg-buildpackage
解决方案:
  1. # yum provides dpkg-buildpackage
  2. > Loaded plugins: fastestmirror
  3.    Loading mirror speeds from cached hostfile
  4.    dpkg-dev-1.18.25-9.el7.noarch : Debian package development tools
  5.    Repo        : epel
  6.    Matched from:
  7.    Filename: /usr/bin/dpkg-buildpackage
GMT+8, 2024-11-23 18:40 , Processed in 0.080624 second(s), 27 queries , Gzip On.
