查看: 27999|回复: 1
固件库点灯
发表于 2021-4-20 20:07:33 | 显示全部楼层 |阅读模式
我用的原子的板子,LED是PB5,寄存器变固件库这一课的时候,寄存器能点亮,固件库(程序如下)就点不亮了,后来我又改了一下,发现GPIOB->ODR不变,把GPIOB->CRL改成GPIOB_CRL,就能点亮。
按理说应该是结构体定义这块的问题,但是我就是找不出问题,哪位大侠帮我看看,谢谢了!
main.c
int main()
RCC_APB2ENR |= (1<<3);
GPIOB->CRL         &= ~((0xf)<<(4*5));
GPIOB->CRL         |= ((1)<<(4*5));
GPIOB->ODR        &= ~(1<<5);
stm32f10x.h
#define PERIPH_BASE                                        ((unsigned int)0X40000000)
#define APB1PERIPH_BASE                        PERIPH_BASE
#define APB2PERIPH_BASE                        PERIPH_BASE + 0x10000
#define AHBPERIPH_BASE                        PERIPH_BASE + 0x20000
#define RCC_BASE                                                AHBPERIPH_BASE + 0x1000
#define GPIOB_BASE                                        APB2PERIPH_BASE + 0x0C00
#define GPIOE_BASE                                        APB2PERIPH_BASE + 0x1800
#define RCC_APB2ENR                                        *(unsigned int *)(RCC_BASE + 0x18)
#define GPIOB_CRL                                                *(unsigned int *)(GPIOB_BASE + 0x00)
#define GPIOB_CRH                                                *(unsigned int *)(GPIOB_BASE + 0x04)
#define GPIOB_ODR                                                *(unsigned int *)(GPIOB_BASE + 0x0C)
#define GPIOE_CRL                                                *(unsigned int *)(GPIOE_BASE + 0x00)
#define GPIOE_CRH                                                *(unsigned int *)(GPIOE_BASE + 0x04)
#define GPIOE_ODR                                                *(unsigned int *)(GPIOE_BASE + 0x0C)
typedef unsigned int                uint32_t;
typedef unsigned short        uint16_t;
typedef struct
        uint32_t        CRL;
        uint32_t        CRH;
        uint32_t        IDR;
        uint32_t        ODR;
        uint32_t        BSRR;
        uint32_t        BRR;
        uint32_t        LCKR;
}GPIO_TypeDef;
#define GPIOB                ((GPIO_TypeDef*)GPIOB_BASE)
#define GPIOE                ((GPIO_TypeDef*)GPIOE_BASE)
 楼主| 发表于 2021-4-21 19:51:08 | 显示全部楼层
没有人的吗?555
GMT+8, 2024-11-24 21:52 , Processed in 0.026708 second(s), 23 queries , Gzip On.
